programming language c using atmega328p
69 posts / 0 new
M.K
Is this a homework/coursework question?
What work have you done yourself? What happens? What doesn't happen?
No, it is not a school assignment, I took this assignment online, where I am preparing to enroll in October in a faculty in Computer Science and Engineering
I need your help
M.K
Metro1 wrote:
I am left with a task which I have no idea how to solve
So you need two programs,
in one you need to set up a timer, either timer0 or timer1 with a one second timeout (overflow).
You also need to set up the usart to send data (TX).
In program 2, you also need to setup the usart to receive data.
and be able to turn on/off one of two LEDs.
I would start with program 2, show us how you would setup the init_usart() function, and how to init the port pins to drive two LEDs.
Begin with a schematic of this M328, show how you would connect the two LEDs with series current limiting resistors.
Note: since the above problem description does not include how the h/w is setup, just show how the two micro's would be connected together and how the leds will be connected, don't worry about how the micro's are powered, bypass caps ect as that is not a requirement of the assignment.
Keys to wealth:
Thank you Jim
Can you write me the Code, because I do not know much in the UART part.
M.K
We are professionals who are paid to write programs, we don't provide code for free.
However, we will help you with your code, show what you have so far and we can help you get it right.
Keys to wealth:
Here is a basic send character function, you will need to init the usart to match the requirements stated above.
int putc(char c){
//put char to usart0... dont add lf after cr
  while(!(UCSR0A & UDRE0)){};	//wait for data reg empty
  UDR0=c; //send char
  return c;
You need to set the baud rate register and change the default no parity to odd or even parity (your choice) and enable the usart TX.
edit: corrections to syntax for M328
Keys to wealth:
Total votes: 2
Well, some will do free code, if they have an itch to scratch. But this sounds like an assignment to determine readiness. It is for your good to solve it yourself if you cannot, then you are not yet ready for the class.
I took this assignment online, where I am preparing to enroll in October in a faculty in Computer Science and Engineering, It is not a project
I need your help
M.K
It is true that I have never studied microcontroller programming in high school, I have tried for many days to solve this task myself, but I need help to gain motivation to enroll in university in computer science
M.K
Is the first part of the program
M.K
Go to the Microchip website and download the datasheet for the Atmega328p, spend some time reading the timer sections and usart sections, come back with any questions you have.
It may be easier to just google atmega328p datasheet!
Keys to wealth:
See if this ebook will give you the basics you need to meet the entrance requirements.
https://www.google.com/url?sa=t&...
Keys to wealth:
Thank you so mach
M.K
I have no idea how to read the datasheet of atmga328p,
Please help me solve this task .
M.K
There is an automatic system which is controlled by two robots.
It should be a piece of cake then. Glad it's only a simple project, not as complicated, say, as to flashing a LED.
Can you help me to solver this task
M.K
Yes, go and do a university or college course for a few YEARS that teaches you the subjects. What is the point of anyone doing YOUR work if you don't know what you are doing?
What happens at you next exam? Will you ask someone to sit it for you?
We surely can help but you must show what you have done.
It is true what you say, that if you do not solve it yourself then who will help me in the exam, I have been trying for several days to solve this task myself, but now I am tired and I am asking for help from you, I i want to see the code and then analyze how the program this project is.
Please understand me.
M.K
We understand you. We get lots of similar questions. Unfortunately, you have exposed yourself as someone who wants to cheat. Is this how you want to be viewed?
Think about the question you are asking as the answer you seek will not help you.
If you want to help yourself, then do some research on the interwebs. Asking these questions on a forum is not good for you - your identity can be easily traced.
It does not matter that my identity can be easily traced, I am not doing any deception, I am just asking for help in solving a task that I have some days that I can not solve, so. If what I am saying is deception then I will leave this forum.
M.K
You have asked us to provide you code so that you can submit it under your name in an entrance exam. Is this not what you have asked? If not, this is how it has been interpreted. Go back and read what you posted.
I’d suggest your actions are ethically challenged.
Sorry my english is not good,
This task will not be in the University entrance exam, I am just preparing by solving tasks which have been in the exams in the past years
M.K
You keep on changing your story. How long do you want to continue this?
Help yourself - google has the answers you seek.
I am also searching on google I have learned some things in programming, but in the part with timer and UART I can not understand them and for this reason I asked for your help.
M.K
Metro1...
Perhaps, some hints may help.
You have stated what you want.
The NEXT step is to think of what big pieces you need in order for that to happen. Send characters? Receive characters? Start or stop various robot pieces?  Just list the major tasks. Now, you have started to DESIGN your software.
A possible next step is to create functions in C that actually do these things. For example you might have
void run_motor(uint8_t motornum, uint8_t speed);
Assuming that there is more than one motor, you would write it to control several motors by number, each with its own speed. You could have speed of zero to mean STOP. There are many examples of character transmitting and receiving functions scattered around the internet. You can certainly find examples since Mega328 is so common. These are examples. You will probably have functions to do other things. For example, you might have one that checks received characters and looks for patterns (called "parsing") that are used to choose which function to call for each serial input string. Probably quite a few more.
BUT, now lets take a step back. This is how you would do it. HOWEVER, you have to learn the low level basics first. I highly recommend that you do some kind of "flash LED" program filrst. These are often called "blinky" programs. This will introduce you to different ways of controlling port pins, which you surely need.
The simple fact is that the project you are trying to do is totally inappropriate for someone who has only been learning the abstract concepts of C. It is as big a job to learn the hardware. And, it is just as important. It is completely unrealistic to make the jump from the abstraction of the C langauge into a hardware intensive project without learning basics. PLEASE take the little step, first.
Thank you so much for the suggestions and help, I will start trying again in solving this task
M.K
... to implement the periodic execution to be used interrupt Service and Output Compare Timer interrupt in normal mode (free running).
This doesn't make any sense at all.  I'll go out on a limb and assume that Robot 2 has a OC Timer IRQ that goes off at "heartbeat" rates like every 1 millisecond.
And this ISR checks to see if any new data byte has arrived on the USART from Robot 1.   If a new data byte has arrived, the OC ISR reads this data byte into a volatile global one byte variable and sets a flag for the main code that a new command has arrived from Robot1 and it needs servicing.
The fact that the "customer" i.e the person who defined the situation that you need to program for forbids using Arduino and delay() functions only shows that this is a academic/test example and not a real-world situation because it if were then you would always use Arduino as a platform when the AVR device is a Mega328P.  Because Arduino is an easier way to go for this one AVR device {the mega328p, which is used by the UNO and Nano, the two cheapest and most common Arduino platforms}.
Start by making charts and diagrams:  what gets sent from one Robot to the other?   When?   How does each robot react to data coming from the other robot?
I can't help thinking there is something "missing" from this whole picture. Sure the task involves using timers in interrupt mode and UARTs to send/receive so the general structure is going to be:
// robot 1
int main(void) {
    init_uart();
    start_timer();
    enable_interrupts();
    while(1) {
ISR(timer) {
    tosend = robo1();
    uart_send(tosend);
// robot 2
int main(void) {
    init_uart();
    while(1) {
ISR(UART_rx) {
    robo2(UDR);
but this is just the "high level" design. To actually implement this you need to know what ini_uart(), start_timer(), enable_interrupts(), uart_send() actually look like. Unless you are telepathic this is not something that just magically pops into your brain. There must surely be course notes asscoiated with the exam? The usual pattern of exams is that you do several months of learning being guided by a tutor who in a well design/structured way builds up your knowledge from the simplest things to the complex. You then take that on board. Maybe run some experiments trying each of the things in turn (timers, polled UART, interrupt UART etc) and when you have all the "building blocks" of knowledge you put that all together in the exam at the very end of the course to prove that you have understood the details of all that you were taught and have understood and taken on board.
What you can't do is just jump straight to the exam and somehow magically pluck all the knowledge out of no where.
So surely the missing bit is the course work/teaching/slides/books/presentations that would imbue the knowledge into you?
Give a link to this online "course" - If you've got to this stage "without a clue", it might be complete rubbish. Many are, we freaks could suggest better examples but we need some idea of your experience and competence level.
Well, maybe you are not yet ready for microcontroller work yet.
what things do you already know about the AVR?
What things are you already able to do with an AVR?
Have you ever used any microcontroller at all?  Which ones?
I am learning programming in Embedded,
We wouldn't want to give you the wrong advice, so you must list everything you have learned so far about embedded programming, with a brief explanation and example of each concept.
Do you already have any experience with programming in any other context?
If not, it would be far easier to start by learning the 'C' (or C++) programming language on a PC - away from all the added complications & restrictions of embedded microcontrollers.
An essential part of programming embedded microcontrollers is, at least, a working understanding of electronics.
See Tip #6 in my signature, below, for some beginner getting started info ...
Thank you
The reason I have problems in programming in Embedded is that I have been in the direction of natural sciences in high school, while the exam to be admitted to the University in computer science is built based on the knowledge that students have gained in high school in electronic directions, mathematics and computer science ... etc. and not for students of natural sciences.
M.K
Then you have to do that course first before you stand any chance of knowing how to do this.
(I would like to be a virtuoso concert pianist but I recognize I probably need to practice the piano for another 10-20 years before they'll hire me. Just because you can pick out "Frere Jacques" with one finger does not qualify you to play Carnegie Hall !)
Perhaps you should be discussing with the University's Admissions people how they suggest that you proceed ?
Clearly, as others have said, you do need to have done the necessary preparation, and laid the necessary foundations, before you start!
That's not something you're going to get from a few forum posts.
My wish is to be a programmer, I know well the front-end and back-end part in building a website, I am not so interested in embedded programming development subjects, but to be accepted in The university has to pass the exam where there will also be tasks from programming to embedded.
I was just asking for your help to solve this task, so that I could continue to understand as little as possible.
M.K
I was at university and I asked if it would be the same exam for students of mathematics and science students, they told me that there will be no division of exams for certain areas.
M.K
Then this is the WRONG COURSE you are trying to join. Surely there must be courses that speciialise in only server-side programming (PHP, Perl, Ajax, Javascript, etc etc)? "Web programming" and "embedded programming" are as different as learning chinese or serbo-croat, a course that concentrates on one will be of no use in learning the other.
This is my goal to continue my specialization in server programming after being accepted to the University, but I must first pass the exam in embedded.
M.K
Sorry but that does not make any sense. It's like training to be a car mechanic so you can captain a yacht. Surely some university near you must run web programming degrees?
There are universities with internet programming, but they are private universities and the cost of studies is very high, where I want to enroll is a public university.
M.K
If you want to be a Chinese interpreter what would be the point in learning Serbo_Croat just because the course to do it is free?
Then you're just going to have to put the work in to pass this assessment!
It's really not hard - the question seems to be basically just to do serial comms between two computers (the fact that they are called "robots" is irrelevant).
Using a UART is one of the most basic tasks of using a microcontroller - so it really shouldn't be hard to find beginner's tutorials for this.
If you're serious about being a programmer - embedded or otherwise - you really need to learn how to work this stuff out for yourself by studying documentation, searching for examples, tutorials, etc.
Even as a server programmer, you are going to be faced with new interfaces, APIs, frameworks, etc that you've never used before - so you are going to need the skills to work them out.
All right, what you say is true.
I begged you if you could help me solve any task
M.K
My problem is that I do not know English well and many videos on Youtube are in English and I do not understand how UART and TIMER are used.
Please if you can only solve the first part for me while the other part I will try to solve it myself by looking at your solution and how to use TIMER and UART
M.K
Remember:
So you have 2 choices:
  1. get down to some serious study so that you are able to do this assignment, or
  2. choose another course and/or University.
Metro1 wrote:
... while the exam to be admitted to the University in computer science is built based on the knowledge that students have gained in high school in electronic directions, mathematics and computer science ... etc. and not for students of natural sciences.
Excellent goal (all kinds to make the world)
The authors of AoE recognize the issue of students having to acquire knowledge in electronics and embedded systems.
The ECE department in an engineering college may have a course in embedded systems (electronics + software)
The Art of Electronics 3rd Edition | by Horowitz and Hill
PREFACE TO THE FIRST EDITION
[second paragraph]
If the third edition is too expensive then consider the second edition in e-book form.
The Art Of Electronics | Download eBook pdf, epub, tuebl, mobi
ECE - Electrical and Computer Engineering
edit : on sale
The Art of Electronics 3rd Edition by Paul Horowitz (eBook PDF)
Please guys
Will you help me solve the first part of the task that has to do with the robot1?
I'm tired of trying but not understanding the part with UART and TIMER.
I thought you would give me the motivation to continue learning for the entrance exam in Computer Science.
M.K
What, exactly, do you mean by "the first part"?
Restate the problem clearly.
Then tell us what you have tried; and where, specifically, you are stuck.
So what, exactly, have you tried in order to learn those things?
And where, exactly, are you stuck?
Again, you are going to have to work this kind of thing out even for "server programming"
Working out how to use a UART or Timer is no more difficult than working out how to use some API.
You could think of the UART as just an API - which is defined in terms of "registers" ...
The only one that can give you motivation is you..........
The problem is going to be that once you get in the class with answers we given you are close to be an exert... now The first assignment in that class you again will have to get help from us, or fail miserably......
These entry exams are not there for nothing.
I suggest you take the datasheet of the chip you have to use and first go through that from top to bottom, and get to grips with what peripheral blocks it has. No need to go in to detail yet and do that before you go of to doing anything else....
Then read again through all the comments ( I have not read them all, but have seen suggestions on how you need to go forth......
break your overal system up into blocks.......
After that take each block and see if you can manage that with one or more peripherals inside the cpu if you can write down that you need to use those.
if you have done that for all items you could for fun start coding, but at this moment that would not be wise as it might distract you from the next thing and that is to make a layer that combines functions.
so you have to continue your way up the program. Once you have done this paper only exercise you can start making the program flow in pseudo code and then block by block replace that with real code.
I usually do this in a text file were each drop in the level of the code is one or two indentations.
Then during making and testing of each code block and when it is OK I remove it from that description file as in the project then you have the real code to continue working with.
Keep in mind that writing code starts with thinking on how to do it. If you cannot do that, then those courses will be hell for you as you will be running behind all the time.
Also keep in mind that when you tested code blocks and run into problems you can always come here and ask, but it is you that is doing the coding we are only going to give advice, perhaps more than you bargained for......
Metro1 wrote:
... I know well the front-end and back-end part in building a website, I am not so interested in embedded programming development subjects, but ...
Yet, the two can be combined.
WebUSB :
WebSocket :
P.S.
Metro1 wrote:
... so that I could continue to understand as little as possible.
indecision
Consider comprehension wink
I'm talking about this part of the task.
The robo1 () function is implemented - you just have to use it.
Implement the program for Robot 1 which:
Executes the function robo1 () periodically with a period of 1 sec. --------How is a function executed periodically with a period of 1 sec?
At the end of the function execution, it sends the return value of the function via UART to Robot 2 (assuming that robots 1 and 2 are connected to each other via a serial communication line
through UART) to implement the periodic execution to be used interrupt Service and Output Compare Timer interrupt in normal mode (free running)------------------How?
Select the parameters for communication via UART with the maximum speed for communication which support the controller in question. Implement parity bit for error checking.
The use of Arduino IDE functions is not allowed and the use of delay () functions is not allowed. The oscillator frequency is 4 Mhz----------------------------------------------------------How?
roboti1.c
unsigned char robo1(void);
int init_robo1 (void) {
int main (void) {
M.K
This parti
Executes the function robo1 () periodically with a period of 1 sec ------------------------Si ekzekutohet nje funskionin ne menyre periodike me nje periode prej 1 sec?
At the end of the function execution, it sends the return value of the function via UART to Robot 2 (assuming that robots 1 and 2 are connected to each other via a serial communication line through UART) to implement the periodic execution to be used interrupt Service and Output Compare Timer interrupt in normal mode (free running)------------------------------------------How?
The use of Arduino IDE functions is not allowed and the use of delay () functions is not allowed. The oscillator frequency is 4 Mhz-------------------------------------------------------How?
roboti1.c
int main (void) {
M.K
A-Ha this thread has developed a new twist since I last posted.
Can we assume you have zero interest in embedded programming ? This is totally understandable, I used to work amongst programmers who were adept with AngularJS but couldn't program AVR for toffee. (even when given Arduino)
Here's a radical thought; what happens if you simply fail the embedded section of the entrance exam but ace those sections that are pertinent to back-end server coding.
Metro1 wrote:
Please guys
I already showed you the high level of the structure for this in #29. All that remains is to add the detail to that. That will involve programming UART and timer. You say you are "tired of trying"? Well I guess it depends how desperately you want to join this course. But consider this: you actually state that this is the paper from a previous year. So assuming you work away at this and learn about timer and UART and then you find that in "this years paper" they actually set a task involving ADC and SPI how are you going to get on with that? The bottom line is that you probably need to have done the entire course that the other entrants have done. Learned about ADC, I2C, Comparator, timer (CTC and PWM), UART, SPI and all the other AVR peripherals that they likely were taught about. Then, when this years exam turns out to be I2C and PWM you will be prepared.
Or are you really hoping they just set the same robo1()/robo2() question every year? It's a bit of gamble!
That is answered for you:
So have you tried googling those terms?
http://www.lmgtfy.com?q=Timer+Output+Compare+Interrupt+Service
Which controller is that?
Add its model number to your google search ...
Please guys
I'm tired of trying but not understanding the part with UART and TIMER.   IF YOU ARE TIRED OF TRYING THAT DOESN'T BODE WELL
I thought you would give me the motivation to continue .  SORRY IT DOESN'T WORK THAT WAY
So if you needed to update a web page once a second, how would you do that?
show the code needed please!
jim
Keys to wealth:
Hello can you tell me if this first part of the task I have given is good
#include<avr/interrupt.h>
#define F_OSC 4000000
#DEFINE PRESCALER 1024
#define TCS_PER_INTERVAL(F_OSC/PRESCALER)
#define BAUD 9600
#DEFINE MYUBERR (F_OSC/16/BAUD-1)
voltile unsigned int sec;
volatile unsigned char value;
ISR(TIMER1_COMPA_vect){
    sex++;
    OCRIA+= TICS_PER_INTERVAL'
    value=init_robo1();
    usartWrite(value);
void usartWrite(unsigned char data)
while(!(UCSR0A &(1<< UDRE0)));
UDR0=data;
void init(void)
//UART
UBRROH =MYUBRR>>8;
UBRROL= MYUBRR & 0x00FF;
UCSR0B = 1<<TXEN0;
UCSROC |=(1<<UPM00)|(1<<UPM01);
UCSR0C |=(1<<UCSZ00)|(1<<UCSZ01);
UCSR0C |=0<<USBS0
//TIMER
TCCR1A|=1<<COM1A0;
TCCR1B|=(1<<CS12)|(1<<CS10);
OCR1A=TICS_PER_INTERVAL;
TIMSKI|=1<<OCIE1A;
sei();
int init_robo1(void)
    sec=0;
    init();
    while(1){
M.K
#define BAUD 9600
    sex++;
    value=init_robo1();
    usartWrite(value);
UDR0=data;
void init(void)
//UART
UBRROH =MYUBRR>>8;
UCSR0B = 1<<TXEN0;
UCSR0C |=0<<USBS0
//TIMER
TCCR1A|=1<<COM1A0;
TIMSKI|=1<<OCIE1A;
sei();
    sec=0;
    init();
    while(1){
M.K
#define BAUD 9600
    sex++;
    value=init_robo1();
    usartWrite(value);
UDR0=data;
void init(void)
//UART
UBRROH =MYUBRR>>8;
UCSR0B = 1<<TXEN0;
UCSR0C |=0<<USBS0
//TIMER
TCCR1A|=1<<COM1A0;
TIMSKI|=1<<OCIE1A;
sei();
    sec=0;
    init();
    while(1){
M.K
You've been pointed to the Tips in my signature already - Tip #1 shows you how to properly post source code.
Put comments in the code which describe what you think the code should be doing.
Do just one thing at a time; eg, timer first; UART next.
Metro1 wrote:
sex++;
laugh laugh laugh laugh
Go on - you clearly haven't even tried to compile it yourself.
You could use the Simulator in Atmel Studio to see how it runs (although it runs an order of magnitude slower than real time) ...
hahhahahhaah noo sex++
sec++
M.K
At it's simplest:
function myreloader() {
  location.reload();
setTimeout(myreloader, 1000);
Which partly illustrates my point above - these web guys just cant be a**ed with F_CPU or configuring registers.
I would like to mention that when you set up one of those network servers, they tend to have serial interfaces (e.g., UARTs at least that was how telecom machines were), they did not have screens or keyboards. So if you ever need to provision such a server to develop on, then the knowledge of how a UART works would be handy. The R-Pi has figured out a way around the provisioning problem, but that in itself is a topic.
Hello everyone
I thank you for the advice you have given me to solve the task, by practicing those tips I have managed to solve the task.
This task was not a task that is set in practice or school task, I was practicing some of the exercises that I found on the Internet and I wanted to practice.
Thanks again for all the tips.
M.K
Lockout Padlock
Just say'in ...
DocJC wrote:
Lockout Padlock
Just say'in ...
great idea
jim
Topic locked
