Magic Wires--don't be fooled
28 posts / 0 new
I set down a magnet on my table.  When I picked it up, a bunch of jumper wires came with it...Strange, I thought.
Turns out about half the assorted ones I had, displayed this mysterious effect....the wires even look like copper, but apparently are steel coated copper, or have ferrous deposits in the mix (maybe they just melt a bunch of different scrap metals together).
They snapped strongly to the magnet so it's more than a little iron residue.   The good jumpers weren't even slightly attracted to the magnet.  I want a refund!!  Calling China to speak with Happy Luck Treasure.
I've noticed this with some resistor leads & headers, but never jumper wires.
The stripped wire pic has both ends cut off...so it is wire only...looks like nice shiny pure copper---not!
Interesting, I wonder what a geiger counter would read when placed near them?
I don't know about your Americon coinage.
But UK "copper" coins have been magnetic since decimalisation.    The old big copper pennies were made of copper.
UK "silver" coins have been made from cupro-nickel since the 1920s.
Yes, a lot of connectors, header strip, ... are magnetic nowadays.
Likewise resistor leads, diode leads, ...
This implies iron content but is probably an alloy of some description.
Presumably these alloys have acceptable corrosion resistance,  conductance, ... compared to pure copper.
For things like connector pins copper alloys are better than pure copper.   Traditionally many used nickel plated brass.
I doubt if the price of copper is significant in a leaded resistor.
But it is certainly too expensive to use in coins.
They started taking the silver out of US coins starting in 1965, and completely out by 1970. You could see a brass colored layer until lately, now it appears to be a much harder mix and the impressions are barely visible now.  I thought pennies were still made of copper, but picked one up off the ground the other day to find the copper plating had been rubbed off.
Wonder how long its been that way....    You can still get .999 Silver/Gold $'s, and I see Silver hit a 5 year high today in US$.   To infinity and beyond!
No - it's more recent than that.
Original "new" pennies were not magnetic
EDIT
1992:  https://en.wikipedia.org/wiki/Penny_(British_decimal_coin)#Metallic_composition
You mean copper-coated steel ?
I expect my copper wires to be copper!....gonna check out my Pomona leads next!
It's probably copper-clad steel. It's stronger (higher tensile strength) than pure copper but has the corrosion resistance of copper.
Are those Neodymium magnets?
Some 1982 pennies are copper and some are copper coated I think nickle, depending on which mint made the pennies.  After 1982 all of them are copper plated.  I made a battery when they first started doing it making a stack of alternating types and immersing it in battery acid.  I might have sanded some of the copper plate off on alternate pennies.  I dont really understand batteries, but I think I got a couple of volts out of it.  They switched when the price of copper got to be two cents per penny, and people were melting them down and selling the copper.
This reminded me I have two 1oz 0.999 silver coins dated 1986 that are almost black from oxidation i got them so long ago.  I think silver was $7/oz at the time.  Now it is $19.05, so I have made $24 since 1986.  Many years ago my mother in law gave me a $10 Canadian coin dated 1982 that says 1/4 oz 9999 fine gold.  It is still bright and shiny and now worth $454.  I totally forgot about them.  I used Tarnex on the silver coins and now they are bright and shiny and probably worth less from the mg's of silver oxide removed.  I dont care.  I like shiny.
The US penny are made of zinc (and cobber), and that is why they make "good" batteries ;)  (just sand one side).
It's funny in DK it's actually not legal to destroy money, but US don't seem to care.
sparrow2 wrote:
... (and cobber), ...
cobber - Wiktionary
2. (Australia) A sweet consisting of a small block of hard caramel covered in chocolate.
Tasty export from Australia?
edit : wink
Yes (or some close cousin); you must be careful, these pack a quite a punch!  I got them at some cheapo place like 10 for $3....they are about 100x stronger than some other magnets I purchased.  I keep them up on the duct vent pipe, away from all the stuff I don't want magnetized, erased, or damaged.  Plus, I read that putting magnets on your ductwork induces a gammabeta field in the airflow that reduces hallucinations, palpitations, and quacking.  So far, it seems to really work!
I know, I have the scars on my fingers to prove it.  They are great for generators. wink
Sorry avrcandies, I think you need more magnets.
(Of course, you just said they were to reduce, not necessarily eliminate..) devil
David
Yeah, I think that's what I did, sand one side.  It was almost 40 years ago, though.  Right, zinc, not nickle.
Goggle says:
According to Title 18, Chapter 17 of the U.S. Code, which sets out crimes related to coins and currency, anyone who “alters, defaces, mutilates, impairs, diminishes, falsifies, scales, or lightens” coins can face fines or prison time
But then says:
It is not illegal to melt, form, destroy, or otherwise modify US coins, including pennies, unless the objective is fraudulent or with the intent of selling the raw materials of the coins for profit. Projects that use coins as materials are entirely legal in the United States
It's the intertubes, so who knows what the truth is.
I need to get some more magnets.  The quacking is driving me crazy.  I don't mind the hallucinations or palpitations.
MarkThomas wrote:
not nickle
No, not nickle. NICKEL damnit, Nickel. See e.g. https://ptable.com/
Away with these wierd Americanisms... and while we're at it, it's *sulphur*.
Neil <g,d,r>
Don't confuse silicon with silicone ...I used to see that all the time.
That is just me being a crummy speller.  Sorry.  The spell checker didn't raise a fuss, though it did look weird to me.  Turns out Nickle is some programming language.  That's a nice periodic table.  I just bookmarked it.
I go both ways with sulphate and sulfate.  The PT you sent shows "Sulfur".  You Europeans, tsk tsk.  Although I am ashamed to be American these days.    What does <g,d,r> mean?
Yeah, me too.  I get that one right, having worked in the silicon industry, and always wondered what a silicon boob job would be like.
Firm.
Firm.
LOL.  I was thinking you could do a couple of piercing and an underwire bra and have some pretty powerful computing ability.
<g,d,r>? Grin, duck, run...
Neil
Good philosophy.
Goggle says:
But then says:
The important point is: Who's gonna know?
So I melted 200 US pennies to get zinc for a small sandcast part I was making. Prove it.
Well, they seem to be able to make copper such that after re smelting it still is marked, they might also do that to the pennies. All they have to do is prove you used one or more.....
I found that interesting as there was a lot of copper theft specially on the rail ways. Now they have replaced the wiring with marked one, and have convicted a couple of people the theft has reduced a lot.
Did the copper float to the top?
They must mix in some impurities that identifies it.  I think they do that with plastic explosives too.
