SAMD21 has insomnia [Solved]
4 posts / 0 new
Problem statement: I want my SAMD21 to wake on an RTC (match) interrupt or EXTIRQ button push, but it continues immediately from the __WFI statement.
My hunch is that there's a pending interrupt at the time I call __WFI, but I haven't been able to determine which one it is.  Unwinding the ASF4 code, my setup goes like this:
    // _set_sleep_mode to STANDBY
    SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk;
    // wait for interrupt
    __DSB();
    __WFI();
    // returns immediately without sleeping
What register(s) should I examine to see if there's a pending interrupt?  As far as I can see, it's not the RTC.
Update:
In a rather heavy-handed attempt to cure the chip's insomnia, I tried the following:
static void go_to_sleep(void) {
  NVIC_DisableIRQ(EIC_IRQn);
  NVIC_ClearPendingIRQ(EIC_IRQn);
  NVIC_ClearPendingIRQ(RTC_IRQn);
  NVIC_EnableIRQ(EIC_IRQn);
  sleep(3); // in hal_sleep
... but execution still continues past the __WFI without stopping.
Solved.  There was pending data in the serial transmit buffer that kept the interrupt bit set.  Flushing the transmit data before sleeping fixed it.
fearless_fool wrote:
Solved.
Please see Tip #5 in my signature, below, for how to mark a thread as solved:
