creating a task context
6 posts / 0 new
Guys, I'm having trouble with floats in my RTOS tht I have ported to SAMA5D44.  I think the error is caused by the function that creates the context for the floating registers.  I have listed it below removing a lot of the code that I feel you do not need to see.
struct task_ctrl_obj * api_program(void(*task)(void), char const * name, void * variable_pass, unsigned int mpu_mem, unsigned char priority, unsigned char ceiling ){
	unsigned int program = (unsigned int)task & ~1u; /* Mask off lower bit in case task is thumb mode        */               					   /* Mask off lower bit in case task is thumb mode        */
	 * Setup general purpose registers
     * cpu_core_stack-- = (unsigned int) program;										   /* PC                                                    */
     * cpu_core_stack-- = (unsigned int) internal_task_destructor;		                                   /* LR: Supervisor mode                                       */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R12                                                        */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R11                                                        */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R10				                                           */
     * cpu_core_stack-- = (unsigned int) 0x00000000;		                               /* R9							    		                   */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R8                                                        */
     * cpu_core_stack-- = (unsigned int) 0x00000000;									   /* R7				                                           */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R6                                                        */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R5                                                        */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R4                                                        */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R3                                                        */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R2                                                        */
     * cpu_core_stack-- = (unsigned int) 0x00000000;                                       /* R1                                                        */
     * cpu_core_stack-- = (unsigned int) variable_pass;                                    /* R0 ARGUMENT PASS                                         */
	#define  OS_CPU_ARM_BIT_CPSR_MODE_SUPERVISOR 0x13u
	#define  OS_CPU_ARM_BIT_CPSR_T (1u << 5u)
     // Setup Status registers
     if (((unsigned int)task & 0x01u) == 0x01u) {                  			/* See if task runs in Thumb or ARM mode                */
            *cpu_core_stack-- = (OS_CPU_ARM_BIT_CPSR_MODE_SUPERVISOR  		/* Set supervisor mode.                                 */
                     	 	   | OS_CPU_ARM_BIT_CPSR_T);              		/* Set Thumb mode.                                      */
     } else {
            *cpu_core_stack-- = (0x00000100 | OS_CPU_ARM_BIT_CPSR_MODE_SUPERVISOR);
     	 *	Setup Floating Point registers
    	 *cpu_core_stack-- = 0x00000000;	 	/* Initialise Floating point status & control register  */
    	 for (int i = 0; i < 32; i++)
    		 * cpu_core_stack-- = 0x00000000;	/* Initialise general-purpose Floating point registers  */
    	 * cpu_core_stack = 0x40000000;  	 	/* Initialise Floating-Point Exception Register (Enable)*/
    // Insert Newly created task on to the Kernel
	internal_kernel_insert_task(tcb);											// insert task ctrl block unto Kernel Schedular
	tcb->stack_ptr = (unsigned char *)cpu_core_stack;													// Store Stack pointer unto the task ctrl block
	return(tcb);														// Return Handle to the newly Created Task
The part of interest is:
     } else {
Any advise is very much welcome.
Out of interest, we have the following code that loads the first task.  This may be causing the trouble with the floats: see below:
void run (void);
__attribute__((naked))void run (void){
	__asm__ __volatile__(
			"MOV     R0, %[current_tcb]\n\t"
		    "MOV     R1, %[tcb_new]\n\t"
		    "LDR     R2, [R1]\n\t"
		    "STR     R2, [R0]\n\t"
		    "LDR     SP, [R2]\n\t"
			"POP     {r0}\n\t"					// Pop new task's FPEXC
            "FLDMIAS SP!, {S0-S31}\n\t"			//    ... Pop new task's General-Purpose floating point registers.
			"POP     {r0}\n\t"
			"VMSR    FPSCR, r0\n\t"				//    ... Pop new task's FPSCR.
		    "LDMFD   SP!, {R0}\n\t"
			"MSR     SPSR_cxsf, R0\n\t"
		    "LDMFD   SP!, {R0-R12, LR, PC}" :: [current_tcb] "r" (&core_executing_task), [tcb_new] "r" (&OSTCBHighRdy));
When I pop the ""POP {r0}\n\t" // Pop new task's FPEXC", I don't see me loading the Floating-Point Exception Register?
Is this the cause of the error????
Slán
Added the following code:
			"VMSR    FPEXC, r0\n\t"
EDITED: forgot to mention that the floating point error is still there.
Balls! I have to get the debugger out, never have I been forced to go to the debugger.
Slán
Maybe I will not have to resort to the debugger, I found two or three errors in the function that creates the task.  See below, I'll not be able to test it until tomorrow.  Here's hoping it works.
    api_system_gateway();
    if(priority > 63){
        return(0);
    struct task_ctrl_obj * tcb;
    tcb = safe_malloc(sizeof(struct task_ctrl_obj));            // Allocate Memory for the Task Ctrl Block, used by the Kernel to manage the Task
    memset(tcb, 0x00, sizeof(struct task_ctrl_obj));
    if(tcb == NULL){
        return(NULL);
    unsigned int stack;
    // Allocate Memory for the Stack
    tcb->mpu_base_mem_addr = safe_malloc(mpu_mem * sizeof(int));
    tcb->stack_allocation = (unsigned char *)tcb->mpu_base_mem_addr;
    // find the number of bytes allocated
    stack = mpu_mem * sizeof(int);
    if(tcb->mpu_base_mem_addr == NULL){
        safe_free(tcb);
        return(NULL);
    // PointStack to the end of the memory structure, Stack grows downwards
    unsigned int * cpu_context = (unsigned int *)(stack + tcb->mpu_base_mem_addr);
    /* Align stack pointer.                                 */
    cpu_context = (unsigned int *)((unsigned int)(cpu_context) & 0xFFFFFFF8u);
    tcb->task_status = DORMANT;    // Initial State of all Tasks is DORMANT
     *    Register task name with operating system
    tcb->name[0] = '\0';
    //if task name has been specified then load the name into the system
    if(strlen(name)){
        struct task_id * log = safe_malloc(sizeof(struct task_id ));
        log->id = tcb;
        int i = 0;    while(* name != '\0'){
                // copy the name
                tcb->name[i] = * name; log->name[i++] = * name; name++;
        // tidy up strings by nulling the end
        tcb->name[i] = '\0'; log->name[i] = '\0';
        add_system_name(log);
     * Signal Setup
    // Setup Signal Receive Buffer, also associated with TCB
    tcb->signals = safe_malloc(sizeof(struct ipc_signal_sent));
    if(tcb->signals == NULL){
        safe_free(tcb);
        safe_free(tcb->stack_allocation);
        safe_free((struct ipc_signal_obj *)tcb->signal_management);
        return(NULL);
    tcb->signal_management->nr_signal_registered = 0;
    tcb->signals->nr_signal_received = 0;
     * Setup tcb priority
    tcb->delta_priority   = priority;                                    // Set Task Priority
    tcb->ceiling_priority = ceiling;
    tcb->default_priority = priority;                                    // Set Base Priority, used by the Priority inversion protocol
     * cpu_context-- = (unsigned int) program;                                            /* PC                                                    */
     * cpu_context-- = (unsigned int) internal_task_destructor;                            /* LR: Supervisor mode                                       */
     * cpu_context-- = (unsigned int) 0x00000011;                                       /* R1`                                                        */
     * cpu_context-- = (unsigned int) 0x00000010;                                       /* R10                                                        */
     * cpu_context-- = (unsigned int) 0x00000009;                                       /* R09                                                           */
     * cpu_context-- = (unsigned int) 0x00000008;                                        /* R8                                                           */
     * cpu_context-- = (unsigned int) 0x00000007;                                       /* R7                                                        */
     * cpu_context-- = (unsigned int) 0x00000006;                                        /* R6                                                           */
     * cpu_context-- = (unsigned int) 0x00000005;                                       /* R5                                                        */
     * cpu_context-- = (unsigned int) 0x00000004;                                       /* R4                                                        */
     * cpu_context-- = (unsigned int) 0x00000003;                                       /* R3                                                        */
     * cpu_context-- = (unsigned int) 0x00000002;                                       /* R2                                                        */
     * cpu_context-- = (unsigned int) 0x00000001;                                       /* R1                                                        */
     * cpu_context-- = (unsigned int) 0x00000000;                                       /* R0  ARGUMENT PASS                                                         */
     * cpu_context-- = (unsigned int) variable_pass;                                    /* status regsiter                             */
    #define  ARM_MODE_ARM           0x00000200u
    #define  ARM_MODE_THUMB         0x00000220u
    #define  ARM_SVC_MODE_THUMB    (0x00000013u + ARM_MODE_THUMB)
    #define  ARM_SVC_MODE_ARM      (0x00000013u + ARM_MODE_ARM)
     if ((task & 0x01u) == 0x01u) {                   /* See if task runs in Thumb or ARM mode                */
        * cpu_context-- = ARM_SVC_MODE_THUMB;                  /* CPSR  (Enable IRQ and FIQ interrupts, THUMB-mode)    */
     else {
        * cpu_context-- = ARM_SVC_MODE_ARM;                    /* CPSR  (Enable IRQ and FIQ interrupts, ARM-mode)      */
     * cpu_context-- = (unsigned int)0x00000000;         /* Initialise Floating point status & control register  */
     // floating point reegisters
         * cpu_context-- = (unsigned int)0x00000000;    /* Initialise general-purpose Floating point registers  */
     // floating point execution register
     * cpu_context = (unsigned int)0x40000000;           /* Initialise Floating-Point Exception Register (Enable)*/
    tcb->stack_ptr = (unsigned char *)cpu_context;                                                    // Store Stack pointer unto the task ctrl block
Solution/Error was the way the context switch was built.  See below for the working solution - thankyou freaks.
	if(priority > 63){
		return(0);
	if(tcb == NULL){
		return(NULL);
	unsigned int stack_offset;
	tcb->stack_allocation = (unsigned char *)safe_malloc(mpu_mem * sizeof(int));
	stack_offset = mpu_mem * sizeof(int);
	if(tcb->stack_allocation == NULL){
		safe_free(tcb);
		return(NULL);
	unsigned int * cpu_context = (unsigned int *)(stack_offset + tcb->stack_allocation);
	if(strlen(name)){
		log->id = tcb;
				// copy the name
	 * Signal Setup
		safe_free(tcb);
		return(NULL);
     * --cpu_context = (unsigned int) program;										    /* PC                                                    */
     * --cpu_context = (unsigned int) internal_task_destructor;		                    /* LR: Supervisor mode                                       */
     * --cpu_context = (unsigned int) 0x00000011;                                       /* R1`                                                        */
     * --cpu_context = (unsigned int) 0x00000010;                                       /* R10                                                        */
     * --cpu_context = (unsigned int) 0x00000009;                                       /* R09				                                           */
     * --cpu_context = (unsigned int) 0x00000008;		                                /* R8							    		                   */
     * --cpu_context = (unsigned int) 0x00000007;                                       /* R7                                                        */
     * --cpu_context = (unsigned int) 0x00000006;									    /* R6				                                           */
     * --cpu_context = (unsigned int) 0x00000005;                                       /* R5                                                        */
     * --cpu_context = (unsigned int) 0x00000004;                                       /* R4                                                        */
     * --cpu_context = (unsigned int) 0x00000003;                                       /* R3                                                        */
     * --cpu_context = (unsigned int) 0x00000002;                                       /* R2                                                        */
     * --cpu_context = (unsigned int) 0x00000001;                                       /* R1                                                        */
     * --cpu_context = (unsigned int) 0x00000000;                                       /* R0  ARGUMENT PASS                                                         */
     * --cpu_context = (unsigned int) variable_pass;                                    /* status regsiter                             */
        // used for the status register
		#define  ARM_SVC_MODE_THUMB    (0x0000001f + ARM_MODE_THUMB)
		#define  ARM_SVC_MODE_ARM      (0x0000001f + ARM_MODE_ARM)
     if (((unsigned int)task & 0x01) == 0x01)                   /* See if task arch_sama5d4_context_switch_starts in Thumb or ARM mode                */
        * --cpu_context = ARM_SVC_MODE_THUMB;                   /* CPSR  (Enable IRQ and FIQ interrupts, THUMB-mode)    */
        * --cpu_context = ARM_SVC_MODE_ARM;                     /* CPSR  (Enable IRQ and FIQ interrupts, ARM-mode)      */
     // floating point status register
     * --cpu_context = (unsigned int)0x00000000;	 	/* Initialise Floating point status & control register  */
     // floating point registers
    	 * --cpu_context = (unsigned int)0x00000000;	/* Initialise general-purpose Floating point registers  */
     * --cpu_context = (unsigned int)0x40000000;  	 	/* Initialise Floating-Point Exception Register (Enable)*/
