api_system_gateway could not be resolved
4 posts / 0 new
Guys, just tidying up some code.  I have the following defined in a header file called "api_gateway.h"
#define api_system_gateway()\
	volatile bool SystemConfiguration = false;\
	if( (OSTCB_EXECUTING->application_mode == false) &&\
		(OSTCB_EXECUTING->interrupt_mode   == 0)){\
			OSTCB_EXECUTING->application_mode = true;\
			SystemConfiguration = true;\
	__attribute__((cleanup(api_gateway_implementation)))volatile bool SystemStatusMode = SystemConfiguration;
when I include the header file and try to use it I get #define I get, api_gateway could not be resolved?
this is how it is called:
api_system_gateway();
Ok, before the grumbling starts....
What target is this for?  ARM or AVR.
JIm
Edit, this looks more like ARM than AVR so for now....
It's running on the UC3 and Cortex-A5
Go on. You've been here long enough to know this: Show the full error message.
Use copy & paste; post the complete and unabridged message.
There is no reference anywhere in what you posted to anything called just  "api_gateway"
