Hi All
I would like to know if someone has had similar issue to what i am experiencing.
I am using the Quectel BG95/96. The module is powered with Li-poly batter 3.7-4.2V 2000mAh.
There has been few times, when the device has locked up where it id no longer functional, to get it back to normal i need to remove the battery.
Resting the module or powering up/down the module does not work, therefore the only option is removing the battery and re inserting it.
Has anyone else experienced such issues?
I am thinking that this could be due to my battery capacity?
The modules do have a peak current of 2A, therefore i am thinking even thou the batteries can output more then 2A for short periods, there could be a possibility there could be a short voltage drop below the min requirement of the module, causing it to lock up.
Could this be possible?
What battery capacity would be recommended to use?
