Connect atmega32 by jtag
14 posts / 0 new
I split the thread but forgot where it came from. JS  blush
Hello, did you manage to connect the atmega32 by jtag? I have my atmel ice and an atmega32, I had no problems programming the microcontroller by ISP, but I couldn't debug. At the moment I am trying to connect it by JTAG but this message appears to me. What would be the problem?
That message sayes the connections are not made correctly, review and verify your jtag connections are correct.
If you can, post a picture of your setup, and your device fuse settings( is jtag enabled?).
I am a novice, how can I activate jtag without being acknowledged by the atmel ice? How do I activate fuses without the atmel ice recognizing my atmega32 by jtag? Thanks for replying.
First, check your connections. The fuse is active by default...
:: Morten
First off.    Connect via ISP  (PB5-PB7 pins).    Read the fuses.    Make sure that JTAGEN fuse is active.
Then connect via JTAG (PC2-PC5 pins).    Select JTAG interface in AS7.0.   Read Signature,  fuses, ...
JTAG debugging should work seamlessly.
Are the connections for JTAG ok ?, I will try to connect by ISP and enable JTAG
Total votes: 2
I strongly recommend that you use a proper development board with a 5x2 JTAG header.   Then your wiring will always be correct.
If you really want to use a breadboard,   make a 5x2 JTAG header from a scrap of protoboard and some male header strip.     Mark pin#1 with a spot of paint.
Buy some 100nF capacitors for the breadboard.
Random flying leads were invented by the Devil.    Avoid them like the Plague.
I tried it by ISP and if you recognize it, the JTAGEN bit was disabled, now enable the JTAGEN bit now I reread the fuses and the JTAGEN bit is already enabled.
I did the JTAG test on the move with the connection seen above, but the problem is the same.
Total votes: 2
I would expect the mega32 to connect immediately via JTAG.
If it does not connect,  toggle the power to the mega32.   Try again.
Seriously.    Wiring several random wires correctly is fraught with problems.    Which is why I suggest spending 20 minutes making a breadboard adapter.
Yes,  random wires can work.    But not as reliable as a ready-made ribbon cable with a ready-made adapter.
finally i tried the other cable from the atmel ice and it worked ..
Very good, please mark the thread as solved, Thanks!
unfortunately, he's a hijacker - not the OP - so can't mark the solution.
(yes, I've been caught on that one!)
I have split the thread, maybe it can be marked as solved now??
JS  wrote:
I split the thread but forgot where it came from. blush
Here:  https://www.avrfreaks.net/forum/atmel-ice-debugging-atmega32 ?
@ edward_yamunaque :  so now you should be able to mark the solution - see Tip #5 in my signature, below:
