Trying to import an adruino project into Atmel Studio 7 but the "fastled" code won't compile.
64 posts / 0 new
Pages
Captured the screen using the snipping tool and save it to the attached file for those who are having trouble viewing the code.
Also changed the tabs to spaces below:
extern "C" {
#  if defined(CORE_TEENSY) || defined(TEENSYDUINO)
extern volatile unsigned long timer0_millis_count;
#    define MS_COUNTER timer0_millis_count
#  elif defined(ATTINY_CORE)
extern volatile unsigned long millis_timer_millis;
#    define MS_COUNTER millis_timer_millis
#  else
extern volatile unsigned long timer0_millis;
#  endif
// special defs for the tiny environments
//#if defined(__AVR_ATmega32U2__) || defined(__AVR_ATmega16U2__) || defined(__AVR_ATmega8U2__) || defined(__AVR_AT90USB162__) || defined(__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__) || defined(__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__) || defined(__AVR_ATtiny167__) || defined(__AVR_ATtiny87__) || defined(__AVR_ATtinyX41__) || defined(__AVR_ATtiny841__) || defined(__AVR_ATtiny441__)
//#define LIB8_ATTINY 1
//#define FASTLED_NEEDS_YIELD
//#endif
//#if defined(ARDUINO) && (ARDUINO > 150) && !defined(IS_BEAN) && !defined (ARDUINO_AVR_DIGISPARK) && !defined (LIB8_TINY) && !defined (ARDUINO_AVR_LARDU_328E)
// don't need YIELD defined by the library
//#else
extern "C" void yield();
//#endif
#endif
There should be no reason to edit anything. Which CPU were you building for? I assumed Arduino Uno and hence 328p?
Sure if it compiled ok but it doesn't and yes I am using the Uno and it is the 328p. Believe me I would be happy to have this work without all this trouble.
But it compiled OK for me? Did you download the AS7 project i created? Did that build OK or not? If you "diff" it against yours what is different?
Where is this project you created to download?
Also what version of windows and Atmel studio are you using?
See #43.
David
No, don't post code as a screenshot!
Again,  instructions for doing it properly are in my signature - Tip #1.
Paul which version of Arduino are you using? It seems that 1.8.12 is broken (I downloaded it at the end of June) and at least 2 of us have proven that.
Arduino 1.8.13 FIXES things in Window 10. See https://www.avrfreaks.net/commen... and the next 2 posts.
@ paulsnop - if you did as suggested in #44 (and as clawson illustrated in #36):
in #44, I wrote:
capture & post screen shots of the process - so we can all see exactly what was done
Then it wouldn't have been necessary for js  to ask that question.
I am using 1.18.13
I did download dawson’s Project and it did compile ok.
Mine doesn’t but it is not the blinky example
I also did a diff on the fastled code and there are none
So which one was it? I could try importing that one and see if it works for me.
Pages
