I was reading Data sheet of ATXMEGA16D4 MCU( XMEGA D [MANUAL] 110
Atmel-8210G AVR XMEGA D 12/2014) and at page 110 they have said
"DIR This register sets the data direction for the individual pins of the port. If DIRn is written to one, pin n is configured as an output pin. If DIRn is written to zero, pin n is configured as an input pin."
"DIRSET This register can be used instead of a read-modify-write to set individual pins as output. Writing a one to a bit will set the corresponding bit in the DIR register. Reading this register will return the value of the DIR register.
"DIRCLR This register can be used instead of a read-modify-write to set individual pins as input. Writing a one to a bit will clear the corresponding bit in the DIR register. Reading this register will return the value of the DIR register.
These registers have diffrent address, What is the principle of association and how is it mapped? Where can I find it?
I notice that
I find some information from https://www.avrfreaks.net/forum/... ,But that is not the answer I want
