/* * nec decoder.c * * Created: 11-05-2020 20:13:54 * Author : jeet */ #define F_CPU 16000000UL #include <avr/io.h> #include <stdio.h> #include <stdbool.h> #include <avr/interrupt.h> #include "uart.c" #include "ir_nec.c" static int uart_putchar(char c, FILE *stream); static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL,_FDEV_SETUP_WRITE); static int uart_putchar(char c, FILE *stream) { if (c == '\n') uart_putchar('\r', stream); loop_until_bit_is_set(UCSR0A, UDRE0); UDR0 = c; return 0; } int main(void) { UART_Initialize(); stdout = &mystdout; IR_Initialize(); sei(); while (1) { IR_ProcessData(); if (nec_new_data == true || nec_current_status == PACKET_RECVD_N_REPEAT_RECVNG) { nec_new_data = false; printf("nec_addrh=%u nec_addrl=%u nec_cmd=%u nec_cmdinv=%u\n",nec_current_packet.addr_h,nec_current_packet.addr_l,nec_current_packet.cmd,nec_current_packet.cmd_inv); } } }
this is my main file and i have already made a post all other files can be seen at https://www.avrfreaks.net/forum/unable-splitmodularize-my-project
