ATMEGA328PB program from Atmel Studio using MPLAB Snap
4 posts / 0 new
I am trying to program the 328PB on my 328 explained mini board using the MPLAB Snap programmer instead of the Debug on the Explained. I made an adapter from the 8 pin header on the Snap to the 6 pin header on the explained mini. When I try to configure the MPLAB Snap, I get the message:
The tool is in ht PIC mode now, it should be switched to AVR mode before connecting to AVR devices. Do you which to switch to AR mode?
I click Yes.
I get Communication switch mode timeout.
I click OK
Then I get
MPLAB Snap firmware must be updated before continuing
Version 0.00 to 0.00
Upgrade it grayed out
Click close
Rinse and repeat.....
JJO
Disconnect the 6 pin cable from the target and try again.
IIRC, you must first use the snap with mplab X first, then it will work with AS7
I made the modifications suggested on various sites for the Snap to AVR. I also removed the 4 resistors on the explained boards that connect MOSI, MISO, SCK and /Reset from the Debug to the 328BP in case the Debug drivers were not being turned off. Has anybody actually gotten all of this stuff to work?
I loaded MPLAB X IDE and imported my project. It compiled and I tried to load it into the explained 328BP.
It says it has found the Snap.
Data transmission failed. Error code -10121 returned while trying to receive USB data.
A communication error with the debug tool has occurred. The tool will be reset and should re-enumerate shortly.
Connection Failed.
Launching
Could not connect to tool hardware: snap, com.microchip.mplab.mdbcore.snap.SnapToolImpl
The debugger could not be started.  Terminating debug session.
User program finished
JJO
My experience is that fresh-from-fab Snaps have to first attempt to connect to a PIC device, and then it will work with an AVR afterwards.
So make a dummy project and attempt to program a PIC.  Worth a shot.
