Pin change interrupt is unreliable with certain input signals
24 posts / 0 new
I apologize upfront if this is going to be a lengthy post.
I started on a project where I wanted my ATtiny45 to wake from deep sleep, so I played with the pin change interrupt. I sampled a switch connected to PB0 and triggered a PCI on each pin change.
My impression was that sometimes switch presses were missed. I spent a lot of time on this and now think there is some 'issue' with the change detection logic.
I stripped down the software to the bare minimum which still reproduces the effect. Here it is, it's only 13 instructions long (it's a disassembly with a few comments):
       0:       rjmp    main		; reset vector, start main()
       2:       rjmp    main		; vec_1, not used
vec2:  4:       sbi     0x16, 1		; vec_2, pin change ISR; toggle PB1...
       6:       reti				; ...and that's it
main:  8:       ldi     r24, 0x1E	; DDRB    = 1 << PB4 | 1 << PB3 | 1 << PB2 | 1 << PB1;
       a:       out     0x17, r24
       c:       sbi     0x18, 0		; activate pullup on PB0
       e:       ldi     r24, 0x20	; GIMSK   = 1 << PCIE;
      10:       out     0x3b, r24
      12:       ldi     r24, 0x01	; PCMSK   = 1 << PCINT0;
      14:       out     0x15, r24
      16:       sei			; enable interrupts
.L4:  18:       rjmp    .L4		; spin
So, it just sets up the pins plus the PCI and then spins. The ISR will toggle PB1, then return. I expect to see one (or several, if the switch bounces) toggles on PB1 for each press and release.
I'm watching the pins with a fast scope.
Oh, and I should note that the low fuse is set to 0x24, so CLK is output at pin 3, and the chip is running at 128/8 = 16kHz.
Also with this minimum program I could see switch presses/releases being lost; i.e. I could see the switch transitioning from LO to HI, with a bouncing transition period, but NO PCI ISR triggered.
Note that I could clearly see if the ISR was triggered twice. I'd say that with my setup I had a single ISR call in about 70% of cases, two ISR calls in 20%, and ZERO ISR calls in 10% of switch presses/releases.
I also noted that, for my switch, the time between bouncing peaks was irregular but in the range of about 100usecs, which is quite close to the chip's cycle time at 16kHz.
After a while all this switch pressing got annoying, so I hooked up my scope's signal generator and tried to simulate the switch. I found a pattern that reliably causes the PCI change detection logic to fail.
It is quite simple: say, the input is LOW. Then, go HIGH for half a clock period; LOW for half a clock period; then HIGH and remain HIGH.
If this signal is applied to a pin and the initial rising edge happens while the clock signal is HIGH, the whole pin change is lost; PCIF won't be set, and the ISR won't be triggered.
This is consistent with the circuit given in 9.2.2, "Pin change interrupt timing", of the ATtinyx5 datasheet. I'm not an expert here, but I tried to apply my synthetic signal to this circuit, as shown in the attached timing diagram, and would expect the pin change to be lost.
As I understand it,
- the initial latch is transparent while CLK is HIGH, and keeps the state it had on the falling edge of CLK while CLK is low
- the signal that finally ends up in PCIF is generated from the XOR of the input and pin_sync, which is a delayed version of pin_lat
- with the given timing, this XOR is always low on rising edge of CLK, so PCIF is never set.
Looking forward to all comments. However, please note that this post is not about debouncing, so an answer like 'use a timer interrupt and poll your switch, that's better' won't really help. This is about the pin change interrupt :)
You say it's not about bouncing but what happens if you activate the interrupt by a signal generated from the io of another micro so it's  guaranteed "clean".
I did not try that; however, as I wrote, I'm generating the signal with a signal generator. This input signal looks certainly 'clean', also when viewed with an analog channel on the scope.
You can see the input in the attached screenshot, labelled "PIN0" (which should be better labelled "PB0")
What is 128?  why are you running at 16KHz?
First, do your results make sense when you run at 8 MHz??  Then start lowering your clock until it doesn't make sense---you will be able to better determine the timing issue.
First, thanks for your reply!
Sorry, that was a bit short. The low fuse was 0x24, so
- clock source is the internal 128kHz oscillator
- CKDIV8 is in effect
-> resulting in a clock of 128kHz / 8 = 16kHz.
I'm running at this frequency mostly because signals in the kHz range are so much cleaner and easier to show on  the scope than signals in the MHz range.
It also makes it a lot easier to check out clawson's idea (another controller, running in the MHz range, produces the input signal for the slow controller running in the kHz range).
I just tried your suggestion - switched the low fuse to 0xa2. Now the chip is running at full 8MHz.
I adapted the input signal accordingly, for 8Mhz == 125ns clock period (steady low - high for 60ns - low for 60ns - steady high) -> same problem: if the rising edge hits when CLK is high, the pin change is missed.
Now, no switch will bounce in the 60ns range. Just for fun I tried 400ns peaks, and the pin change is detected reliably.
But, as I said, this is not so much about properly sampling a bouncing switch, it's about the pin change interrupt not firing.
I just can't believe that such a simple input makes the "pin change detection' logic fail.
OK, I think we are getting somewhere...it sounds like you are simply trying to use too narrow pulses...for the IRQ capture to work, there is some minimum (I don't have a datasheet handy)..maybe it is 2 clock cycles?    Now start increasing your pulse width until it works reliably,  that will tells us where the minimum is.
mzinner wrote:
As I understand it,
I think you've got a good grasp of what's going on. Probably a better idea than the original author of the data sheet who completely missed out any explanation of this.
BTW: Many other AVRs are identical in this regard, it's not only TINY..
The setup & hold timing of the very first block is important.   And unstated anywhere, I believe.  Let's assume it is 20ns for setup & 5 ns for hold
So the question is how soon can PCINT(0) end and still ensure pcint_syn (green) still gets generated, assuming PCINT(0) starts immediately after just barley missing a clock pulse?
Ouch, yes, you seem to have found a serious design flaw.
Normally such edge circuits use 2 FFs, but Atmel's designer assumed a latch could do (maybe he was trying to get faster response?) but you found that has a flaw, with fast-pin changes.
A workaround may to be use a RC filter, and use the Pin hysteresis, to ensure the pin cannot change at a SysCLK rate.
Maybe a parallel C is enough, combined with Pullup current, and Pin Hyst. A ballpark calc is 50u*(1/16k)/250m  = 12.5nF, so try 22nF ?
Oh, that's vital..you are saying if the pulse is wide enough, but preceded by a runt pulse during the clock high time, the whole thing is trashed anyway.  veeeeerry interesting!
They don't really encompass that here:
If edge or toggle interrupt is selected, pulses that last longer than one clock period will generate an interrupt. Shorter pulses are not guaranteed to generate an interrupt. For both types of sensing, if low level interrupt is selected, the low level must be held until the completion of the currently executing instruction to generate an interrupt.
Very curious what Microchip might have to say about this.  Someone want to ping je_ruud?
Yes, exactly.
I tried to draw it once more so the issue is more prominent.
Good news (for me, at least): things look brighter when in power-down mode. Here, the clock is OFF, and obviously some other circuitry is taking over. Then, the chip will wake up (and the pin change interrupt will fire) on the first edge, no matter what the input signal looks like.
From OP:
joeymorin:   [why  does the whole post get quoted and not the selected part?]
I'll start with how one can do a button press in less than one clock cycle?  Even at 16kHz (that's the clock, right?) that is 62us, right?
Now, isn't it a Martha Stewart "good thing" to >>not<< fire an interrupt at every glitch?  Is all this really a philosophical discussion, or a real or perceived problem?
OP has done a lot of work to track down the situation.  I wonder how it might apply to other AVR models of various generation, and to different brands/architectures.
Apologies -- a more careful re-reading shows the problem with the "lost" edge.
Perhaps the last sentence is still a good query?
The original post was talking about a 16kHz clock when the issue was first noticed.
Edit: corrected while I was typing...
David (aka frog_jr)
There is a big difference between  not picking up on a narrow pulse (hey: you need to make wider pulses), vs a narrow  & missed pulse causing a valid ,wide pulse to not be sensed.
Question (I haven't traipsed through the diagram)...what if the normal pulse is separated from the narrow pulse, instead, by several clock cycles?  I'm assuming/hoping this "lockout" is already reset, the normal pulse is detected,  & that the trouble only occurs when the two pulses are immediately adjacent.
Yes, a standalone pulse of half the clock period is - somewhat ironically - detected very well; a standalone pulse plus a 'normal' edge, not immediately following each other, results in one (or even two, if they are far enough apart) ISR calls.
It's this timing that is critical (here, as an example, a LOW->HIGH transition, HIGH->LOW should be the same):
- input is steady LOW
- input is LOW at some rising edge of clk
- input is HIGH at the next falling edge of clk
- input is LOW at the next rising edge of clk
- input is steady HIGH from then on.
Lost pin change timing
I think it was just my bad luck that I played with a 16kHz clock and my bouncing switch fulfilled these conditions often enough for me to notice :)
I'd like to repeat that I know nothing about hardware, so my explanation might well be wrong, but the effect is certainly there.
This don't sound good.
Some one (I don't have a studio7 here) should simulate the code.
If the model really is made from the code that generate the chip, it should also fail.
I always have one fast timer ISR that pull what I need.
As I remember it's 10 or 11 clk to make a ISR that check if a IO have changed (if nothing have changed), else it's only 2-3 clk slower than normal.
Did you try adding a ~22nF cap across the switch, as suggested above ?
That slows down the fast edges, so that the chip does not 'see' such rapid changes.
I don't believe it is possible to create a stim file accurate to a quarter-period of the clock.  Is it?
If a runt pulse (glitch) can block a later valid IRQ pulse, that seem rather problematic.  You'd think many would have encountered that along the way & had some discussions.  At some point, Atmel started adding "glitch" filtering to some of the later AVR series...was this an issue they spotted?
Doubtful.  The pin change logic is responsible for this newly demonstrated behaviour, whereas the filters you're referring to (generally for ICP) take as their input the output of the synchroniser for an input buffer, separate from the pin change logic.  That synchroniser is properly implemented as two FF in series but >>without<< the XOR that seems to be implicated here.
The conditions seem to be quite specific.  The runt input pulse appears to need to be out of phase w.r.t. the system clock by something in the neighbourhood of 1/4 of a system clock period, and also appears to need to be less than about 1/2 of a sytem clock period.  The actual limits of the phase and pulse length are surely a bit wider, but it does seem as though the candidate runt pulse would be rare in most real world situations.  Then again, it's possible that this has actually been observed before, but has been incorrectly diagnosed and/or unknowingly mitigated by some means e.g. RC filtering of inputs by the hardware designer ("There!  That fixed it!  That must have been the problem then!").
First, I want to thank you all for your input so far!
Not yet, and I should explain why. I'm sure that is a good suggestion that would fix it. I could, just as well, use a normal 1 MHz or 8 MHz clock as everyone else, that would also 'fix' it in a way. Or sample the switch periodically instead of relying on PCI.
I'm doing this mostly out of curiosity. I'm coming from a windows/linux application software dev background. I'm new to the embedded world, and I'm fascinated to see and watch every single clock cycle doing something.
One of my first fun projects involves a little device with a switch where you can input kind of a 'password', like a morse code, that unlocks the device. While developing this I found that my switch presses were not always detected as expected. That made me dive into the problem, until I had a stable case that showed the problem we're discussing.
And I just could not believe that something as basic as 'read in a switch' is not done 100% reliably. I wouldn't like this to work only 'most of the time'.
I don't know. As I said, I had a 'failure rate' (i.e. a switch press or a switch release not causing an ISR call) of a few percent, may up to 10 percent. I'd consider this rather fragile.
Now, noone is probably running at such low clock speeds, so the combination 'switch bounces with about clock frequency' might be unrealistic.
On the other hand,
- when going to higher frequencies inputs start to overshoot and undershoot,
- a bouncing switch or a noisy line is a very uncontrolled input, so it might happen just occasionally?
In the end, I think if there really is such a problem an application note would be nice, like 'if you want stable pin change interrupts, avoid pin changes in the vicinity of the clock frequency'.
I have not played with the tiny45 (actually 85 but don't matter) for years but here is some thoughts:
This is PCINT0 (but probably don't matter which) and OC0A is on the same pin, does this mean that PCINT0 can be triggered by a timer compare ?
If that is the case there could be a chance that the error can be made with the timer running 64MHz!
And if the simulator can run the faster PCK then perhaps.
Coupled with this data-sheet statement one could build a self-contained test-bed
Observe that, if enabled, the interrupts will trigger even if the INT0 and INT1 or PCINT23...0 pins are configured as outputs. This
feature provides a way of generating a software interrupt.
