picoboot-lib arduino protocol bootloader in 258 bytes
6 posts / 0 new
I've written a bootloader for tiny AVRs that needs only 258 bytes of flash.  It's written to be used as a library, so adding a single include to your main enables the bootloader.  This adds a call to the bootloader in .init1 before main.  If the bootloader times out, it returns and execution continues from .init2.  When the bootloader main loop is run, the arduino/stk500 quit command will jump to the reset vector.
https://github.com/nerdralph/pic...
picoboot-lib will be integrated into the next release of picoCore.
I've released v0.4, which includes automatic OSCCAL tuning and exposes picoboot-lib's UART transmit and receive functions.
I believe this is the first AVR bootloader to support fully-automatic OSCCAL tuning.
I plan to add the automatic OSCCAL tuning to the megaAVR version of picoboot as well.
Ralphd, I'm familiar with writing bootloaders to interact with the AVRospII (PC side Software), or chip to chip programming but no exp. in AVRDude to bootloader interaction.
So basically you install the bootloader, hook up serial and then selfprogram?
Nice work! Sorry for my confusion, I don't do arduino much. I use AVRDude for my USBtiny programmer but not to bootload.
It's intended for use with an Arduino core like my picoCore.  If you are not familiar with tweaking Arduino boards.txt and platform.txt files, I'd suggest waiting until it's integrated into an Arduino core.  I should have picoCore v0.4.0 released in about a week.  ATTinyCore will support picoboot-lib, though I'm not sure of the timeframe.
https://github.com/SpenceKonde/A...
I've got ( I think) the Spence/Konde ATTinyCore installed in the IDE which I would use for my t84A, t85 and t2313A  (and it does work)... if I used it much. I think for me, it's more about being able to move the serial port to different pins on the m328 or any chip... that's the appeal. The  Enable Read While Write code and some other things would need to be added if it was attempted. Are you going to include a version for the m328p or is it geared mainly for tinys? After reading a little on AVRDude, I believe it supports AVR109 and /or AVR911 app notes/protocols which is what I based my bootloaders on. So I could've been using AVRDude this whole time... LOL, live and learn. Getting info on AVRDude has been a challenge for me. I will look for the Spence/Konde update... Thanks!
The version of picoboot for the megas does autobaud and uses the hardware UART.
http://nerdralph.blogspot.com/20...
I have been thinking of doing a version similar to picoboot-lib with my soft UART code.  I'm currently working on some mcs51 stuff, but give me a week or two and I should be able to put something together.  On the megas it's easier not to use the RWW and just block for all writes.
As for avrdude, the docs suck, so I just look at the source.
