AVRco E-lab compiled file name
10 posts / 0 new
Hello
Does anyone know if it is possible to specify the compiled programs filename, e.g. if I have 3 programs defined (A,B, and C) then when I compile something where A is defined the Output file is A.hex.
Thank you in advance,
TJ
TJWahlberg wrote:
Does anyone know
Surely, the authors of this "AVRco E-lab" would know that ?
Does it not come with documentation?
Does it not have any support?
https://www.e-lab.de/kontakt.html
https://forum.e-lab.de/
Is this really Pascal for AVR? How wonderful!
Apparently so.
Nothing like starting a good language war:  https://www.e-lab.de/diverse/diverse.htm
surprise
Windows only.  Too bad.
Just heard back from the author and there is no way if renaming the .hex file automatically.
here is a bit more info...gonna blow the dust off my Turbo Pascal books,...seems like a few years ago...
https://www.e-lab.de/pdf/AVRinf_en.PDF
We won't need to worry about punters running off the end of UART buffer any more!  Indeed, how wonderful.
