AC mains optocoupler
7 posts / 0 new
I am trying to safely isolate AC mains through an optocoupler. The output is a square wave, yet want I want is a sine wave output, like the AC input. Do I need a special type of optocoupler? I'm not finding much on Google on this. Any help would be greatly appreciated.
Are you shure that what you really need is not a transformer?
Guillem.
Guillem.
I use small transformer like a BV201 http://www.hahn-trafo.com/
The key name to search is 'linear optocoupler'.
I used a device by infineon/siemens a few years back, the IL300. It is no longer in production, but it might be of interest. The chip required an op-amp feedback cct to get a linear response. Note that this device was for isolating a signal only, not tapping off power.
I would favour the transformer solution, but I do not know your requirements.
http://docs-asia.electrocomponents.com/webdocs/0028/0900766b80028881.pdf
Reduce the signal going into the LED with a larger series resistor.
Lower the gain of the transistor output by reducing the load resistor value.
But, with a simple opto, you will ONLY get every-other half-cycle. Even with the "linear" ones. If you want a full 360 degree sine, a transformer is needed.
Maybe use an AC Optpcoupler ie. H11AA1
http://www.fairchildsemi.com/ds/...
/Bingo
Btw: I was thinking about using one of these as AC optocoupler (Zero Crossing) , and maybe also as Triac driver , it has 2 functions. Would that be a god chip for that ?? , i can't seem to find the delay through the AC Opto , so i don't know if it's good for zerocrossing.
Edit: I don't think its a good choice , it seems there can be a 3 ms delay on the output fet.
http://www.clare.com/home/pdfs.n...$file/Ts117.pdf
I have used the IL300-x also in some production devices and for some apps I prefer the transformer ....
try mouser if you want to try them
http://www.mouser.com/search/ProductDetail.aspx?R=IL300virtualkey61370000virtualkey782-IL300
