Atmel Studio 7 while(1) loop does not repeat
13 posts / 0 new
int main(void) {
  // -------- Inits --------- //
  DDRB |= 0b00000011;
  //cli();
    int8_t i = 0;
        while (1)
    PORTB = 0b00000001;          /* Turn on first LED bit/pin in PORTB */
                    //_delay_ms(50);                                           /* wait */
     PORTB = 0b00000010;          /* Turn off all B pins, including LED */
                    //_delay_ms(50);
  return 0;                            /* This line is never reached */
I don't understand why in the debugger mode, it stops at the end of the while loop and never repeats. If I place a breakpoint at the start of the while loop, then it repeats, otherwise it hangs. In assembly everything works just fine.
Right click, "goto disassembly" then continue stepping. You will see:
alternating with:
and then
and this will keep repeating. So it definitely is doing the two OUTs (and then an RJMP) each time.
But, while stepping in the C code, it still hangs on the last line in the while loop, and never jumps back. Actually it repeats once, and then remains on the last line in the while loop, repeating the same instruction.
Try:
Debug / Start Debugging and Break
Debug / Windows / Disassembly
Now use F11 to step through the code shown in the disassembly window...
Edit: Apparently I was late to the party...blush
David (aka frog_jr)
Yes, it works normally in assembly. I can't understand why it's not doing the same in the C file?
Please try to do it in the C file. You will see, it will hang in that loop, and never jumps back at the beginning.
What optimization level are you using, -Og should be used for debugging!
Yup, I confirm the C steps as expected in -Og optimization.
(does kind of make you wonder why Atmel default "Debug" to -O1 not -Og in fact?)
PS in -Og build the code is:
	while (1)
  80:	81 e0       	ldi	r24, 0x01	; 1
  82:	85 b9       	out	0x05, r24	; 5
  84:	82 e0       	ldi	r24, 0x02	; 2
  86:	85 b9       	out	0x05, r24	; 5
  88:	fb cf       	rjmp	.-10     	; 0x80 <main+0x6>
so it keeps doing LDIs inside the loop. With -O1 (and above) it is:
	while (1)
  80:	91 e0       	ldi	r25, 0x01	; 1
  82:	82 e0       	ldi	r24, 0x02	; 2
	while (1)
  84:	95 b9       	out	0x05, r25	; 5
  88:	fd cf       	rjmp	.-6      	; 0x84 <main+0xa>
so the LDIs are now optimised out of the loop.
So to peek at what's going on inside costs a bit of performance. Schroedinger unfortunately lost a cat this way once !
Thank you so much Jim and to all!
Do note the penalty you pay for buying the ability to get the debugger to step it so you probably want a "better" optimization setting for the final code you plan to use.
Simply because Og came long after the other O levels, and ... well, never been a huge impetus for change (i.e it is difficult to guarantee that (wrong) code today wont break if we default from 01 to Og, if they rely on timing requirements that O1 keeps at the moment, but Og does not...)
:: Morten
I don't use -Og because of the problem already written.
I have been using nop for a long time.
Probably  ali6e7 should spend some time reading-up on compiler optimisation,  and the things that need to be borne in mind both when writing code and when debugging - as these are very common issues, not specific to AVR or GCC.
Here's a starter for ten:
https://www.avrfreaks.net/forum/tutcoptimization-and-importance-volatile-gcc
