Interruption is blocked
8 posts / 0 new
Hi
I am using atmega328P , as it shown in the attached picture
when the interruption is executed , the program doesn't turn back to the main to execute the rest of the program ?
i made 2 functions ; one to blink led in portC and the other in PORT D
the Led in PORT D (interruption) is working fine but the Led for PORT C in the main is not executed
is there a problem ??
atmega328P  is not an ARM so you are not positing in the right place. There is no "while forever" type loop in your main, that's usually a problem.
/Lars
ooops sorry this forum is about  'arm related' : can I change my post to another place ?
i added :
   portc_led();
still not working
You can't, but a Moderator can move it for you.
Please see Tip #1 (in my signature, below) for how to properly post source code & pictures.
You may need to be on the desktop site to see signatures.
It was moved by someone to the Atmel Studio (AVR-related) forum however the topic has nothing to do with Studio problems, so it's moving again to the mega and tiny forum.
You've not cleared the reason for the interruption - so my guess is that it keeps on interrupting. What does the datasheet for the mega328 say about the spi interrupts?
If you run the code in the Atmel Studio simulator, what happens?
SPIF is cleared by hardware when executing the
corresponding interrupt handling vector.
