Q on mega 0-series TWI slave protocol
5 posts / 0 new
Hi All,
I'm working on a state transition diagram for slave mode I2C software.  I've started with the read part.  See diagrams below.
Here is the question: Say the I2C master is reading 3 bytes, but the slave thinks it's only supposed to return two, what happens after the master sends the ACK for the second byte?  It seems the but is now is a deadlock.  The master is waiting for data and the slave is waiting for a stop command.   I must be missing something.  I'm asking about the "n=0/???" branch in the diagram.
here is the associated diagram from the megaAVR0 datasheet:
The slave must send something when the master clocks the data, what is sent is undefinded, but it must send something (repeat last data sent, 0x00, 0xff, ???)
Refer to the I2C doc from Phillups NXP for details of the protocol.
The slave releases the bus when the master NAK's, but until then it sends data.
Keys to wealth:
ki0bk, thank BTW
Always!
https://www.nxp.com/docs/en/user-guide/UM10204.pdf
new version w/ write loop added and "send zero" on n==0
