"recipe for target ... failed" in sample project
9 posts / 0 new
Hello everyone,
recently I bought two ATmega 1284P XPLAINED boards and decided to use Atmel Studio (7.0, downloaded a couple of days ago) for my code.
I created a new AVR GCC Executable project and selected the 1284P board for it. Naturally, to see if everything was okay, I thought I'd build
the project as-is (a "main" function with a "while (1){}" loop).
However, upon hitting "Build" (or "Build Solution") I was presented with the following error message:
------ Build started: Project: fromVideo, Configuration: Debug AVR ------
Build started.
Project "fromVideo.cproj" (default targets):
Target "PreBuildEvent" skipped, due to false condition; ('$(PreBuildEvent)'!='') was evaluated as (''!='').
Target "CoreBuild" in file "D:\Install\Uni\Atmel\7.0\Vs\Compiler.targets" from project "D:\Studium\SS20\BA\code\fromVideo\fromVideo\fromVideo.cproj" (target "Build" depends on it):
    Using "RunCompilerTask" task from assembly "D:\Install\Uni\Atmel\7.0\Extensions\Application\AvrGCC.dll".
    Task "RunCompilerTask"
        Shell Utils Path D:\Install\Uni\Atmel\7.0\shellUtils
        D:\Install\Uni\Atmel\7.0\shellUtils\make.exe all --jobs 4 --output-sync
D:\Studium\SS20\BA\code\fromVideo\fromVideo\Debug\Makefile(106,1): error: recipe for target 'fromVideo.elf' failed
        make: *** [fromVideo.elf] Error 1
    Done executing task "RunCompilerTask" -- FAILED.
Done building target "CoreBuild" in project "fromVideo.cproj" -- FAILED.
Done building project "fromVideo.cproj" -- FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
After some googling, I found that:
  • the skipped "PreBuildEvent" is most probably not the issue,
  • others have had similar problems too, but with the 6.0 version.
In particular, this post looked a lot like my problem; however, unlike the OP there, I do not have any helpful output pointing out what
could be broken.
I am running Atmel Studio on a Windows 7 machine. Building from the Windows Shell did not help either. I have also tried removing the loop
or the #include<avr/io.h> import.
Any help would be appreciated; I can also provide additional input. It is my first time using Atmel Studio, although I had programmed another
microcontroller about an year ago.
Best regards.
Suggest you remove AS7 and re-install it in the default location on C drive and see if that helps.
Or upload a zip of your project directory and see if others can duplicate your problem.
When I build, I get:
------ Build started: Project: LTX_Serial_Interface, Configuration: Debug AVR ------
Build started.
Project "********************.cppproj" (default targets):
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\7.0\Vs\Compiler.targets" from project "C:\***********************************************************************************************\********************.cppproj" (target "Build" depends on it):
	Using "RunCompilerTask" task from assembly "C:\Program Files (x86)\Atmel\Studio\7.0\7.0\Extensions\Application\AvrGCC.dll".
		Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\7.0\shellUtils
		C:\Program Files (x86)\Atmel\Studio\7.0\7.0\shellUtils\make.exe all --jobs 4 --output-sync
		Building file: .././main.cpp
		Invoking: AVR8/GNU C Compiler : 5.4.0
		"C:\Program Files (x86)\Atmel\Studio\7.0\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-g++.exe" -funsigned-char -funsigned-bitfields -DDEBUG -DF_CPU=3579500UL -D******** -D***************** -D********************  -U********************** -U************* -U**************  -I"C:\Program Files (x86)\Atmel\Studio\7.0\7.0\Packs\Atmel\ATmega_DFP\1.2.209\include"  -Og -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega328p -B "C:\Program Files (x86)\Atmel\Studio\7.0\7.0\Packs\Atmel\ATmega_DFP\1.2.209\gcc\dev\atmega328p" -c -MD -MP -MF "main.d" -MT"main.d" -MT"main.o"   -o "main.o" ".././main.cpp"
		Finished building: .././main.cpp
		Building target: ********************.elf
		Invoking: AVR8/GNU Linker : 5.4.0
But OP's output seems to be missing any attempt to actually build any files.
Are you sure you have the source file(s) included in the Project?
Possibly not the best choice, I'm afraid:
See: https://www.avrfreaks.net/commen... - and the rest of that thread.
thank you all for the tips.
I reinstalled AS7 in its default location and also created a new project with the new installation. It did indeed change the output, but the build still fails:
------ Build started: Project: AnotherTest, Configuration: Debug AVR ------
Build started.
Project "AnotherTest.cproj" (default targets):
Target "CoreBuild" in file "C:\Program Files (x86)\Atmel\Studio\7.0\Vs\Compiler.targets" from project "D:\Studium\SS20\BA\code\AnotherTest\AnotherTest\AnotherTest.cproj" (target "Build" depends on it):
    Using "RunCompilerTask" task from assembly "C:\Program Files (x86)\Atmel\Studio\7.0\Extensions\Application\AvrGCC.dll".
        Shell Utils Path C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils
        C:\Program Files (x86)\Atmel\Studio\7.0\shellUtils\make.exe all --jobs 4 --output-sync
        Invoking: AVR/GNU C Compiler : 5.4.0
        "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe"  -x c -funsigned-char -funsigned-bitfields -DDEBUG  -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\include"  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -mrelax -g2 -Wall -mmcu=atmega1284p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\gcc\dev\atmega1284p" -c -std=gnu99 -MD -MP -MF "main.d" -MT"main.d" -MT"main.o"   -o "main.o" ".././main.c"
D:\Studium\SS20\BA\code\AnotherTest\AnotherTest\Debug\Makefile(106,1): error: recipe for target 'AnotherTest.elf' failed
        make: *** [AnotherTest.elf] Error 1
Done building target "CoreBuild" in project "AnotherTest.cproj" -- FAILED.
Done building project "AnotherTest.cproj" -- FAILED.
Build FAILED.
... so I am getting the "Finished building: .././main.c" line as @awneil wrote.
Regarding the question of @awneil: Yes, my main.c is in the project and appears in the project explorer -- as shown in the image from the comment you linked.
I chose this type of boards as it was recommended by the authors of a project I'm hoping to implement.
Just out of interest what does line 106 say?
It is @echo Building target: $@ . To put it into perspective,
# All Target
all: $(OUTPUT_FILE_PATH) $(ADDITIONAL_DEPENDENCIES)
$(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS) $(OUTPUT_FILE_DEP) $(LIB_DEP) $(LINKER_SCRIPT_DEP)
    @echo Invoking: AVR/GNU Linker : 5.4.0
that is the content of the Makefile around it.
A few more lines of context are required.
Post all the lines from this target line:
down to the next line that looks like
target : dependency dependency
Or perhaps just post the whole thing if it isn't excessively long.
I think that would be
    $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS) -Wl,-Map="AnotherTest.map" -Wl,--start-group -Wl,-lm  -Wl,--end-group -Wl,--gc-sections -mrelax -mmcu=atmega1284p -B "C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\ATmega_DFP\1.3.300\gcc\dev\atmega1284p"
    @echo Finished building target: $@
    "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures  "AnotherTest.elf" "AnotherTest.hex"
    "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -j .eeprom  --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0  --no-change-warnings -O ihex "AnotherTest.elf" "AnotherTest.eep" || exit 0
    "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objdump.exe" -h -S "AnotherTest.elf" > "AnotherTest.lss"
    "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O srec -R .eeprom -R .fuse -R .lock -R .signature -R .user_signatures "AnotherTest.elf" "AnotherTest.srec"
    "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\bin\avr-size.exe" "AnotherTest.elf"
Since what comes next is just the cleanup with rm -rf.
