Xmega virtual ports---definitely use them for manipulating single bits!
28 posts / 0 new
I was surprised (or simply blissfully ignoring) how much more efficient the Xmega virtual ports are when dealing with single bits...much more code and speed efficient:
This is due to allowing the use of sbi & cbi & in & out
#define PORTA_Virt  VPORT0 // just a naming substitution for clarity
#define PORTB_Virt  VPORT1
int main(void){
//NOTE the port directions (.DIR) have not been configured, but need to be for actual usage
 PORTA_Virt.OUT |=PIN4_bm; // set a specific pin using virtual port
 PORTA.OUTSET=PIN4_bm;  // set a pin using std port (same as PORTA_Virt, if already configured as noted below)
        // this code will compile 4x longer/slower  (3x If Z already set)!!
 PORTB_Virt.OUT &= ~PIN4_bm; // reset a pin using virtual port
 PORTB.OUTCLR=PIN4_bm;  // reset a pin using std port
 // the following configurations are needed, VPorts are UNASSIGNED  upon reset....these must be placed PRIOR to making the above virtual pin changes
 PORTCFG.VPCTRLA=PORTCFG_VP0MAP_PORTA_gc|PORTCFG_VP1MAP_PORTB_gc; // assign the virtual ports A==>VP0, B==>VP1
 PORTCFG.VPCTRLB=PORTCFG_VP2MAP_PORTC_gc|PORTCFG_VP3MAP_PORTD_gc; // assign the virtual ports C==>VP2, D==>VP3
The compiled code shows a large improvement with the virtual ports:
 PORTA_Virt.OUT |=PIN4_bm; // set a specific pin using virtual port.....NICE AND QUICK
 184: 8c 9a        sbi 0x11, 4 ; 17
 186: 80 e1        ldi r24, 0x10 ; 16
 188: e0 e0        ldi r30, 0x00 ; 0
 18a: f6 e0        ldi r31, 0x06 ; 6
 18c: 85 83        std Z+5, r24 ; 0x05   .......SING A SAD DOG SONG
 18e: ac 98        cbi 0x15, 4 ; 21
 190: e0 e2        ldi r30, 0x20 ; 32
 192: f6 e0        ldi r31, 0x06 ; 6
 194: 86 83        std Z+6, r24 ; 0x06
It would be nice to have some sort of macro to allow  "virtual compatibility" (only for a single pin) with a statement such as:
PORTB_Virt.OUTCLR=PIN4_bm;    //same as PORTB_Virt.OUT &= ~PIN4_bm;
That shouldn't be impossible, I'll scratch my head on it
Of course, the standard Xmega OUTCLEAR, allows multiple bits to be simultaneously cleared, at about the same rate/length as the mega/tiny read (IN), modify (AND/OR), write (OUT) dance
But why bother if "PORTB_Virt.OUT &= ~PIN4_bm;" achieves the same thing? Why not just type that?!? After all it should become a single CBI.
Some people don't like typing I guess.
I'm wondering if the compiler would be clever enough to reduce compile time constants down to zero RAM and a single instruction. Like say you had something like
typedef struct = {
    REAL_PORT *real_port,
    VIRT_PORT *virt_port,
    uint8_t mask
    bool virtual;
} PORT_PIN_t;
const PORT_PIN_t led_pin = {NULL, &VPORT0, (1<<5), true);
static void set_pin_high(PORT_PIN_t *pin)
    if (!virtual)
        pin->real_port->OUTSET = pin->mask;
        pin->virt_port->OUT |= pin->mask;
You could probably create a load of macros to generate everything you wanted and have a nice easy "Arduino" style interface if you wanted to.
But yes, I agree with clawson, just type faster :-)
Interesting.
It's also worth noting that virtual ports can be slower in some circumstances. cbi/sbi can only act on one bit, where as the OUTSET/OUTCLR registers can operate on multiple bits.
Yeah but the compiler KNOWS that. If you write code to affect 2+ bits on any AVR that has IO in SBI/CBI range the compiler will switch to IN/<and/or>/OUT - it's still faster than it doing LD/<and/or>/ST.
On an Xmega you should always map your four most heavily used GPIO to the VPorts.
In a thread previously (several years ago) I opined the wasted opportunity in Xmega - there's some IO space that could have been used for more VPorts that is just wasted :-(
Hay, the compiler did a good job :-) With optimization at -O1 and a real port:
static inline void pin_high(const PORT_PIN_t *pin)
	if (!pin->is_virtual)
 22c:	81 e0       	ldi	r24, 0x01	; 1
 22e:	e0 e0       	ldi	r30, 0x00	; 0
 230:	f6 e0       	ldi	r31, 0x06	; 6
 232:	85 83       	std	Z+5, r24	; 0x05
And with a virtual port:
		pin->virtual_port->OUT |= pin->mask;
 22c:	88 9a       	sbi	0x11, 0	; 17
Yes, but with IN/OUT you have to do a read-modify-write, so three or four instructions (there is no immediate EOR for toggling). It's not atomic either.
It would be nice, certainly, as would virtual SET/CLR/TGL registers. I imagine the limit is in silicon though, with MUXes being somewhat expensive.
But this is nothing to do with Xmega/Vports. It's always been like this...
$ cat avr.c
int main(void) {
	PORTB |= (1 << 3);
	PORTB &= ~(1 << 5);
	PORTB |= 0xAA;
	PORTB &= ~0xAA;
$ avr-gcc -mmcu=atmega16 -Os -g avr.c -o avr.elf
$ avr-objdump -S avr.elf
   [SNIP!]
0000006c <main>:
int main(void) {
	PORTB |= (1 << 3);
  6c:	c3 9a       	sbi	0x18, 3	; 24
	PORTB &= ~(1 << 5);
  6e:	c5 98       	cbi	0x18, 5	; 24
	PORTB |= 0xAA;
  70:	88 b3       	in	r24, 0x18	; 24
  72:	8a 6a       	ori	r24, 0xAA	; 170
  74:	88 bb       	out	0x18, r24	; 24
	PORTB &= ~0xAA;
  76:	88 b3       	in	r24, 0x18	; 24
  78:	8a 7a       	andi	r24, 0x55	; 170
  7a:	88 bb       	out	0x18, r24	; 24
  7c:	08 95       	ret
0000007e <_exit>:
  7e:	f8 94       	cli
00000080 <__stop_program>:
  80:	ff cf       	rjmp	.-2      	; 0x80 <__stop_program>
That's mega16 code.
The point of this thread surely is: you can get GPIO performance on an Xmega as good as you can get on tiny/mega *IF* you map your 4 most used ports to the VPorts.
Sure, my point is that with the XMEGA ports that have OUTSET, OUTCLR and OUTTGL which occasionally can be faster if you need atomic updates, or if you want to generate a little square wave or something like that. It's a rare corner case but still...
What I don't get is why the compiler bother going through Z in the first place (when it is used as a constant that is).
This would do the same, in less cycles and in less codespace:
ldi  r24, 0x01
sts  0x0605, r24
I never bothered with virtual ports. I find outclr/outset of greater value to me, avoiding the problems with non-atomic read-modify-writes.
What I like about XMega and bit-addressing, is the gpio registers at address 0-15. They are great for boolean flags. Setting and testing bits there is fast and atomic.
It uses Z if the same (or other close) destination is accessed several times in the same function. It then saves code. Observe:
$ cat avr.c
int main(void) {
	UDR0 = 0x55;
$ avr-gcc -mmcu=atmega168 -Os -g avr.c -o avr.elf
$ avr-objdump -S avr.elf | tail -n 16
00000080 <main>:
int main(void) {
	UDR0 = 0x55;
  80:	85 e5       	ldi	r24, 0x55	; 85
  82:	80 93 c6 00 	sts	0x00C6, r24
  86:	08 95       	ret
00000088 <_exit>:
  88:	f8 94       	cli
0000008a <__stop_program>:
  8a:	ff cf       	rjmp	.-2      	; 0x8a <__stop_program>
but:
$ cat avr.c
int main(void) {
	UDR0 = 0x55;
	UDR0 = 0xAA;
	UDR0 = 0xFF;
	UDR0 = 0x00;
$ avr-objdump -S avr.elf | tail -n 22
int main(void) {
	UDR0 = 0x55;
  80:	e6 ec       	ldi	r30, 0xC6	; 198
  82:	f0 e0       	ldi	r31, 0x00	; 0
  84:	85 e5       	ldi	r24, 0x55	; 85
  86:	80 83       	st	Z, r24
	UDR0 = 0xAA;
  88:	8a ea       	ldi	r24, 0xAA	; 170
  8a:	80 83       	st	Z, r24
	UDR0 = 0xFF;
  8c:	8f ef       	ldi	r24, 0xFF	; 255
  8e:	80 83       	st	Z, r24
	UDR0 = 0x00;
  90:	10 82       	st	Z, r1
  92:	08 95       	ret
00000094 <_exit>:
  94:	f8 94       	cli
00000096 <__stop_program>:
  96:	ff cf       	rjmp	.-2      	; 0x96 <__stop_program>
Since the Atmega328 need 2 Clocks to change PIN-Output  like PINA=1 , I was dissapointet to see
ATXMEGA 16A4 need 4 Clocks like PORTA.OUTTGL=1 .
My question is what is the 2 Clockcode  for  ATXMEGA to toggle a OUTPUT-PIN ?
I thought Virtual-Ports with direkt addressing may be faster therefore I place my question here ?
There is no 2-cycle toggle for an arbitrary IO pin on the XMEGA.
You're example of PORTA.OUTTGL=1 only takes 3 cycles.
3 cycles @ 32MHz is 94ns is less than 2 cycles @ 20MHz.
So I'd say the XMEGA is still faster than the MEGA.
If you truly need 2-cycle or better pulse timing on the XMEGA start a new thread explaining what you're trying to achieved.
There are multiples tricks using optimizations & peripherals to achieve precision timings.
With Atxmega16A4 and Atxmega128a1 i measure 8Mhz with this code
PORTA.OUTTGL=1;PORTA.OUTTGL=1;PORTA.OUTTGL=1;................100xtimes
With my UNO (16Mhz Quarz)  :  PINA=1;PINA=1;PINA=1;........100xtimes
i measure 8Mhz !
How can I get the XMEGA-clock ?. It shoult be 32 Mhz with this
// Use 2Mhz internal RC with 16x PLL
  OSC.PLLCTRL = OSC_PLLSRC_RC2M_gc | 16 ;
  OSC.CTRL |= OSC_PLLEN_bm ; // enable the PLL...
  while( (OSC.STATUS & OSC_PLLRDY_bm) == 0 ){} // wait until it's stable
  // And now we can (finally) switch to the PLL as a clocksource.
  CCP = CCP_IOREG_gc;       // protected write follows
  CLK.CTRL = CLK_SCLKSEL_PLL_gc;  // The System clock is now the PLL output (2MhzRC * 16)
Surely you'd be better off mapping to the VPORTs (subject of this thread)? It will require an RMW so that nay sap some performance gained in IO space.
You can do everything in one cycle with VPORTs.  SET, CLR or TGL.
Xmega does SBI in one cycle.   Don't ask me how.   Mega takes 2 cycles.
Are you sure VPORTs support the extra SET/CLR/TGL? I thought each VPORT location only duplicated 4 of the ports base registers.
No, you don't say PORTA.OUTSET = (1<<bit)
You say VPORT1.OUT |= (1<<bit) after assigning PORTA to VPORT1
The Compiler produces an SBI instruction because VPORTs are all in IN/OUT memory.
Xmegas have got lots of PORTs.  So you have to choose the "best" ones to access with the 4 possible VPORTs.
The XTinys have only got a few PORTs so you get VPORTs automagically.
He's talking about TGL. I don't think the reduced VPORT group (certainly a subset of 4 in original Xmega) has TGL in the group. Maybe these newer ones do?
VPORT1.IN = (1<<bit) compiles as an OUT instruction.   Which is one cycle even on a Mega.
My measure was right but my interpretation was wrong.
Atmega328p  PINA needs 1 Clock
xmega PORTA.OUTTGL needs >= 2 Clocks
So my question as David wrote is , how to get 1Clock-Instruction  to get Pin-Change ?
I am looking for Xmega to get more speed with hardware application but I realize its no advantage !
Thx for answer
John
Go on.   Xmega is brilliant for GPIO.   One cycle for changing a single bit.    You can toggle 1-8 bits in one cycle with any AVR.   Since Xmega is clocked faster than a regular Mega you are always faster per cycle.
Yes,   you have to choose the best 4 PORTs to use with VPORT0-VPORT3 on an Xmega.
XTinys have VPORTA-VPORTD always available.
Xmega beats Cortex-M0 hands down.   And compares with Cortex-M3 and Cortex-M4 at faster clocks at least for external 8-bit bus e.g.8080.8 or 6800-8.
VPORT1.IN = (1<<bit)  does in-fact compile as an OUT instruction. But, it does not do anything to the IO pin. The datasheets shows VPORTx.IN as R/W which is apparently a typo. I just tested it on an 16A4U and the scope showed nothing.
The XMEGA has tremendous advantages over the MEGA. I'd say the most important are DMA, multi-level interrupts and the event system. Combining DMA with SPI you can get arbitrary signals with a resolution of 62.5ns; That's how I drive WS2812 LEDs.
As I suggested before, start a new thread describing what you're trying to achieve.
My apologies.   I had used VPORT.OUT and VPORT.DIR but VPORT.IN only for reading.   Writing to VPORT.IN does not toggle the pin.
#define F_CPU 2000000uL
#include <util/delay.h>
#define MASK (1<<4)        // wiggle PC4 pin
    PORTCFG.VPCTRLB = 0x32; //VPORT2=PORTC, VPORT3=PORTD
    VPORT2.DIR |= MASK;
    while (1)
        VPORT2.OUT |= MASK;  // 1 cycle
        VPORT2.OUT &= ~MASK; // 1 cycle
        VPORT2.OUT |= MASK;
        VPORT2.OUT |= MASK;
        asm("nop");
        VPORT2.IN = MASK;    // 1 cycle but it does not work
        VPORT2.IN = MASK;
        VPORT2.IN = MASK;
        VPORT2.IN = MASK;
        asm("nop");
        PORTC.OUTSET = MASK; // 2 cycle
        PORTC.OUTCLR = MASK;
        asm("nop");
        PORTC.OUTTGL = MASK; // 2 cycle
        asm("nop");
In practice,  you would simply read the current state of the latch with VPORT.IN and use subsequent SBI, CBI instructions.
Since SBI, CBI are 1 cycle on an Xmega there is no advantage in a 1 cycle write to the IN register.
Thx David,
now I can toggle 16Mhz with Virtual-Ports .
I dont understand your VPORT2.IN=.. , I think a read-Command is use as  x=VPORT2.IN .
I test  virtual Read with your sketch and it works
#define readpin (1<<5)        //PC5 pin  connect with MASK
while(1)  //toggle Mask-Pin till Virtual readError    (Scope-Test)
        VPORT2.OUT|= MASK;  asm("NOP"); asm("NOP");      //2 NOPS needed ! ! !
        if(VPORT2.IN & readpin) {VPORT2.OUT &=~MASK;  asm("NOP");  asm("NOP");  if(VPORT2.IN & readpin) break;} else break;
    while(1) //toggle Mask-Pin till readError    (Scope-Test)
        PORTC.OUT|= MASK;asm("NOP");   //1NOP needed
        if(PORTC.IN & readpin) {PORTC.OUT &=~MASK;asm("NOP");if(PORTC.IN & readpin) break;} else break;
Do you know reduce the NOPS with Config the  readpin :PINnCTRL – Pin n Configuration register ?
(The readpin is only connect with the MASK-Pin )
John
Yes,  an SBI / CBI will be 2 cycles.   i.e. 16MHz square wave when F_CPU = 32MHz.
But you will need to put all the statements in an unrolled loop to sustain a steady 16MHz.
You should use the hardware if you "want" 16MHz.
On a Mega or Tiny you can toggle the port pins by writing to PINC e.g. PINC = (1<<5) will toggle PC5 pin.
I assumed erroneously that VPORT2.IN would work the same way.
Yes,   you probably need a NOP before reading with VPORT2.IN after writing with VPORT2.OUT
If you want to toggle pins you generally know the initial state of the pin.
