camera for vision system
6 posts / 0 new
Hi
Has anyone here worked on the vision system? I am planning to purchase a vision camera for practice. I found that the camera depends on the size of the object (soap, human face, screw, boxes)
Would anyone suggest a good camera for practice
Thank you
Too vague. You have to specify what it is you are trying to observe and what kind of processing power you plan to attach it to.
For example "Omnivision" are a fairly big player in the CMOS sensor game. Here's just a small fraction of their product range...
https://www.ovt.com/mobile-devices/use-cases/cameras-for-super-selfies
But it really does depend on what you want to observe and in how much detail. Processing 128x128 mono pixels 5 times a second is a whole lot different to processing 1920x1080 at 30 frames per second in 24 bit colour for example!
If this is "object tracking" you then have to consider how much CPU power you require. Say you really did have 1920x1080x3bytesx30fps then you are processing 186MB of data per second (and that's before you have considered moving an object recognizer over the data). To process this in realtime will take GHz of CPU power. But if you are looking for an 8x8 rectangular object in 128x128 mono at 5fps then you might do it in a few MHz.
PS a good place to start is something like an Rpi running OpenCV (Open Computer Vision library released free to the world from Intel). You can get a lot of "pug in" cameras to add to Rpi that have the kind of resolution/bit depth/frame rate that kind of CPu can cope with.
PPS here's some cameras that might work with AVR..  https://microcontrollershop.com/default.php?cPath=301_540&osCsid=cibmcj6h2hdb9sb087niidro50
clawson wrote:
Rpi
+1
ie, "Raspberry Pi" - and its camera:
https://www.raspberrypi.org/products/camera-module-v2/
Note that they've recently introduced a "high quality" camera:
https://www.raspberrypi.org/products/raspberry-pi-high-quality-camera/
And just to see what you really need, a PC and a webcam would be a fast and easy start.
Or live stream video from your cellphone.
We need more info.
Add:
If the camera is too good you can always make the picture more course or add noise to see how little/cheap a camera you can live with. In the old day the lens gave the size.
clawson wrote:
"pug in"
Like this:?
if you crossed it with a Jack Russel, would that be a Jack Pug ... ?
laugh
