Modbus
10 posts / 0 new
Hi everybody!
Is there anybody who have implementet the modbus protocoll in codevision?
I am doing a project now and begin to run out of time, so if it is somebody who can help me with this I will be very content. It does not have to be the code, just a place who will get me started. I have never used the modbus protocoll before..
In advance, thanks
Here's a link to a modbus implementation.
http://freemodbus.berlios.de/
Thanks!
Do a search on my posts - I have posted parts of the modbus code before. I do not have access to my computer at the moment so I can't repost. Nevertheless, the code is quite straightforward - you can use the methods described on the documents from www.modbus.org
modbus is really really simple protocol and you'll have a simple system running in 4 hours.
How many different types of devices are you dealing with?
There is Modbus, and then there is Modbus. ASCII? RTU? Ethernet? Master and/or slave? Do you have control over both ends, or do you have to interact with "standard" full Modbus devices?
If you are the master and only need to do a couple simple queries, then it is indeed quite straightforward and you should find lots of examples on the 'Net. If you need to do a "full" Modbus-RTU slave that can interact with an arbitrary master, that ends up taking about half of a Mega88 in code space, so a several week job. Probably a little longer if you are not familiar with Modbus. Three things come to mind: the dead time between packets is end-of-transmission, so there is a timer involved. The checksum generation and recognition needs to be done. And the 16-bit values come in/go out big-endian, so you normally need to byte-swap everything.
Lee
theusch,
thanks for correcting me. Indeed, there might be much more complex cases involved.
Hello!
I am dealing with only 1 device, the master. My slave must understand 5 different function codes and it is a modbus rtu.
I did download the modbus implementation from http://freemodbus.berlios.de/, but when I try to make the project in CodeVision I got a lot of errors. This errors does not appear when I compile the project.
The errors appear in .asm file and say undefined symbol... What is all this about?
Likely the syntax of the assembler used isn't the same as the assembler you're using ;)
Thanks!
There was som files I had forgot to implement..
There are some trouble here. When I try to compile the demo project for avr in the http://freemodbus.berlios.de/
I still got some errors. It say implicit declaration of function eMBInint. I know what it means but I thought the demo had all the files I need to run it. Is there anbody else who have had the same troubles?
