Saturday Morning Junkbox Project - Voltage Reference.
8 posts / 0 new
I've been meaning to put this together for a while...
Other than the Adafruit LM4040 breakout it's cost me nothing as it's been 'designed' around what I had to hand. So I now have a 0.1%, low tempco, battery-powered reference for doing quick checks on scopes and multimeters.
Yes, it is an ill wind that blows no good... opportunity to catch up on that list of things I must get around to. I understand that the sale of photo albums has boomed.
Amazon.com: Hosa BNA-100 Dual Banana Connector, 2 Pieces: Musical ...
I could of plugged in my banana connector but that blasted BNC connector got in the way!  wink
Nice job Brian!
Nice, neat package.  What's on the inside?
I'm guessing it's the Adafruit LM4040 breakout, a battery and some air.
Not a lot. The Adafruit breakout board is tiny and is the only item that can't be seen from the outside.
The battery is in a compartment in the case and is a PP3.
Nice handiwork!!  Can be used in a lot of situations around your lab.
