What's the difference between EEPROM and FLASH? (besides amount)
13 posts / 0 new
I hate to sound like a noob here (nothing against noobs), but I haven't seen anything on this.  "Back in the day", yes, I could see a reason for EEPROM (vs RAM or EPROM).  But now that we have devices that can write to their own FLASH, which as far as *I* know, is indistinguishable from EEPROM, what's it's purpose these days?  Why both?
I doesn't retain it's data longer does it?  I have to jump through hoops to program either one, so I don't see a benefit there.  I don't see different voltage requirements (at least on the outside).
Are the manufactures just leaving this artifact there for compatibility?   Is it really different internally?   Or does the manufacturer make both types "FLASH" and simply call one block EEPROM?
Just curious, one of those "why do fish have nostrils...."  questions.
Just gettin' started, again....
from 328pb DS
my projects: https://github.com/epccs
Debugging is harder than programming - don’t write code you can’t debug! https://www.avrfreaks.net/forum/help-it-doesnt-work
Well, EEPROM can be written as a single byte.
If EEPROM is a separate storage area, it is harder to accidentally destroy your program, since thee EEPROM commands can only write to the EEPROM
Ok, I'll give you that one.  Endurance counts.
Your app can write eeprom, normally an executing application can not write its own flash...
:: Morten
PS - because fish breathe too.  Deplete all the oxygen in the water (e.g. an algae bloom) and all the fish die.  wink  S.
Take a look at PIC processors, it is very common
As I understand it, the way that memory cells are physically constructed is different for FLASH compared to EEPROM.
Again, as I understand it, one technology (e.g. how FLASH is constructed) is relatively hard to write. That "hard to write" feature makes the long-term reliability much higher, which is what you want for program storage. After all, you don't want the program to unexpectedly change because the chip was too hot for too long or experienced some kind of power supply "glitch".
The other technology (EEPROM) is easier to write (but not as easy as RAM). So, it is non-volatile, which means that it persists with power turned off, but not quite as good as FLASH. This makes it ideal for things like calibration constants or program "mode" settings, things that you want to stay around. On the other hand, we have seen, over the years, discussion of techniques needed to insure reliability. These have gradually become less necessary, but the longevity/reliability of EEPROM compared to FLASH is still somewhat poorer (measured in 10s of years).
As a result, a mix  of the two technologies in microcontrollers persists. Will it always? Maybe not, but that is still the way it is, right now.
Jim may be suggesting the difference between NOR and NAND. NOR being the easier to erase/write in individual cells while NAND can only be erased in pages (but is simpler/cheaper/less silicon area/transistors per cell). Not sure what the AVR technology is, I thought it was all NAND in fact?
Atmel actually started life as NAND flash memory specialists but then added micros later I believe.
edit:oops wrong thread.
theusch wrote:
the AVR's EEPROM cells are "based on floating-gate transistor technology...":
http://www.gaw.ru/pdf/Atmel/app/... App Note AVR103 and other Google hits.
Kartman wrote:
the AVR uses NOR flash
Unfortunately the entire flylogic article no longer there.
https://ioactive.com/atmega88-te...
Lee, I was looking for the same image you were, I think.
I found it via:
http://blog.sina.com.cn/s/blog_54f48a4b01009bdf.html
... about half-way down is a repost of the IOactive article, including images.
Unfortunately, the images fail to load, because they no longer exist, and instead redirect to the same boilerplate IOactive page, but a bit of help from the Wayback Machine saves the day.
These are the images related to the ATmega88 teardown:
https://web.archive.org/web/20160714155833/http://flylogic.net/chippics/atmega88/atmega88_lrg.jpg
https://web.archive.org/web/20160714221135/http://flylogic.net/chippics/atmega88/atmega88_m2_lrg.jpg
https://web.archive.org/web/20160714094722/http://flylogic.net/chippics/atmega88/atmega88c_lrg.jpg
https://web.archive.org/web/20160714135836/http://flylogic.net/chippics/atmega88/fuses1_lrg.jpg
https://web.archive.org/web/20160714130237/http://flylogic.net/chippics/atmega88/fuse2_lrg.jpg
The relevant annotated image, scaled:
At 512 bytes, the EEPROM size is 6.25% that of flash at 8,192 bytes.  If the annotation is to be trusted, the EEPROM real-estate is a bit less than 30% that of the flash real-estate, or a about 4.6 times more expensive.
So, although EEPROM and flash may be implemented as essentially the same floating gate transistor technology on the die, their difference comes down to cost.  The extra endurance possibly requires more real-estate (larger transistors?), and the fully byte-addressable logic is more complex, also occupying more real-estate.
EDIT:  I was having trouble with connectivity to the Wayback Machine when I posted this.  Seems that is ongoing.  Trouble with images not fully loading, or the page failing to load altogether.  Some persistence with F5 did/does eventually lead to happiness.  I do wonder what the issue is, though...
NAND flash was invented by Toshiba. I'm not sure Atmel made NAND flash. They definitely made NOR flash and were one of the first to have the 'special sauce' to put it on chip with micros and to do it cheaply. This made their 8051's very popular which led onto the AVR series. The rest, they say, is history.
