uart programing for receiving string.
5 posts / 0 new
 hi to all,
i want to receive the string from the user in using UART communication...i have coded the below code but in this case the length of the string should be known to me .
But what if i want to take input from user and i dont know the length of the string ..in that case how should i do.not getting any thoughts ...so any suggestions or guidance how that can be done.
#include <uarts.h>
{    char buff[30];
    UART_Init0();
    //UART_Init3();                        /* Initiate USART with 115200 baud rate */
    //UART_Init1();
 printString0("******************hellow*****************");
 printString0("\n");
                         /* Start global interrupt */
        printString0("type a character  \n");
        char b=UART_RxChar0();
        UART_TxChar0(b);
        printString0("\n");
        for(int i=0;i<10;i++)
            buff[i]=UART_RxChar0();
            UART_TxChar0(buff[i]);
        printString0(buff);
        printString0("\n");
 function defination of the uart functions which i have used in above code
void UART_Init0()
    UBRR0L = 103;
    UCSR0B = (1<<TXEN0)|(1<<RXEN0);
    UCSR0C = (1<<UCSZ00)|(1<<UCSZ01)|(1<<UPE0);
void UART_TxChar0(uint16_t data)
    while((UCSR0A & (1<<UDRE0))==0);
    UDR0 = data;
char UART_RxChar0()
{   //unsigned char status, resh, resl;
    //status = UCSR0A;
    //bit0(UCSR0A);
    //printString0("\n");
    while( !(UCSR0A & (1<<RXC0)));
    //if ( status & (1<<DOR0)|(1<<UPE0)|(1<<FE0)==1)
    //return -1;
    //bit0(UCSR0A);
    return UDR0;
char rxstring0()
    char myValue;
    while((UCSR0A & (1<<RXC0))==0);
    myValue = UART_RxChar0();
    return myValue;
void printString0(char *myString)      /////to print any string
    while (*myString)
        UART_TxChar0(*myString++);
Kunal Gupta
github.com/gkunalupta
There is an active thread here: https://www.avrfreaks.net/forum/avr-uart-string-receive-and-compare you might like to read that for some ideas.
Why not use carriage return (CR, 0x0D)  as a marker?  One you get a CR from the sender, consider that the end of your reception & take your next step(s).
So like in the string that i am getting entered by user i also get them write the \r or \n .. . Like
Writing kunal\r or kunal\n
And now make the loop and check if(buff[i] =\r or \n)
Then come out if the loop and my user eneterd string will be stored in the buff. Variable
Kunal Gupta
Yes, but instead of storing the \r or \n, store a \0,(null terminated string) then all the C string handling functions in strlib will work.
