ATTINY416-XNANO mEDBG
21 posts / 0 new
I'm back again with my problems.
I dare quote: "The onboard debugger can be completely disconnected from the ATtiny416 microcontroller and it can be used to program other UPDI devices."
Sounds good, but something is wrong.
The drop-down list contains only ATtiny416. I can change "Device" to ATtiny412 by keying, but this attempt does not lead to success, and when programming I get the error message:
"Cannot execute empty custom programming tool command. Please provide a command to execute and try again."
The truth is more important than the facts.
what is the ATpack version you are using ?
The thread title says "attiny416-xNano"
Are we saying that this is an Xnano board that claims to be 416 but has been built with a 412 (as identified by UPDI read) then ?
EDIT: now confused further. 416 datasheet says:
Yet your picture shows:
so 1E 92 23 does indeed look like it is not a 416 ?!?
Sorry, where can I find this information?
Atmel Studio 7, installed last week.
See my previous EDITs in #3 and also:
So if UPDI has read 1E 92 23 as the picture seems to indicate it does appear to have found an ATTiny412 not an ATTiny416 !
So have you done that?
But only after you have done the previous step!
EDIT
Thread from a while back on using an onboard mEDBG for off-board debugging:
https://www.avrfreaks.net/forum/low-cost-debugger-xplained-kits
ATtiny412 is identified as ATtiny412. Is it not OK?
Yes but your thread title lead me to believe you were trying to use an Attiny416 XNano. I would kind of hope an ATtiny416 Xnano might have an ATtiny416 CPU on it, not an ATtiny412. YMMV.
I remember what brought me here to freaks the first time was the issue with AS7 detecting the wrong device and it was the same problem with tiny412.
so I suspect its the same problem if you have an old AT pack.
@OP: please check this thread
You should be able to update your pack here:
if you want to do it manually, you can find the latest packs here:
http://packs.download.atmel.com/
I suspect you have an older version with the wrong device signature bug,
Yes, but I think he's trying to use it to program a separate target - which is not a '416 ?
EDIT
So, if he's still getting the signature of the 416, that could be because he's still talking to the on-board 416 - not the off-board 412 ... ?
Indeed, the title is too brief. Sorry.
It has to do with the mEDBG of the XNANO, not with the ATtiny416.
What I have to do?
poftamunk wrote:
What I have to do?
Click the [Install] button to the right of the top line. That will install Tiny pack 1.4.310
BTW when you look down that list doesn't the comment against 1.3.229 look interesting? !
(EDIT: oh, wait a minute, it's saying that is the one you currently use !)
OK.
There is still only ATtiny416 to select.
What's next?
poftamunk wrote:
What's next?
Are there any more detailed instructions in the User Guide ?
try to go in that menu in Atmel Studio :
Tools (Main Menu) -> Options ... -> Tools -> Hide Unsupported Device -> False
then you will be able to choose another device in the progamming interface, than the one initially configured in the xnano board.
Ah, yes - previously, on AVRFreaks:
https://www.avrfreaks.net/commen... - and following posts.
fgras78 wrote:
That's more like it. Now the MCU is automatically identified:
But programming doesn't succeed:
Total votes: 2
In your project, you have chosen to execute a custom command instead of using the Tool... It's under Tool in your project properties.
:: Morten
Total votes: 2
Salvation!
congrats!
