8x8 led matrix control using 74hc595 and cd4017
20 posts / 0 new
I've code shift register and decade counter to display a 8x8 led matrix. The bits seem to be off by 1 bit, e.g I expect them to go from row-1, column-1 to r-2,c-2 but the mid part, i.e. r-1,c-2 is also lighting.
 * free_lance_2.c
 * Created: 23-05-2020 11:23:32
 *  Author: Chirag Goyal
#define F_CPU 16000000UL
#include<util/delay.h>
#define reg_port PORTD
#define reg_data PD7
#define reg_clock PD1
#define reg_latch PD5
#define data_high() (reg_port|=(1<<reg_data))
#define data_low() (reg_port&=~(1<<reg_data))
#define cd_en PD2
#define cd_clk PD3
#define cd_rst PD4
#define del 1
void reg_pulse()		//to pulse the shift register
	reg_port|=(1<<reg_clock);
	reg_port&=~(1<<reg_clock);
void reg_store()		//to store the data
	reg_port|=(1<<reg_latch);
	_delay_ms(del);
	reg_port&=~(1<<reg_latch);
	_delay_ms(del);
void counter_init()
	reg_port&=~(1<<cd_en);
	reg_port&=~(1<<cd_rst);
void reg_write(unsigned char x)
	for(unsigned char i=0;i<8;i++)
		if(x&0b10000000)
			data_high();
			data_low();
		reg_pulse();
		x=x<<1;
	reg_store();
void counter()
	reg_port|=(1<<cd_clk);
	_delay_ms(del);
	reg_port&=~(1<<cd_clk);
	//_delay_ms(del);
	DDRD=0xff;
	unsigned char c[8]={0b00000000,0b11111101,0b11111011,0b11110111,0b11101111,0b11011111,0b10111111,0b00000000};
	unsigned char d[8]={0b00000000,0b11111101,0b11111011,0b11110111,0b11110111,0b11111011,0b11111101,0b00000000};
	counter_init();
        //TODO:: Please write your application code
		for(unsigned char k=0;k<48;k++)
		for(unsigned char j=0;j<8;j++)
			reg_write(c[j]);
			counter();
			//_delay_ms(1);
			reg_write(d[j]);
			counter();
			//_delay_ms(1);
In the attachments, I've printed N and M.
Chirag Goyal
Don't start new threads about the same thing please.
I think the display is scrolling and you're pausing the simulation with incomplete frames displayed.
Rather than using Q8 on the 4017 to reset the counter, explicitly reset the counter before each frame with a pulse on PD4.
I made an LED text scroll like you described.
First I bought a four unit 8x8 LED matrix like this one on eBay for about $10 USD: https://www.ebay.com/itm/MAX7219...
Each of the four PCBs has its own MAX7219 controller IC directly under the 8x8 LED matrix unit.  The four units all have their Vcc, GND, CS, and CLK lines connected together and the DataOut of each unit is connected (on the single PCB) to the DataIn of the next unit.
I use an Arduino Nano to drive the three lines that go into the MAX7219[data, CS, CLK].  I use the library "MD MAX7219"  [Mad Max]  found on GitHub.  To get this library working correctly with this 8x8x4 LED board, I had to change the display type to FC-16.   This is described in detail in the documentation written into the .h file of the library.  Now it runs the "Daft Punk" demo without problems.
Sure, this is a "cookie cutter" solution.  But I still had to spend a long time studying the library code, the MAX7219 datasheet, and any-and-all schematics that I could find on Google.   Using a standardized eBay 8x8x4 unit with a standardized Arduino library, along with needed code modifications is by far the easiest way to get a scrolling text display working.
I'm with #3 - as soon as you update the latch you then clock the counter. If this was a real circuit, you'd see ghosting. To avoid this, you have to
1. load the shift register with new data
2. turn off all columns
3. update the latch
4. select new column
5. delay
rinse and repeat.
Sorry about that. Some views and no reply made me think it was because of the community it was posted on
Chirag Goyal
I will try that. Thank you
Chirag Goyal
I get the idea of what you're saying. How to turn off all columns?
Chirag Goyal
How were you circulating columns in that project?
Chirag Goyal
I tried using the enable. But the thing is enable turns off logic, and the output still remains working. I need to stop the output of counter to do  what you are saying. Any suggestions on how to do that would be appreciated. Thank you
Chirag Goyal
I have solved the issue by turning off shift register (output data 255) and then shifting clock. Thank you guys for advice.
Chirag Goyal
connect the hc595 oe (pin 13) to the avr.
Note: this circuit wouldn't work too well in the real world - the current drive of 4000 series cmos is poor and the HC595 is only a little better. You'd be better off using the port pins of the AVR.
Here is the code for avr studio5
If you are really using Studio 5, you must watch your LED sign & exit at the next train station.  RUN, not walk away from Studio 5.   Get on the next train to Studio 7 as fast as you can & never come back.    (studio 5 had many terrible problems).
avrcandies wrote:
If you are really using Studio 5, ...
My grumpy old AVR programmer computer laptop still uses Studio 4.  (.12)  It works.  Why 'move fast and break things'?  S.
I've got 4.19 installed & still use it occasionally when I work on some older projects, or when V7 misbehaves...a good blast from the past
4.18 here as well as AS7.
Didn't 4.19 have issues?  Isn't 4.18 the better choice for the 4.x lineage?
https://www.kanda.com/blog/microcontrollers/avr-microcontrollers/avrstudio-explored/
Disclaimer:  I'm not a user
It's not working on hardware. Are you suggesting that I should connect OE to Atmega, should I connect Reset as well?
Also, is there any alternative for this so I don't have to change hardware?
Thank you
Chirag Goyal
Noted. Will look into it. I'm not facing any problems now so I'll stay on AVR studio 5 for the moment
Chirag Goyal
connecting reset won't be of any benefit to you. As you wrote, sending 0xFF to disable the segments is a perfectly valid method.
How did you come up with this bizarre hardware method anyway? Why did you not simply chain two HC595's together?
I think I was around 14 years old the last time I used a 4017! And that was with a NE555, some diodes and 74 series TTL to build a digital speedometer for my bike.
