RFID and USART atmega8
8 posts / 0 new
Hello, i'm doing a school proyect that  includes a access control with RFID. We are using SPI for comunicated the atmega 8 with it, also we are using a nextion screen with the usart. When i connect all the circuit the RFID doesn't read the tags, but when i disconnect the screen of the atmega8 and turn on the circuit the RFID read the tags and i don't know why.
We don't know why either. It could be a hardware or a software problem - or both. Since you have not shown us the hardware, we cannot comment on that. Think of how you could formulate some tests to narrow down the problem.
My first thought would be power supply. Measure this with and without the nextion attached.
these are the connections
YOu do not show what the Vcc and AVcc  or the grounds of the AVR are connected to.  I see no filter caps on the AVR either.  Also.  Nextion screens are power hungry.  What is the Main power supply capable of providing in amps/wattage?
The avcc isn't connected. Vcc and Gnd are connected in the hi link power supply. The power supply is 5v and 0.6A. I proved other program with out using the eeprom and it works, the problem is when I changed the program
Read the datasheet - avcc must be connected. You also need bypass capacitors. Ignore this and expect problems.
Your fault report didn’t say anything about changing the program or eeprom.
See here...
...this applies to ALL AVRs.
Too small.  You will want at least a 1 amp supply
