blank atmega16u2 need firmware to enumerate usb
8 posts / 0 new
Hello all,
i have 2 circuit boards with the 16u2 cpu. I used a usbTiny device connected to the cpu's SPI interface to do 1)full chip erase, 2)unlock the lock bits, 3)program the LOW, HIGH, and EXTENDED fuse bits with different values. 4)Verified the new values. Did this on both boards.
then i took one of the boards and connected direct to computer USB, verified with Device Manager, ran Arduino IDE, and programmed the chip with an Arduino bootloader. success.
But the second board will not enumerate on the computer USB. Dunno why but now i guess i need to program the chip again by SPI with the Microchip USB firmware. But i can't find that firmware.
Anybody know where to get it?
thanx, mike
ATmega16U2 - 8-bit AVR Microcontrollers
[Documents tab, bottom]
Software Libraries/Firmware
[megaAVR USB DFU bootloaders]
well the firmware that they have available doesn't seem to include the firmware for the 16u2.
the download file includes 4 different .hex files:
 at90usb128-bl-usb-1_0_1.hex
 at90usb162-bl-usb-1_0_1.hex
 at90usb64-bl-usb-1_0_1.hex
 at90usb82-bl-usb-1_0_1.hex
these are different chips with no word about which (if any) will work for the 16u2.
Are the two boards identical?
Are the two boards homemade or purchased fully assembled?
Since you have an ISP programmer, why not download a
"blink a LED" test program and see if it works.  Have the program
blink the LED once per second and time the blinks.  This will verify
that the cpu clock is running at the frequency that you think it is.
Once that works, you can explore why the USB didn't enumerate
for that board.
yes they are two of the same that i designed, ordered from OshPark and i assembled them.
Same fuse values and Xtal frequency.
And yes i'll do that tomorrow and see.....
One of the documents referenced on gchapman's link in #2.
http://ww1.microchip.com/downloads/en/Appnotes/doc8224.pdf
Title:       AVR530: Migrating from AT90USB162/82 to ATmega16U2/8U2
Date:      12/10/2016
The ATmega16U2/8U2 is a functionally identical, drop-in replacement for the AT90USB162/82.
well ok i programmed it with the ISP to blink every 60 seconds and it was spot on, then when i connected it to USB it did enumerate. Don't know why but it works now. i'll never know what was wrong.
thanx
...... oh .... i missed it
thanx i would not have found it.
