Serial Communications
23 posts / 0 new
Hi guys,
I am planning a forms based windows console application (C#) to communicate via serial coms with the UART on an ATMega. I have attached a TTL to USB interface module to the uC. When the interface module (4Dsystems) is plugged into the USB, the windows machine creates a COM port which is visible in the device manager and can be opened with serial.open() command. However, which COM port is opened is up to windows and what's available.
The problem is that the serial.open() commend expects the programmer to designate which COM port to open. Since the interface module is on the USB, I don't understand how the windows app knows which COM port has been opened.
So, the questions is: how does a windows application know which serial port to open to communicate with a new USB device?
The whole .NET C# thing is a new area for me, so please forgive my ignorance. I have googled the snot out of this without success.
This is a windows-specific question - so you'd really be a lot better off asking in a Windows developer forum.
But take a look at  SerialPort.GetPortNames:
https://docs.microsoft.com/en-us/dotnet/api/system.io.ports.serialport.getportnames?view=dotnet-plat-ext-3.1
You can use that to populate a drop-down list, so that the user can choose the required port
EDIT - something like this:
EDIT 2
It doesn't - it requires user input.
You can put the port number in the command line when you run program.exe so you dont have to hard code it in your C# program.  This is how I did it:
        string[] args = Environment.GetCommandLineArgs();
        string arg = args[1];
        serialPort1.PortName = arg;
For the best of both worlds, give the user the option to specify it on the command line or to select it in the GUI ...
Is the 4D-Systems USB Bridge this Sparkfun thing? https://www.sparkfun.com/products/15009
Sparkfun's picture does show the 4D name & logo on it:
USB UART's serial number
AN-226_Windows_Driver_Customization_for_USB_UARTs_226ANR00.pdf (MaxLinear)
[page 7]
Customized Registry
Custom Config
FixCOMPortByDevID
FixCOMPortByLocation
via Documentation tab of XR21B1420 - MaxLinear
Similar for Atmel AVRISP mkII and its clone by Waveshare.
Can I Get a Genuine Atmel AVRISP MKII? | Blog | Kanda
[fifth paragraph]
... the original Atmel AVRISP MKII has a unique serial number so that more than one programmer can be connected to a PC as AVR Studio can identify the different units using it.
Atmel AVRISP mkII Block Schematic | AVRISP mkII
WCID also has serial number though, if the USB device is on a specific port on a specific hub on a specific USB HCI, then that's another way to identify a USB device.
WCID Devices · pbatard/libwdi Wiki · GitHub
Add Microsoft WCID descriptors to Atmel's ASF USB stack · GitHub
Dont you have to be already connected to a COM port to be able to talk to the GUI?  I guess you could have a menu of COM ports to select from, but you wouldn't be able to type in the port number.
Of course not.
As shown, the GUI lets the user select one of the available ports, then connect to that
See #2.
When I talk to an avr app, I automatically scan the available ports & keep talking until I find the desired response.
So you just hit "connect"  & it does the work for you.
In some apps, while disconnected, I scan continuously so as soon as you plug in the cable it automatically connects--no need to do anything!
if these fail, there is a manual mode to force a connection to a specific port
That's really not a friendly thing to!
It can be really annoying to have an unrelated app sending unexpected, unsolicited stuff at you!
This is effectively what MS do in trying to detect serial mice - and it leads to all kinds of grief!
angry
Oh, there's only one serial comm port that actually connects to anything in these systems so you either talk to the unit or to nothing.  Granted, that might not always be the case.
The ping is only one character looking for a specific reply, so it prob wouldn't upset the cart too badly.
If you manually try selecting different ports you end up doing the same thing (are we connected yet....arrrg lets try comm 19, the other 18 did nothing).
Automation was put in place, since people wasted a lot of time trying all of the available ports.
Yeah, that's what I said.  I was thinking about typing in the COM port number, but you would have to be already connected to type it in.
Eh?
I think we're talking at cross purposes here?
Are talking about "typing" into the thing that's at the other end of the COM port link?
If your USB device has a specific, known, VID/PID see:
https://www.codeproject.com/Tips/349002/Select-a-USB-Serial-Device-via-its-VID-PID
Of course, if you have more than one of the same device, you'll still need user input to say which particular one the user wishes to use at the particular time.
OP seems to have run away. I'm still waiting to find out whether he uses Silicon Labs USB Bridge.
Let's assume he does use Silicon Labs:
The Test Technician where I work has achieved this using Labview in the application of PCB Test. For Silicon Labs CP2102 (and others in the family no doubt) Windows will allocate a new COM port number for each unique CP2102. I believe he used this feature to recognise the PCB without any UI COM Port selector. I don't know the details I'm afraid.
From the  Sparkfun & 4D pages, it seems that there are (at least) 2 versions of this thing - one uses SiLabs, the other has FTDI
Same for FTDI.
In fact, that's exactly what the image I posted in #2 is showing!
It would need user input to know which COMx is the one of interest
eg, I know that COM9: is the one I want from the list shown in #2.
EDIT
It's just like when you have multiple ICEs connected - Atmel Studio can give you a list:
But the user has to know & select which one is connected to the particular Target of interest
EDIT 2
And, like Atmel Studio, you could have the app remember your previous selection - so, if you always use the same adaptor, you don't have to keep reelecting the same one every time you start the app.
Yes.  I was thinking instead of typing the COM port number on the command line you would type the COM port number into the GUI, but you would have to already be connected to a COM port to do that.  Just me thinking in circles.  SOrry.
I think I am confused.  Never mind.
Overview | How to Find Hidden COM Ports | Adafruit Learning System
[second paragraph]
You may have noticed that every time a new FTDI-based board is plugged in, you get a new COM port. You might also get new COM port assignment with adapters, etc.
I have noticed that every time I use a new USB-serial converter I get a new COM port number.  I am up to 30 something, and I read here that it will go past 128, so there is at least one byte allocated in Windows for the port number.
As to typing the port number into the GUI, it is pretty obvious after thinking about it that the desired port number could be typed into a C# text box, and then clicking on a C# button could connect the form to the typed in COM port like a PuTTY window.  I should know better and think about things a little before reacting here and saying dumb stuff.
See #2 !
See #2 - the GUI can easily give you a list of available ones, and you just click the one you want.
I see.  I didn't follow the link to see how you get ports currently in use.  I just blundered ahead.  Thanks for method!  That makes it a good day - I learned something new.
