AtXmega128A3U - CDC library under MPLAB X
15 posts / 0 new
I am currently using Microchip MPLAB X IDE to develop my AVR projects. I'd like to add an USB-CDC support to one of them.
I was able to find some old ASF example, made with Atmel Studio 6.1. I needed to convert it AS7 to be able to import it to MPLAB X.
Importing process was finished, but code doesn't compile. It looks like some files are missing.
Is it possible do add CDC library to my project manually?
Aren't there current examples in AS7 ?
What about START ?
Maybe, but I do not use AS7. It is Windows only tool - this is why I prefer MPLAB X.
What about START ?
Do you mean https://start.atmel.com/?
It seems not to offer any USB Middlewares for AtXmega128A3U...
My point was, why not start with an AS7 project - rather than mess about trying to convert 6 to 7
I prefer MPLAB X
Note that MPLAB forums are here:
https://www.microchip.com/forums/f499.aspx
Yes, but this is a library related issue rather than IDE related issue.
Forum mentioned by you is rather devoted to PIC microcontrollers.
I simply would like to know if there is some "raw" version of CDC library for AtXmega, which I could manually add to my project. The same it can be done with FatFS library for example.
Ok, I m trying to add the first one to my project. It compiles but get two weird warnings:
</p>
<p>/tmp/ccnpK1h1.s: Assembler messages:<br />
/tmp/ccnpK1h1.s:846: Warning: Quoted section flags are deprecated, use attributes instead</p>
<p> </p>
<p>usb/usb_xmega.c: In function 'usb_ep_start_in':<br />
usb/usb_xmega.c:83:15: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]<br />
  e->DATAPTR = (unsigned) data;</p>
<p>
Any ideas?
It would help to show the code to which those lines relate.
The second one should be self-explanatory:
try googling "Wpointer-to-int-cast" for more info - see: https://www.avrfreaks.net/commen...
I can't... These are some temporary files, generated by the compiler and then quickly removed.
Will this be a sufficient solution?
e->DATAPTR = (unsigned) (volatile uint8_t *) data;
And another, more important question. I can't locate any example nor figure it out by function names. How to send and receive data via CDC, using this library?
Use -save-temps when building.
Impossible to say what would be appropriate without knowing the context.
But, as the original warning says, it is very suspicious to be trying to make something that's the wrong size for a pointer be a pointer!
you'd need to contact the author of the library for support with their library.
EDIT
The Github page does point you to an example that uses it ...
joeymorin wrote:
-save-temps
Ok, now i see it points to the main.s:
</p>
<p>.global    usb_xmega_endpoints<br />
    .section    .data,"aw",@progbits<br />
.p2align 1;,bss<br />
    .type    usb_xmega_endpoints, @object<br />
    .size    usb_xmega_endpoints, 16</p>
<p>
So it looks like the following define in usb_xmega.h is causing the problem.
</p>
<p>#define GCC_FORCE_ALIGN_2  __attribute__((section (".data,\"aw\",@progbits\n.p2align 1;")))</p>
<p>
How should I modify it?
Are you using [ code ] tags by any chance. As you can see they don't work correctly on this forum, use <> on the toolbar.
As for forcing alignment, there's a data attribute for that.
Thanks. I didn't notice that.
Do you mean something like that?
#define GCC_FORCE_ALIGN_2  __attribute__((data))
Unfortunately, this ends up with:
main.c:24:1: warning: 'data' attribute directive ignored [-Wattributes]
No, read the manual about "function attributes" and "data attributes". There is an attribute you can apply to data objects to force their alignment.
EDIT relevant manual page...
https://gcc.gnu.org/onlinedocs/gcc/Common-Variable-Attributes.html#Common-Variable-Attributes
