Atmega328p
13 posts / 0 new
Hi there
I am using 2 Arduino nano boards and want to implement full duplex data transfer between them..by using GPIO pins. Both devices can send or receive data. See diagram. Let the initial I/O configuration be clk - output, tx- output, rx- output.
Scenario- when device 1 wants to send data to device 2 on tx pin, then the tx pin of device 2 should be configured to input.
Now during program execution, if I change the configuration of tx pin of device 2 to input, it does not receive data from device 1.
How to correct this?
There are available protocols that can be used for this but I was just trying to do something own d different.
Helps if you put the image in the post - where we can see it:
So why not just use SPI? or the USART in sync mode?
Why do you need to be changing the direction of pins? why not just keep 1 line for device1 --> device2, and 1 line for device2 --> device1 ?
Which is how both SPI and USART do it!
EDIT
Like this:
So:
  • "Tx" is always device1 --> device2
  • "Rx" is always device2 --> device1
(but then you should probably choose better names)
seemam wrote:
...to implement full duplex data transfer between them by using GPIO pins...Now during program execution, if I change the configuration of tx pin of device 2 to input,
That's not full duplex.
In full duplex each device has a dedicated input (RX) pin and a dedicated output pin (TX). And in use you simply cross-connect them.
Ok...it's like I want to write data transfer code d make my own circuit using gpio pins.
There can be more than 2 devices...multi master multi slave configuration.
before re-inventing the wheel, it's good to have a solid understanding of how existing wheels work, and how they have addressed the common problems that wheels encounter ...
you will also have to change the direction of the pin at device 1.
and you have to change the functions associated with those pins.
how do you know which one of them is not working? or that more than one thing is not working ... ?
Just look at "bit bang SPI", "bit bang I2C", "bit bang UART". Each of those is simply making 0/1 transitions on general IO pins to make the desired kind of connection.
seemam wrote:
...using gpio pins...multi master multi slave...
clawson wrote:
Just look at "bit bang SPI", "bit bang I2C", "bit bang UART"...
Bit bang LIN might work better for multi-master multi-slave.
There are available protocols that can be used for this but I was just trying to do something own [an]d different.
Well if you want to do it using your own method...why aren't you?
Thanks a lot...browsing along for bit bang gave a lot of insight
๐Ÿ‘Ž๐Ÿ‘Ž
Well, the protocol was 'different' in that the common ones actually work. The 'must work' requirement got added after implementation.
Thanks for your suggestions...I am able to send and receive 8 data bits
