ATMEL ICE Intermittently Functional
15 posts / 0 new
Hi All,
I am having an issue with Atmel Studio 7.0 recognizing my Atmel Ice reliably. Sometime when I reboot Atmel Studio 7.0 my Atmel Ice shows up but only briefly before it disappears.
I have tried many suggestions from this form from over the years.
  • Uninstalling Atmel Studio 7.0 and related drivers and files. Removing registry settings for Atmel as well.
  • Updating the device firmware
  • Using Zadig to install different drivers
  • Use over 5 different USB cables (which work with other USB Data based devices) and different USB ports on my desktop
  • Using atfw in CMD to update the programmer
  • Random Others (Anything that seemed like it would work)
I am using Windows 10 and I am trying to connect to any target I have avaliable. ATTINY85/ATTINY85/ATMEGA32U4/ATMEGA16U4. No target change helps.
I submitted a case with Atmel but with not support so far.
Below is my device manager. I am hoping I am missing something obvious but this issue is gating my development.
-Hardware Engineer by day, Hardware by night.
Is it just disappearing from AS, or also disappearing from Device Manager ?
It always shows up in device manager, but doesn't show up in AS.
Is it detected if you use
atprogram list
at the command prompt?
https://community.atmel.com/comm...
There's a similar thread going on in the ARM section:
https://community.atmel.com/forum/samd11xplained-pro-not-showing-edbg-programmign-tool-atmel-studio-7-backend-agent-crashes-when
Various people seem to have found that disabling some or all of  the "other features" of the Atmel-ICE may help ...
I just tried that and it just shows "working.."
I have used atfw and gotten the device sometimes.
I also get this quite a bit when the backendagent seems to be trying to connect.
This showed up after a while. 5+ minutes of running. AS not showing anything.
Hmmm ... the other thread is also talking about "backend agent" ...
I looked at that thread but didn't get any results from disabling either the gateway or CMSIS device in device manager. Is there something I am missing? Is there a driver to install or switch over to?
I guess there must be something.
I just noted those as things others have said helped them.
I am out of ideas.
Hi Awneil,
Thanks for the help! This issue has been plaguing me for awhile. Would you know anyone at ATMEL that could help, or someone in the community?
MakeBuildMake
If you're a professional user, do you have FAE support? Or try your distributor?
Is there a way to "bump" your support case?
Perhaps try Twitter ...
I will try some industry contacts I have, thanks for the suggestions!
I feel Twitter is a nice customer support venue, but I never use it. Maybe it is time!
Is there a driver to install ...
occasionally a re-install
... or switch over to?
No (WinUSB in late model Atmel Studio 7)
P.S.
What version of Atmel Studio?
What build of Windows 10? (winver)
Reason : USB in Windows 10 does undergo change
How do I get my Tool to be recognized by Atmel Studio? | Atmel Studio 7
Another Win_10 rant of frustration-part 2 | Page 3 | AVR Freaks
or, for increased scope of visibility : Recovery options in Windows 10
Total votes: 3
RESOLVED! My K70 Corsair Keyboard has an ATMEL chip in it. It wouldn't allow my ICE to function properly. Need a new keyboard just for the ICE now though.
