AVR & REAL TIME SIMULATION FAILED TO START ERROR
6 posts / 0 new
#include<GSM.h>
int BUTTON1 = 4;   //water sensor
int BUTTON2 = 2;  //light sensor
int BUTTON3= 6;    //ultrasonic sensor
int GREEN = 10;   // vibration motor
int YELLOW = 12;
int BUZ = 7;
int GSM = 0;
void setup()
pinMode(BUTTON1,INPUT);
pinMode(BUTTON2,INPUT);
pinMode(BUTTON3,INPUT);
pinMode(GSM,OUTPUT);
pinMode(YELLOW,OUTPUT);
pinMode(BUZ,OUTPUT);
Serial.begin(9600);
void loop()
if(GSM == HIGH)
      sendsms();
      delay(2000);
if(digitalRead(BUTTON1) == HIGH) //WATER SENSOR DETECTS WATERY OBSTACLE
digitalWrite(GREEN,1);           //VIBRATOR VIBRATES
digitalWrite(BUZ,1);             //BUZZER MAKE SOUNDS
digitalWrite(GSM,1);             //GSM SEND OUT TEXT MESSAGE
digitalWrite(GREEN,0);
digitalWrite(BUZ,0);
digitalWrite(GSM,0);
if(digitalRead(BUTTON2) == HIGH)
digitalWrite(YELLOW,1);   //LED lights up to make people aware about the presence of blind people in dark place
digitalWrite(YELLOW,0);
if(digitalRead(BUTTON3) == HIGH)
void sendsms()
  Serial.println("AT\r");
  delay(1000);
  Serial.println("AT+CMGF=1\r");
  delay(1000);
  Serial.println("AT+CMGS=\"XXXXXXXXXX\"\r");
  delay(1000);
  Serial.println("Facing Obstacle!!");
  delay(1000);
  Serial.println((char)26);
  delay(100);
anyone knows what is the problem in the code? the code can be compiled but after i insert the code into proteus, there are AVR and REAL TIME SIMULATION FAILED TO START.. thankyou :)
mnmnisaghost
Could it be complaining about the lack of indentation? ;-)
Seriously, the code is almost impossible to read/follow without it.
Proteus! Do we look like labcenter support?
What do THEY say about your error, you paid for the support, why are you not using it?
Proteus support:
i see, thankyou for the help blush
mnmnisaghost
thankyouu
mnmnisaghost
