ATTINY416-XNANO Pullup
8 posts / 0 new
Dear Valued Members,
for some tasks I need small MCUs, and the tinyAVR® 1-Series seems to be quite suitable.
But unexpected a curious occurrence: after going to sleep the pullup is disconnected (detected with a multimeter).
Narrowed code example
(after button pressed und released 5x blink and go to sleep again):
ATTINY416-XNANO
LED = PB5, active LOW
Button = PB4, pressed = GND
#define F_CPU 3333333				// 20MHz/6
#include <util/delay.h>
#include <avr/interrupt.h>
#include <avr/sleep.h>
uint8_t count = 0;				// cycle count
ISR(PORTB_PORT_vect) {
  PORTB.INTFLAGS = PORT_INT4_bm;		// clear the interrupt flag
int main( void )
  PORTB.PIN4CTRL = PORT_PULLUPEN_bm;		// PB4 pullup
  PORTB.OUTSET = PIN5_bm;			// PB5 HIGH, LED off
  PORTB.DIRSET = PIN5_bm;			// PB5 as output
  SLPCTRL.CTRLA = SLPCTRL_SMODE_PDOWN_gc;	// select Power-Down sleep mode
  sei();					// enable global interrupts
  while(1){
    while(!(PORTB.IN & PIN4_bm)) {}		// wait while button pressed (LOW)
    PORTB.OUTCLR = PIN5_bm;			// PB5 LOW, LED on
    _delay_ms(100);
    _delay_ms(400);
    count++;
    if(count == 5) {
      count = 0;
      PORTB.DIRCLR = PIN5_bm;			// PB5 turned input
      PORTB.PIN4CTRL = PORT_ISC_LEVEL_gc;	// LOW level interrupt on PB4
      sleep_mode();
      PORTB.PIN4CTRL = PORT_ISC_INTDISABLE_gc;	// disable interrupt on PB4
      PORTB.DIRSET = PIN5_bm;			// PB5 turned output
Does anybody have an ATTINY416-XNANO? Please find out my code error.
The truth is more important than the facts.
Doesn't this line turn off your pull-up?
Obviously. And what would be the correct code?
Well, since you want to 'add' in the bits needed for pull-up and interrupt you want something like...
PORTB.PIN4CTRL = PORT_PULLUPEN_bm | PORT_ISC_LEVEL_gc;		// PB4 pullup and LOW level interrupt on PB4
So you are 'or-ing' the bits together.
Something that would enable the low-level interrupt and the pullup
ie, set bits 3, 2, and 0
Thank you so much! The problem is solved. The PULLUPEN Bit must be confirmed again and again.
sleep_mode();
PORTB.PIN4CTRL = PORT_PULLUPEN_bm | PORT_ISC_INTDISABLE_gc;	// PB4 pullup and disable interrupt on PB4
But it is not very convenient. If I may mention it.
Time to look into the |= operator,  then ... ?
https://www.avrfreaks.net/forum/tut-c-bit-manipulation-aka-programming-101
Since PORT_ISC_INTDISABLE_gc = (0x00<<0), ORing anything with 0 has no effect.
Of course the compiler will just treat it as
David
