Split from: Starting with AVR
18 posts / 0 new
New to the ATmega 1284P Xplained.  I watched the video "getting started with mega 1284P" and it looks like he is programming the atmega board directly from his laptop to the board through a USB cable using AVROSP.  Or is there a programmer like the AVR ISP mkII programmer mentioned here that is not being shown in the video?
howdyrichard
The Xplained boards have a built in programmer/debugger, one of the nice things about the xplained products.
Note that you're replying to an 8 year old thread!
This:  https://www.microchip.com/DevelopmentTools/ProductDetails/ATMEGA1284P-XPLD
which says:
The MEGA-1284P Xplained contains ... a UART-to-USB bridge.
and:
Program the kit via bootloader or a Microchip programmer
Not the plain old XPlained - you need the Pro, Mini, or Nano for that
As noted above, this one just has a bootloader
EDIT
https://www.microchip.com/development-tools/xplained-boards
OK, then I do need a programmer for this board (it's the plain one) and use the JTAG connection?
howdyrichard
If it is indeed an actual XPLAIN board you do not need anything else.
JIm
EDIT:
OOPS!  This beast is a different animal for debugging.
I checked out the product page and it's summary says:
The MEGA-1284P Xplained evaluation kit is a hardware platform for evaluating the ATmega1284P microcontrollers. The MEGA-1284P Xplained contains one QTouch button sensor, three mechanical buttons, four LEDs, three analog sensors, and a UART-to-USB bridge. The AVR Xplained expansion headers provide easy access to analog and digital I/O pins. The board is powered by the use of a USB cable and equipped with the standard 10-pin JTAG header that connects to the full range of AVR debuggers.
So this xplained board needs an external debugger/programmer!  bummer!
Thank you awneil.  I am aware that I am Johnny come late, it just looked like a board that I could use for a project and following that video, the board will not program with AVROSP.  So now I have Studio 7 and I will try with it.  But even in these threads there seems to be a difference of opinion.  Someone said that what Xplained boards are for, direct programming through USB, then another says it has to be the Pro version for that.  Just to be clear, I bought the board from Mouser for about $32 and it is an ATMEL ATmega_1284P_Xplained.  I have spent too much time on not so clear information.
I did buy from Amazon this:  Aoicrie 51 AVR ATMEGA8 Programmer USBasp USB ISP 10 Pin Adapter Board ATMEGA128 USB ASP Microcontroller Programmer 3.3V/5V with Download Cable , a Chinese knock off and maybe that will work.  Otherwise I should have a quality programmer if I am going to continue with these projects.
Thanks all...
howdyrichard
That's OK, as long as I know.  I think I'll make a more accurate video when I figure this out so beginners like me can start right away without the enormous task I have gone through.  I will be an expert on it!
Thanks again!
howdyrichard
The USBasp is a nice and cheap ISP programmer, it can not do debugging.  Debuggers tend to be more expensive, but not much more, pickit4, MicroChip snap, or atmel ice are debuggers, there are 3rd party ones too.
You will need to set up AS7 to use it via an external command, those here with AS7 experience can guide you how to do that.
Arduino's are AVR too, and that is another route.
Welcome to AVRFreaks if that has not already been done!
Thanks Jim, good to be here.  I'll look into those debuggers you mentioned but I did go ahead and get this:
Programmers - Processor Based Atmel AVRISP STK500 USB ISP Programmer
I see STK500 all over the place in these Studio's.
howdyrichard
I didn't know those oldie's were still available, that is still only a programmer.
Here's a bit of a radical idea. One could give in and read the user manual...
So, yeah, it doesn't have a debugger and it doesn't have an ISP programmer so if you want to do either of those operations you need something external like a USBAsp or one of the many gadgets mentioned in AVR370 but you don't NEED any of those things. All you need is a USB cable and a copy of avrosp.
So out of all the foregoing I would investigate a little deeper into:
What does "will not program" in this context actually mean? Did you read the part of AVR370 where it said you would need a .INF file for Windows so it would recognise the USB bridge? The place I found AVR370 was:
https://www.microchip.com/wwwAppNotes/AppNotes.aspx?appnote=en591062
That page not only has the PDF icon that leads to the PDF I quoted but it has the ZIP icon that leads to a .ZIP file that contains some "useful stuff". Among that is a .INF file that should make the USB bridge visible so that AVROSP can "see" it. AVROSP itself is here:
https://www.microchip.com/wwwAppNotes/AppNotes.aspx?appnote=en591218
(to be honest., for an easy life I'd be tempted to spend the $10 or whatever it is and get one of the other Xplained Pro/Xplained Mini boards that DOES have a programmer\debugger built in)
Absolutely!
Total votes: 2
Whilst the 1284 is a good chip, and was my 'goto' chip in 40/44 pins, I'd now be inclined to use something like the mega4809, which is still available in DIP40, but with the added bonus of the 4809 Curiosity Nano with on-board debugger.
Thank you for that because I was just about to post the same thing.  I have been looking at that for weeks and it will not program with AVROSP.  It's what the "Getting started" video is about, and with with the exact same Xplained board.  It gets almost there and acts like the board is not reset properly with SW0 and reset.  I will try again tomorrow; but do you guys see all the frigging confusion here.  This should not be this complicated!  I have no problem with Arduino but this mega stuff is really poor.  I think I should scrap all this and start with some different up-to-date board.
Thanks!  I thought I was losing my mind, maybe tomorrow!
howdyrichard
That's why things have moved on, and they now have the Pro / Mini / Nano versions with the onboard debugger/programmer.
This is how things were 10 years ago!
Look at the docs and you'll that they're from a time when Win-XP was current, and Win-7 was new !
Yes - you should! That'd be the Pro / Mini / Nano - See #13 (and #14)
Well, I pulled out a Dell laptop with XP and was able to program it in about 20 minutes!  So there ya go, whoever said these were from the XP days, thank you!  Not sure if I want waste time on becoming any more of an expert on this oldie...
howdyrichard
