Please help me with stepper motor
15 posts / 0 new
I tried to control the direction of the stepper motor by using switch like if switch ON stepper motor will rotate clockwise and if switch OFF stepper motor will rotate anticlockwise.
I tried to write the code, please help me and correct the code according to the circuit.
please help me I will be thankful
#define F_CPU 8000000UL
#include <util/delay.h>
    int period;
    DDRC = 0x0F;
    DDRA = 0x00;
    period = 100;
    while (1)
        m=PINA;
        if (m==0x01)
        for(int i=0;i<12;i++)
            PORTC = 0x09;
            _delay_ms(period);
            PORTC = 0x08;
            _delay_ms(period);
            PORTC = 0x0C;
            _delay_ms(period);
            PORTC = 0x04;
            _delay_ms(period);
            PORTC = 0x06;
            _delay_ms(period);
            PORTC = 0x02;
            _delay_ms(period);
            PORTC = 0x03;
            _delay_ms(period);
            PORTC = 0x01;
            _delay_ms(period);
        else if (m==0x00)
            PORTC = 0x01;
            _delay_ms(period);
            PORTC = 0x03;
            _delay_ms(period);
            PORTC = 0x02;
            _delay_ms(period);
            PORTC = 0x06;
            _delay_ms(period);
            PORTC = 0x04;
            _delay_ms(period);
            PORTC = 0x0C;
            _delay_ms(period);
            PORTC = 0x08;
            _delay_ms(period);
            PORTC = 0x09;
            _delay_ms(period);
        PORTC = 0x09;
        _delay_ms(period);
        _delay_ms(1000);
Without knowing...
1) The connections to your motor and
2) The drive waveform you expect
...it is impossible to give an answer.
Uhhhh...the ULN2003 connects 7 different outputs to ground!
How are you expecting to drive the motor when it has no source of voltage?
At least in your code use names for your bit patterns coil1, coil23, coil89, whatever,  to show what coils your are activating.  That is MUCH clearer than 0x06 !!
  DDRC = 0x0F;        /* Make PORTD lower pins as output */
    DDRA = 0x00;        /* Make PORTC lower pins as input */
your comment names don't match the port names!
Mr  Brian Fairchild  the connections are right and the circuit is running but I found difficulties in the code not in the circuit
The simple answer is : you invert the output to one of the coils the motor will change direction.
But in real life you want to ramp down to 0 and then ramp up in the other direction.
before writing any code, did you spend time studying how stepper motors work, and looking at examples of how to drive them from microcontrollers ?
http://homepage.divms.uiowa.edu/~jones/step/
https://www.google.com/search?q=arduino+stepper+motor
https://www.google.com/search?q=AVR+stepper+motor
Your schematic looks like Proteus, so see: https://www.avrfreaks.net/commen...
See Tip #1 (in my signature, below) for how to properly post source code:
So what "difficulties", exactly, did you find?
And what have you tried to resolve them ?
It's not like there's a shortage of prior art here ...
Dear mr.awneil
did you spend time to understand the question before putting a comment
It's ok that you do not know how to correct it and you do not have any idea
I'd suggest you be a bit more respectful.
 m=PINA;
  if (m==0x01)
You assume the other pins in PORTA are going to be 0. Unfortunately in the real world that won't hsppen unless you do something specific to make that true.
What you probably want is:
if (PINA & 1)
Have you read the documentation for _delay_ms()? I think it might tell you it doesn't like a variable time value - it wants a constant.
If you are seriously putting AC (Alternating Current?!) into the center taps of your stepper motor windings, it's a miracle you haven't had a cheerful 'boom!' yet.
COM on the ULN2003 should be taken to Ground, and the center taps of the stepper motor windings to 5V DC.
  S.
In the real world this:
would not work at all due to the missing power for half of your AVR provided by the AVCC pin, I would also want a 100nf cap connected between AREF and GND!
intelmen wrote:
Dear mr.awneil
disrespectful comments like that will get you no where, You are asking for help, Andy asked you clarification questions which you ignored.
Good luck with your project!
On these parts, COM usually refers to 'common free wheeling diodes' and would be connected to the load Vcc ie. it's the connection point for the in built protection diodes in parallel with the load
GND would be connected to ground :)
But the OP's schemtaic doesn't show GND pin (pin 8)
Need to have a more detail view for showing the motor and the power source for it.  The ULN2003 only provides grounding.
With just a few modifications your code will be better than ever.
Remember, every bit is important!
You still haven't told us what is wrong with your code.
Correct.  My bad.  S.
