ejecting Atmel ICE
12 posts / 0 new
I have been just unplugging USB from my Atmel ICE, but I noticed in Windows 7 I have the option to eject it before unplugging.  Does anyone have an opinion about ejecting before unplugging?  I thought ejecting was mainly so files got closed properly before unplugging USB.
I simply unplug it.
Pull the plug and move on with life.
That probably has to do with the Data Gateway side of Atmel-ICE, not the programmer side of it. The programmer is an HID device. There is no need to eject it. And I guess there is probably no way to eject it even if you wanted to.
Surprised that you see this with an Atmel-ICE... Some of the xpro boards have MSD support which would be 'ejectable', but ... HID or DGI should not be .. As you said ejecting mainly means a fs sync to ensure that all write caches are written down....
:: Morten
Dunno if it's related, but my USB-ICE has a nasty habit of losing its mind under certain circumstances - namely, losing USB power (PC shutting down) before losing power on the target board.  It usually wakes up in 'Must update flash' mode (r/g blinking LED) when that happens.  It's not that hard to update, but you have to take it apart, put in a jumper, update the flash, pull the jumper out again, and put it back together again, all while power-cycling everything.   Not much fun, really.  S.
Win 7 sees the device as an Atmel ICE and gives me the option to eject it, and when I do it tells me it is safe to remove.  Win 7 also gives me the option to eject the spectrometer I use, but file saves are done in the GUI, so it seems to be the same deal.  Win 7 recognizes USB devices and gives the option to eject, I guess.  I will just ignore it all and unplug happily.
MarkThomas wrote:
Win 7 ... gives me the option to eject it,
Where ?
I've never seen it and, hence, never use it!
Well, Atmel-ICE is a composite device. On my Win 7 it shows in the device manager as two things:
1) Atmel-ICE Data Gateway under Atmel
2) HID-compliant device under Human Interface Devices
Yes, my Win 7 also give me an option to eject it ("Eject Atmel-ICE CMSIS DAP"). So, my guess was that that option had to do with the Data Gateway.
awneil wrote:
Where ?
In the lower right hand corner of the task bar there is a little up arrow that when you hover over it it says "Show hidden icons", and if you click on it the hidden icons come up and one of them is eject the device it has detected.
well so it does!
Never noticed that before!
But if I go to 'Devices and Printers' there's a load of other things with it - including 2 other debuggers:
and none of them gets an 'Eject' option ...
While I have never ejected an AtmelICE, I have launched one or two on occasion.....angry
jim
