ATMEL STUDIO 7.0 cant enter programming mode
9 posts / 0 new
I just started to use Atmel Studio with Atmel ICE. I try to connect, the interface can read my Atmel ICE and I connect it to my board with ISP interface with my target AVR is ATTiny1634. I power the target with 5V and ground from Arduino board.
When I read the Device Signature, it show 0x1E9412 and dont have error.  But when I try to read the fuses, lock bits, and memories program, the error of unexpected signature (0x00000102) came out. I attached the error screen captures.  Can someone tell me what is going on and how to resolve this issue.
I have the same issue with my ICE and XMega-A3BU using the PDI interface ..
Another board I have based on the atXmega192A3U-AU has no issues ..
Misread signatures often indicates the programmer to chip wiring has a problem.
Presumably for the 192a3u it was hoping to see 1E 97 44? What did it actually read? Does it just look like noise or was it a number similar to this? (for example if it expected 1E 97 44 but actually read 1E 97 42 it would simply mean you actually has a 128a3u not a 192a3u etc but if it as F7 3B 29 or something that is just a wiring/reading problem - at the very least all Atmel AVR will start 1E (code for "Atmel")).
could also be a speed issue...
Are these new chips, or have they been programmed before?
Oh and the usual question: what is powering the AVR? (don't answer "Atmel ICE"!!)
Found the culprit ...
The XMega-A3BU is an Xplained board .. which by default is set to JTAG.
In order to use PDI you must either:
1) Disable JTAG in the device
2) Cut a small strip on the back of the board to force PDI ..
I have done the latter and it works flawlessly now. JTAG can be re-enabled by simple soldering the link again ..
And the AVR is powered via USB ;-)
I have resolved this issue.
Thanks for feeding back.
Please mark the solution - see Tip #5 in my signature, below:
