Setting GIMSK PCIE bit to 1 vs calling sei function.
9 posts / 0 new
I found some code like this somewhere and was curious what the difference was between setting the GIMSK PCIE bit to 1 and calling sei function. Thanks :)
void setup()
    GIMSK = 0b00100000;    // turns on pin change interrupts
    PCMSK = 0b00010011;    // turn on interrupts on pins PB0, PB1, & PB4
    sei();                 // enables interrupts
sei();
Is not a function but a defined macro that execute the asm instruction sei
sparrow2 wrote:
sei();
Ah okay. I think I found the answer. I believe sei enables all interrupts, while the GIMSK PCIE bit enables specifically pin change interrupts, so calling sei is probably not necessary if you're just wanting pin change interrupts.
There are a number of interrupt sources, each with their own enable bit. Then there's the global interrupt enable - this is set/reset by sei/cli. So both are required to be set in order for the interrupt system to operate.
No sei enable interrupts, if not set no interrupts will be executed.
Okay I see now. Thank you.
But - caveat: it's been a while since I played with deep and dirty AVR code - I seem to recall that there is a (sort of) use case for setting individual interrupts without the global interrupt being set.
In this case, if the interrupt event occurs, the interrupt flag will be set. A polling program - it may have tight timing requirements that can't be interrupted - can then tell after the event that an asynchronous something has occured.
Equally, one might disable the overall interrupt for a sensitive bit of code while leaving individual interrupts enabled: when the main interrupt is reenabled, anything that was pending will trigger interrupts in priority order.
Neil
barnacle wrote:
I seem to recall
I think you have the mechanism mixed up a bit.  In general the event flags (...IF generally) on an AVR8 will be set when the event occurs, regardless of the setting of the enable flag (...IE generally) or the state of the global interrupt enable bit.  So the fact that you might be polling SPI completion or ADIF is not directly related to whether you are using interrupts for pin-change or other.
Quite feasibly. In which case, queueing interrupt around sensitive code remains the use case.
Neil
