can anyone suggest the 8 PORT(1G) 2SFP(1G) 2CU UPLINK(1G) MCU?
10 posts / 0 new
Please suggest the MCU.
Realtek
could you suggest the part number (i have choosen"RTL8330" or microchip vsc7428) , whether it works ?  ?
What is your question? And why ask it here?
Actually i was looking ethernet switch IC with 8 Port 10/100/1000G downlink, 2SFP and 2CU uplink with 10/100/1000Base - TX . Please suggest the ethernet switch IC.
Kartman wrote:
 why ask it here?
is the key question!
I know this is "General Electronics" but we do try to keep some kind of distant link to "electronics used with AVRs" here !
Moderator
PS anyone know of a good brand of toaster by the way?
I sort of gathered you wanted some sort of ethernet switch - as to where the mcu is involved is questionable. From the smart switch chips I’ve seen it is a mpu and usually running linux.
You’re asking about a fairly niche application on a forum that is for entry level mcus.
We've been happy with our De'Longhi ;-)
How about a Black&Decker toaster, I use one to do my SMD PCB's (they have AVR's), but sadly the model is obsolete so this is really just noise, I am not helping the signal to noise ratio.
Update: but tarts taste funny now, or do I got Covid19, at least I stopped using it to recover Au from Hg amalgam.
my projects: https://github.com/epccs
Debugging is harder than programming - don’t write code you can’t debug! https://www.avrfreaks.net/forum/help-it-doesnt-work
