Atmel Studio 7.0 Monitor Lag
6 posts / 0 new
Hi, hope this is the right place to ask about this.
I'm using Atmel Studio 7.0 on a 144Hz monitor and getting frequent and irregular screen lag (to around 30fps or so it seems). It instantly is resolved on closing Atmel Studio. I've tried disabling Virtual Assist. Has anyone run into this before?
jionbha wrote:
screen lag
not sure what you mean by that ?
Try to turn off hardware accelerated rendering (Tools/Options)
:: Morten
Deep in the bowels of Visual Studio (and hence Atmel Studio) settings is an option to say "use basic graphics not the fancy DirectX stuff from my video card". That will probably avoid any "odd" behaviour.
Can I just say "SNAP!" to Morten while I also add this picture...
Thank you both! That did the trick.
... I can't post pictures while out running :)
jionbha this does however point to some underlying issue with your graphics driver...
:: Morten
