writing a string to EEPROM
4 posts / 0 new
I have posted this in the EEPROM tutorial topic. It was later when i realized that if a person reads the tutorial topic, it is likely they are new at using EEPROM like myself. I apologize for the double post :oops:
I have a problem writing to EEPROM of atmega8515. I get a string send to parceInput but when i read the EEPROM all I get is ( ¼ ) that. If I put something in the EEPROM using EEMEM, reading it works just fine. Someone please explain how to write a string to EEPROM in one function and read it in another.
Here is the code I tried
uint8_t  EEMEM EEPROMString[10]; // this is before main()
void parceInput(char s[])
   if ((s[0] == 'r') && (s[1] == 'e') && (s[2] == 'a') && (s[3] == 'd'))
      sendString("Reading EEPROM \r\n");
      readEEPROM(); // read whats in eeprom
      sendString("Saving to EEPROM : ");
      sendString(s);
      sendChar('\r');
      sendChar('\n');
      eeprom_is_ready(); // dont know what this is, says in EEPROM.h to use it.
      eeprom_write_block((const void*)&s, (void*)&EEPROMString, 10);// write a string to the EEPROM
// readEEPROM
void readEEPROM()
eeprom_is_ready();
uint8_t  SRAMstring[10];
eeprom_read_block((void*)&SRAMstring, (const void*)&EEPROMString, 10); // read whats in EEPROM
sendString((char *)SRAMstring);
Thanks in advance.
Watchdog timing out?
Just lose the '&' on '&s' in the call to eeprom_write_block(). s is already a pointer, you don't want to pass a pointer to a pointer
Thank you 8) It works now.
