[closed, no answer though]Which timer used by Arduino in NANO every?
7 posts / 0 new
Timer0 has been used by arduino In NANO,  what about NANO every?
TCA has been requisitioned?
How to output 40K HZ  PWM in NANO every?
I think it is better to use TCB, for there are 4 of it.
But I don't know how to get it.
With 8 bit PWM mode, what I get is like this:
the counter is 16 bits and the CCMPL/CCMPH is 8 bits, it just output half PWM :)
amazing.
Look at the core code - it's on your computer somewhere in the Arduino directory.
PWM output on PF5 of 4809 is right.
It should be other hardware parts caused.
Sorry, the reason is that the USBee is crazy.
The PCBA works well.
The frquency is not right, but that is another problem.
By reverse engineering, I have found that TCA0.SINGLE is used for pwm 5,9,10, TCB0 is used for pwm 6, and TCB1 is used for pwm 3.
I have found it crazy not to find an official documentation with this information anywhere.
It's in the source code, of course:
https://github.com/arduino/Ardui...
