Microchip direct appear to have some parts in stock. There is some confusion over the MOQ but, as a test, I've just ordered 25 pcs of the 128DA48. I'll see if the order gets accepted. If they arrive I'll be happy to bung a few out to fellow freaks in the UK and Europe.
#5 "If you think you need floating point to solve the problem then you don't understand the problem. If you really do need floating point then you have a problem you do not understand."
That moq on the qfp parts confused me. I chanced it and placed an order for 25pcs and the system accepted it. At the moment it looks like I might get them.
I've just had notification that 25pcs of AVR128DA48 are on their way to me!
Just installed the new packs. So this is "xmega4", hum? Yeah, the architecture is different, of course 128Kb can't fit in the 64Kb linear address space. They use some kind of memory paging, or else it's back to progmem...
Time to do some experiments while waiting for the actual chips.
edit: and yes, as I feared constant strings are being processed like on classic AVRs, by being copied to SRAM first. So PROGMEM is back...
Looking at the data sheet, it seems that you should be able to get away with up to 32K of flash mapped into the data address space.
I'm not sure you can convince the compiler that you've set that up, though. (Linker scripts? Can you just move the .rodata section to the 32k of high flash and have the linker complain if it overflows?)
As you know, on classic AVR we have 2 choices for using constant data:
let the compiler do it's thing, and we will be wasting SRAM, because all constant data is copied there
Use the facilities of pgmspace.h; this way you save SRAM, but now you need to use PROGMEM and cumbersome pgm_whatever to access the data
The flat address space of the AVR-0/1 had solved that problem, we could use standard C for constant data and not waste RAM. But now with the DA series the problem is back, so I'm just complaining a bit, I like to complain from time to time
edit: and also complaining because they decided to recycle xmega4 scripts for the DA instead of going to the trouble of writing new ones that could make use of the linear mapped flash area.
Mine have arrived too, they come in narrow 28 pin DIP packages like the mega328p. Background is my IKEA silicon mat that I use for soldering, it was on sale
Both my AVR128DA28 (ordered via microchipDirect) and AVR128DA48 (ordered as samples) seem to be working and talking to MPLABX via a SNAP, and doing the whole Blink thing...
Next-generation AVR MCU family features core independent peripherals, advanced analog and on-chip communications
Chandler, Arizona
May 5, 2020
Development Tools
Microchip’s AVR DA family of MCUs offers several options for software and hardware support. Software support includes Microchip’s MPLAB® X, MPLAB Xpress and Atmel Studio, code configuration tools including MCC and START, and compilers including GCC, XC8 and the IAR Embedded Workbench. A functional safety certified version of the XC8 compiler is available via Microchip’s Functional Safety Ready program. Hardware support is included in debuggers/programmers including MPLAB PICkit™4, MPLAB SNAP, Atmel ICE and the AVR128DA48 Curiosity Nano evaluation kit.
Pricing and Availability
The AVR DA family of MCUs is available in volume production in 10,000 quantities starting at $0.87. For additional information, contact a Microchip sales representative, authorized worldwide distributor, or visit Microchip’s website. To purchase products, visit our purchasing portal or contact a Microchip authorized distributor.
The AVR DA family of MCUs’ high memory density and SRAM-to-flash ratio make them suitable for both wireless and wired connected sensors nodes, as well as other stack-intensive applications.
I observe that the slightly-staggered pin-header arrangement (AFAIK, invented by SparkFun to help hold the headers in place during soldering - I don't think they're tight enough to make soldering unnecessary) is really annoying when used with that long a strip of pins... My poor fingers!
Agree. I could never get the whole thing to go in on my 4809 CNANO. But I could test out my projects with a few header pins without soldering them, so the connection seems to be pretty decent (even with a 230.4k baud serial comm happening through the stuffed-in-but-not-soldered pins).
... is really annoying when used with that long a strip of pins... My poor fingers!
I hear you. My fingers suffered too, but I managed to get the two full strips in.
While playing with the analog comparator, I found the first error in the (admittedly preliminary) datasheet. It says that the voltage reference for AC is using the DAC reference. This is not so. The AC has its own independent reference.
Unfortunately I have no AVR DA chips yet, so I cannot make the following test by myself. I need more PWM channels, so I’d like to use timer type A (TCA type) in split mode. Hoverer, I have some bad experience with this mode on XMEGA32E5, and in many other XMEGAs split mode doesn’t work as expected.
So, can you please confirm that in split mode timer really can generate 6 8-bit PWMs? XMEGA32E5 in this mode can generate 8-bit PWM but the number of available channels is not doubled as stated in datasheet.
Added PTC information. Corrected SPI1 alternative pins for AVR128DA48 and AVR128DA64. Updated external clock and clock output signals. Corrected CORE_VERSION.
While trying to get the USART and CCL to do automatic collision detection and backoff on a half-duplex line, I came across something that isn't documented in the datasheet. In the USART CTRLA register description, there is one bit allocated for RS485/XDIR pin signalling:
But when looking in the device headerfile (at least ioavr128da48.h), it looks like there are two bits related to RS485:
Generating PWM Signals Using TCD with High-Frequency Input
edit :
TB3236 - Generating PWM Signals Using TCD with High-Frequency Input
TopWow, package pinouts, they are looking goofy on my browser, better start tonight before they get out the Neuralizer.
my projects: https://github.com/epccs
TopBasic Bootloader for the AVR-DA Family
TopUsing 10-Bit DAC for Generating Analog Signals
TopAN3249 Getting Started with the AVR-DA Family
TopMicrochip direct appear to have some parts in stock. There is some confusion over the MOQ but, as a test, I've just ordered 25 pcs of the 128DA48. I'll see if the order gets accepted. If they arrive I'll be happy to bung a few out to fellow freaks in the UK and Europe.
#1 Hardware Problem? https://www.avrfreaks.net/forum/...
TopThanks!
https://www.microchipdirect.com/product/search/all/AVR128DA48
very low MOQ for QFN; QFP is MOQ one tray.
Haven't read the datasheet to see if QFN has wettable flanks (drag soldering is akin to wave soldering)
AVR128DA48 - 8-bit Microcontrollers
edit : Microchip - Samples Web Site (AVR128DA48)
TopThat moq on the qfp parts confused me. I chanced it and placed an order for 25pcs and the system accepted it. At the moment it looks like I might get them.
TopQTouch® Modular Library Peripheral Touch Controller User's Guide
Appendices A and K for revision history and link to the library documentation
Touch Sensing | Release Notes - Developer Help
TopIt certainly looks like the chip family I would have loved to have had 5 years ago...
Now, it's competing with those 120MHz CM4 chips...
TopNo DMA? Bummer.
TopAVR DA-series may be seen as a follow-on to XMEGA D which doesn't have DMA.
IIRC, MPLAB X v5.35 has precursor for more AVR Dx-series.
edit : MPLAB X IDE | Microchip Technology
Top"Dare to be naïve." - Buckminster Fuller
TopI've just had notification that 25pcs of AVR128DA48 are on their way to me!
Top***Datasheets are now on the Microchip Website***
http://ww1.microchip.com/downloa...
Top***DIP parts now available on Microchip Direct***
TopI ordered a few of the DIP ones, taking advantage of the free shipping offer this month.
Something to play around while the quarantine continues...
TopThis DA family is impressive,
TopWow, those pin currents and the clamp currents are much higher than the "old" chips.
TopThey've escaped from the factory and landed on my bench...
TopAVR128DA32 arrived to me today.
It attaches without modification to the breakout for mega4808.
TopJust installed the new packs. So this is "xmega4", hum? Yeah, the architecture is different, of course 128Kb can't fit in the 64Kb linear address space. They use some kind of memory paging, or else it's back to progmem...
TopLooking at the data sheet, it seems that you should be able to get away with up to 32K of flash mapped into the data address space.
TopWell, the xmega3 have this
I'm guessing the AT> text means that .rodata is in the text memory region, whose size is known to the linker, so it should complain.
I really don't know what I'm doing, but maybe something like this for the xmega4?
TopI may be misunderstanding your problem.
I have used the last 64KB of program memory as data on xmega128A1U.
There was no problem using far pointer and pgm_read_byte_far, is that frustrating?
Edit:--------------------------------
Oh, I just noticed.
Declared in __flash and wanted to read from the RAM address without using pgm_read_byte_far.
I have no idea.
TopAs you know, on classic AVR we have 2 choices for using constant data:
TopHmmm, nice, AVR128DA28 in a DIP package.
I really need to get the current project finished and shipped so I can free up some play time.
TopMine have arrived too, they come in narrow 28 pin DIP packages like the mega328p. Background is my IKEA silicon mat that I use for soldering, it was on sale
TopDoes anyone have EAGLE libraries yet?
TopOMG, I am
retarded, I used thewrongpackage, will try again...update:
well that 48pin pitch seems wrong, but the DS is saying 0.5mm, it is not tested.
so less retarded, but probably mostly
TopWoo hoo!
The 28-pin DIP is on a protoboard, and I dropped the 48pin chip onto a 4809 board that I have around...
Top(interestingly, the MPLABX programmer doesn't seem to complain if I have the wrong chip connected.)
TopMicrochip has published some information about the new DB series!
AVR128DB64
AVR128DB48
AVR128DB32
AVR128DB28
TopProduct Change Notification - SYST-22TQTN001 - 23 Apr 2020 - ERRATA - AVR128DA28/32/48/64 Silicon Errata and Data Sheet Clarification Errata Document Revision
TopSigh. It would be nice if the NVM Controller wasn't COMPLETELY DIFFERENT from the mega0/xtiny series :-(
Topvia https://www.microchip.com/RSS/recent-PRProduct.xml
TopI know I'm a bit late, but I want in on the action too.
TopHeh. I got a couple of the Curiosity boards.
TopAgree. I could never get the whole thing to go in on my 4809 CNANO. But I could test out my projects with a few header pins without soldering them, so the connection seems to be pretty decent (even with a 230.4k baud serial comm happening through the stuffed-in-but-not-soldered pins).
-Sam
TopI hear you. My fingers suffered too, but I managed to get the two full strips in.
Topnew arrival, 91 parts, 3 in stock, 8 on order, ETA 12-Jun'20 to 7-Dec'20, 6 week to 30 week lead-time
AVR DA 8-Bit Microcontrollers - Microchip Technology | Mouser
Topnew arrival, 100 in stock, 1 week lead time
AVR128DA48 Curiosity Nano Evaluation Kit - Microchip Technology | Mouser
Topvia a banner on the home page
AVR DA | Microchip Technology
TopHello to everyone!
TIA
TopI tried it. The device used is DA32.
The test code is here.
The clock is 4MHz by default.
Observation on the scope seems to work well.
This is available not only in the DA series but also in all of the AVR0 / 1 series.
Edit: Add fuse settings
TopThank you very much! I really appreciate your help.
TopThe pack seems to now have core version 4, the assembler in studio has an error with this version.
TopWhile trying to get the USART and CCL to do automatic collision detection and backoff on a half-duplex line, I came across something that isn't documented in the datasheet. In the USART CTRLA register description, there is one bit allocated for RS485/XDIR pin signalling:
Is this a hidden feature, or just an error in the headerfile?
TopPages
