HOLD, DETECT SAME HOLD MANY TIMES , DO!
21 posts / 0 new
Hello freaks , I hit a wall when doing something and hence want some advice. I know how to hold a button and do something but now I want to do something else I want to hold a button which will enable the user so that he can hold another button and then due to both of their holds something appliance will run this is simple indeed I have achieved this but now I want to detect that whenever the second button is released the avr should start a timer and during that period even if the second button is held the appliance will not run. I think You guys will understand more from the code. I am also giving a pseudo code for clarity:-
Using the atmega8 at 8MHz clock
1.1st button held - 1st led lights up
2. 1st button released -  1st led is switched off
3. 2nd button held - held will be registered only if the 1st button is being held first and nothing will happen if 1st button is not held- 2nd led turns off
4. 2nd button released - 2nd led lights up and starts a timer (for say 10 minutes) and also starts a flashing led as an indication during the period if 2nd button is held again then
   turn ON an output.
5. after the set time the timer stops and the flashing led also stops and then wait for manual start of the output.
This is roughly what I want any suggestions guys here Is what I have created. You can inspect my work.
 * atmega8 dry_run_controller_3.c
 * Created: 10-04-2020 12:46:05 PM
 * Author : HP
#include <avr/interrupt.h>
#include <util/delay.h>
#include "debounce.h"
void motor_on(void);
void motor_off(void);
void automatic_mode(void);
void automatic_high(void);
void automatic_low(void);
void dry_run(void);
void dry_run_flasher(void);
int dry_run_counter = 0;
int start_timer = 0;
void manual_mode(void);
void manual_low(void);
void manual_high(void);
void filling_led(void);
int mode_of_operation = 0;
int filling_counter = 0;
int filling_hold = 0;
int hold = 0;
int pressed = 0;
int activate_dry_flasher = 0;
int activate_dry_timer = 0;
void universal_dry(void);
	DDRB = 0b00100000;
	PORTB = 0b11011111;//pull ups for the inputs
	DDRC = 0xff;
	PORTC = 0x00;//all outputs turned off
	DDRD = 0b01111111;
	PORTD = 0b10000000;//pull ups for buttons
	TCCR0 = (1<<CS02);//pre-scaler of 256 at 8MHz
	TIMSK = (1<<TCNT0);//initiating the timer0 in normal mode
	debounce_init();
	OCR1A = 15624;
	TCCR1B |= (1 << WGM12);
	// Mode 4, CTC on OCR1A
	TIMSK |= (1 << OCIE1A);
	//Set interrupt on compare match
	TCCR1B |= (1 << CS02);
	// set prescaler to 1024 and start the timer
	sei();
	_delay_ms(50);
	mode_of_operation = 1;
	PORTD |= (1<<PD4);
    while (1)
		if(mode_of_operation == 1)
			automatic_mode();
			manual_mode();
		if(button_down(BUTTON1_MASK))//manual ON
			motor_on();
		if(button_down(BUTTON2_MASK))//manual OFF
			motor_off();
		if(button_down(BUTTON3_MASK))
			mode_of_operation = 1;//ie in automatic_mode
		if(button_down(BUTTON4_MASK))
			mode_of_operation = 0;//ie in manual mode
ISR(TIMER0_OVF_vect)//using the timer0 for filling tasks
	debounce();
	if(activate_dry_flasher == 1)
		PORTB ^= (1<<PB5);//dry_run led is blinking
ISR(TIMER1_COMPA_vect)//using timer1 for separate tasks
	if(activate_dry_timer == 1)
		if(hold == 10)//until 10 seconds have passed
			if((!(PIND & (1<<PD7))) == 1)//even if dry_run is held do not turn ON the motor
				motor_off();
				hold = 0;
				pressed++;//count the number of interrupts
			if(pressed != 3)
				//PORTC |= (1<<PC1);//stop the blinking
				activate_dry_flasher = 0;//stop the blinking
					motor_on();
					hold = 0;
					//pressed++;//count the number of interrupts
			hold++;//increment the hold timer continuously.
void motor_on()
	PORTC |= (1<<PC0);
void motor_off()
	PORTC &= ~(1<<PC0);
void automatic_mode()
	PORTC |= (1<<PC4);
	automatic_high();
	automatic_low();
	universal_dry();
void manual_mode()
	PORTC &= ~(1<<PC4);
	manual_low();
	manual_high();
void manual_low()
	if((!(PIND &(1<<PD5))) == 1)
		PORTC |= (1<<PC2);
		PORTC &= ~(1<<PC2);
void manual_high()
	if((!(PINB &(1<<PB7))) == 1)
		PORTC |= (1<<PC1);
		PORTC &= ~(1<<PC1);
void filling_led()
	PORTC ^= (1<<PC3);
void automatic_high()
		PORTC |= (1<<PC1);
		motor_off();
		PORTC &= ~(1<<PC1);
void automatic_low()
	if((!(PIND &(1<<PD5))) == 1)//if low is held
		PORTC |= (1<<PC2);//low led ON
		if((!(PIND &(1<<PD5))) == 1)//if dry_run is held
			motor_on();
			PORTC &= ~(1<<PC5);//dry run led is OFF
		else//if dry_run is not held
			activate_dry_timer = 1;
			activate_dry_flasher = 1;
			motor_off();
		PORTC &= ~(1<<PC2);
void universal_dry()
	if((!(PIND &(1<<PD7))) == 1)//if dry_run is held
		PORTC &= ~(1<<PC5);
		motor_off();
As you might have known after reading my code that I am working on a controller to automatically turn ON and OFF my water pump in case of water supply failure. Any advice would be highly appreciated.
Anshumaan.
anshumaan kumar
I think you need to have a read of this - https://www.avrfreaks.net/forum/...
You really only need one hardware timer.
As for your question, rather than look at some code, step back and think about the task at hand - not the code. Once you've figured out the required sequence, then the code will fall into place.
   turn ON an output.
What happens if the user presses both button1 and 2 together?
Have you read about state machines?  https://www.avrfreaks.net/forum/...
I haven't read this article but yes I have read about them please don't compare the above given code to a code of a state machine although I am trying to create one but the above code is no where near on how to create a working state machine I am currently using Kartman's code to achieve my goal I will share that. In the mean time can someone see that how I am holding the button , I am detecting holds using this method:-
although I know how to use timer to detect the hold of a button but this thing works perfectly too even on the hardware so I decided to stick with this. Is this right or I should really be using timers to detect the button holds.
Below is how I use timers to detect the button hold:-
Please tell which is the right way to detect a button hold:-
ISR(timer1_COMPA_vect)
    if(button_is_pressed)
    if(counter == 2)//after 2 seconds
        //do something
        counter = 0;
        counter++;
anshumaan kumar
So why did you decide not to use one?
Well I thought that this will be a simple project but then the requirements went on increasing because I haven't planned on how to achieve this problem ,this is what I am, I rarely plan before ,which is why I am used to confusing myself in the very simple of things. Hoping to fix myself in the upcoming projectslaugh.
By the way thanks awneil for asking.wink
anshumaan kumar
State machines don't need to be big or complex, and are not reserved for big and/or complex projects.
One of the beauties of state machines is that they are (relatively) easy to extend as a project grows.
Perhaps now would be a time to refactor ... ?
Yes this would be a perfect time for a change so you tell which code can accomplish my requirements better Kartman's multitasking code or the state machine code given by Jim??
What do you think? I love Kartman's code because it is so easy to use and I have created a working device with it in the past. I am leaning towards that code but If you have used Jim's code
you can give me advice to use that I will have no problem using that too. New things would be nice to learn.
anshumaan kumar
Total votes: 2
Multitasking and state-machines are not mutually exclusive.
Most of my projects are multitasking and usually several of those tasks will require a state machine.
And in several projects, there is an overall state machine that determines what tasks are active...
David
I would totally echo Kartman's advice:
Don't leap straight into code!
Spend time with pencil & paper to thoroughly understand the problem, and design your solution.
Drawing a state diagram can be a great way to understand a problem - and answer questions like:
EDIT - Example:  https://www.avrfreaks.net/commen...
Coding is the last thing you should do!
So don't do that, then!
You need a better logic description
like step 3 when does LED 2  turn on (it only tell about how it turn off!)
what happen if key 1 is released under step 4 ? (or key 2 pressed again etc.)
I agree that a state machine would be normal way to do it, but this (so far) are very simple I think.
something like:
init div things
LED1 == key1
if key1 && key2    // assume if they come at the same time it's ok
    turn LED2 off
    key2flag=on
if !key2 && key2flag==on
   LED2 on
   start timer
   key2flag=off
   flash LED
if timer_running && key2
    set out
if timer_out
    LED2 off
Add:
missed the step 5 part in first try
Well I also thought like that just got confused with the names and nothing else. Thanks for clearing me up.
Yes you are right maybe I should try to improve myself rightaway.
Ok. I will this time try to do the coding in the end.
Yes you are right this is simple I just make it a mess myselfcheeky.
Thank you guys I will share with you what I have made asap.
anshumaan kumar
Hey guys this is what I have thought I hope I have written it clearly so that you guys can understand it clearly.
Well don't think that I am asking for code just want to ask a few things regarding the below given pseudo code:-
low is switch_1
low led is led_2
dry_run is switch_2
dry_run is led_2
timer led is led_3
motor is led_4
*if switch_1 == 1
led_1 == 1
led_1 == 0
*if switch_1 == 1 and switch_2 == 1
led_4 == 1
*else if switch_1 == 0 and switch_2 == 1
led_4 == 1
led_4 == 1
led_1 == 0
led_2 == 0
led_3 == 0
*else if switch_1 == 1 and switch_2 == 0
led_3 ^= 1 //flashing
led_4 == 0
start a timer until the timer is out do not start the motor i.e.
led_4 == 0 until timer is != 0
*until timer is out
    led_4 = 0
    led_3 ^= 1
    led_2 = 0
    then turn ON the motor i.e. led_4 = 1
    led_2 = 0
    led_3 = 0
    just let the motor off
    led_4 = 0
    led_3 = 0
    led_2 = 1
*when timer is out
    led_4 = 0
    led_3 = 0
    led_2 = 1
    now do not start the motor even
    led_4 = 0
    led_2 = 1
    led_3 = 0
Well just clear one of my doubts that how can I achieve this part
led_4 == 1
led_4 == 1
this is kind of confusing to me. One place to start explaining is this piece of code
    turn LED2 off
    key2flag=on
Basically I am asking how can I set flags like this. Earlier than now I used a variable and store 1 or 0 in it depending on the condition. Just like this:-
            automatic_mode();
            manual_mode();
So what I do is good or not???
anshumaan kumar
what do you mean, just use a variable & define some modes to be used:
if (mymode == FORWARD)
   {do this stuff...
      mymode = WAITING;}
if (mymode == REVERSE)
   {do this stuff...
      mymode = ALARM;}
Why does you program look extremely long just to fiddle with 2 switches?   Have you tried doing it in assembly?
            automatic_mode();
            manual_mode();
what i understood is that you have indicated this thing only just because I have used straightaway 1 and 0 it's looking weird but when I use like it:-
mode_of_operation == automode;
where, automode = 1;
everything becomes what you are indicating right??
Have I understood correctly.?
It could be because I must have been really confused on how to implement my idea into the coding.
No.Really not that strong in assembly , just started learning c++ near about 6 months ago.I am basically a student of electrical engineering just took these embedded things because I am interested in them.
anshumaan kumar
   {do this stuff...
      mymode = WAITING;}
   {do this stuff...
      mymode = ALARM;}
This is actually the same thing that I was doing and I realised it long after I was working.Thanks for clearing my doubts.
something like:
Thanks this helped me a lot.Thanks man.
I had worked hard on this,it could still look to you a little bit of a mess sorry for that but it works I will clean it a bit later.
Paper computer always works.Thanks man.
 * Author : HP
void motor_on(void);//motor is on
void motor_off(void);//motor is off
void low_led(void);
void full_led(void);
void sensor_show(void);//showing all the lights
void dry_run_led(void);
void dry_run_function(void);
void timer_check(void);
uint8_t start_timer = 0;
uint8_t start_flasher = 0;
uint8_t timer_is_running = 0;
uint8_t dry_flag = 0;
uint8_t counter = 0;
uint8_t timer0_counter = 0;
uint8_t manual_start_flag = 0;
uint8_t dry_tries = 0;//stating that the tries have been done.
uint8_t mode_of_operation = 0;
 DDRB = 0b00100000;
 DDRC = 0xff;
 DDRD = 0b00010000;
 PORTD = 0b11101111;//pull ups for buttons
 TCCR0 = (1<<CS02);
 TIMSK = (1<<TCNT0);
 //starting the timer_1
 OCR1A = 7812;//truly 250ms count
 // Mode 4, CTC 1 OCR1A
 //Set interrupt 1 compare match
 debounce_init();
 sei();
 _delay_ms(50);
 while (1)
   motor_on();
   motor_off();
   mode_of_operation = 1;//i.e. in automatic_mode
   mode_of_operation = 0;//i.e. in manual mode
   automatic_mode();
   manual_mode();
 debounce();
 filling_led();
 //PORTD ^= (1<<PD4);//power led
 //debounce();
 //filling_led();
 if(start_flasher == 1)
  PORTB ^= (1<<PB5);//timer led
  PORTB &= ~(1<<PB5);
 if(start_timer == 1)//starting the timer
  if(counter == 20)//after 5 seconds
   timer_check();
   counter = 0;//restarting the counter to start again
   start_timer = 0;
   start_flasher = 0;
   dry_flag = 0;
   counter++;
   timer_is_running = 1;
   start_flasher = 1;
  counter = 0;//stopping the counter
  start_flasher = 0;
void motor_on()
 PORTC |= (1<<PC0);
void motor_off()
 PORTC &= ~(1<<PC0);
 PORTC |= (1<<PC4);
 sensor_show();//showing the values of sensors in each mode
 automatic_high();
 automatic_low();
void manual_mode()
 PORTC &= ~(1<<PC4);
 sensor_show();
void filling_led()
 if((!(PINB & (1<<PB0))) == 1)
  PORTC ^= (1<<PC3);
  PORTC &= ~(1<<PC3);
void low_led()
  PORTC |= (1<<PC2);//low led == 1
  PORTC &= ~(1<<PC2);//low led == 0
void full_led()
  PORTC |= (1<<PC1);//full_led == 1
  PORTC &= ~(1<<PC1);//full_led == 0
void sensor_show()
 low_led();
 full_led();
 dry_run_led();
void dry_run_led()
  PORTC &= ~(1<<PC5);
  PORTC |= (1<<PC5);
  motor_off();//always turn off the motor when the supply is out
 if((!(PIND &(1<<PD5))) == 1)//if low is pressed
  dry_run_function();
void dry_run_function()
 //and then dry_run has been pressed  / released then :-
 if(((!(PIND &(1<<PD7))) == 1) && (((!(PIND &(1<<PD5))) == 1)) && (manual_start_flag == 0) && (timer_is_running == 0))//if low and dry has been pressed together
  //This is the ON condition when the timer has been fired for the first time
  motor_on();
  dry_flag = 1;//now storing that the motor is being ON for the first time
 if(((!(PIND &(1<<PD7))) == 0) && (dry_flag == 1))//supply is out for the first time
  //This stops the motor and starts the timer
  motor_off();
  start_timer = 1;
  start_flasher = 1;
 //ALL other conditions than this are ignored
  motor_off();//turning off the motor
void timer_check()
 if((!(PIND & (1<<PD7))) && (dry_flag == 1) &&(timer_is_running == 1))//if supply comes in the timer period
  motor_on();
  start_timer = 0;
  start_flasher = 0;
  dry_flag = 0;//resetting the counter to start checking again if supply goes out
One more question regarding this I wanna ask although this code works fine in a simulation but on a practical chip I noticed a flaw:-
As you noticed that I am using two timers the things in the timer0 mainly the filling function and the debounce function works on the simulation but in practical no buttons works and no filling function
blinking is achieved as if timer0 isn't started on the actual chip anything you guys could find on the code that I have missed that is messing these functions??
I have tried merging both of the timers code into one but to no affectsad
anshumaan kumar
The secret is to isolate the code that decodes the buttons from the rest of the code - you've got a mish mash of stuff everywhere.  This just makes it harder for you to debug.
I recently wrote a tutorial on debugging - maybe you might want to read it and apply some of the techniques mentioned?
A big mess...
separate your  detection of conditions from what you want to happen under those conditionns .....a state machine
switch mystate
      case motor_forward
             if pin1 mystate= motor_pause
             else if timer1>500 mystate=motor_stop
      case motor_stop
             if pin 22 mystate= motor_forward
             else if pin 34 mystate= motor_reverse
      case motor_hot
            if tempsensor<200 mystate=motor_resume
//take actions here
   switch mycase
       case motor_hot
                 turn on alarm
       case motor forward
                 turn on led green
                 turn on PWM
This captures some of the idea, but there can be more.  Usually you track the previous state (not shown here)
If the current state matches the previous state nothing has changed, and you can do keep those state things that need repeated over & over (maybe making continuous pulses, or calling a routine that displays the current pressure)
If the current state does not match the previous state, you have entered a new state and can do things that happen only once (like turn the motor ON, or make one pulse when entering open_trap_door state)...these things happen only when entering the state.
So just because you are in open_trap_door, you don't have to keep making pulses, but  maybe there are other things you want to do repeatedly (maybe display a list of messages).
The  previous state is the set to match the current state (previous_state=mystate)
Hopefully this gives you some ideas to make things cleaner.
Wow. The thing that I wanted to learn I can code but can't code clean that's why its hard to debug that's right maybe I should first clean the code in a nice readable manner and then maybe I would find the problem myself.
Nice piece of advice I am on it.
avrcandies wrote:
A big mess...
ya.I am afraid it is sadthis happens when you are desperate to build something and then panic moment comes.
Yes.This will. Thanks for the explanation man I will do it as much as you could to make the code cleaner.Thanks for the help mate.
anshumaan kumar
It's a lot less twisted when you separate the flow between states  from the actions states allow to be taken.
There are many variations. A few to consider:
A state can take an action when it is first entered (once, say: turn on an led, turn off a valve)
    This might additionally involve performing some checks  (if the battery voltage is low turn on the led)
A state can take an action when it is leaving (going to another state) (once, say: turn on an led, turn off a valve)
    This might additionally involve performing some checks  (if the door is open, sound the alarm)
A state can take an action repetitively while remaining in the state (refresh the display with the latest voltage reading)
    This might additionally involve performing some checks (if the motor voltage is high, apply the brakes)
Sometimes the checks get complicated enough, or logically partitioned to naturally warrant becoming their own states.  It's a decision balancing between having too many (minor) states or too few (major) ones.
Having options at your disposal lets you arrange the actions in an understandable manner, and more importantly allows you to easily manage and modify them.
States can even be combined or nested. A "high level" printer could have a set of states for handling paper  (moving, ready, jammed, empty, wrong size, etc) , and another set for running the menus, perhaps coordinated by another set of system states.
Believe me or not this is one of the advice that I have got here and I will never forget nice explaining Sir. It really made my day.Thanks
Well I already know that but I was not accepting it until you have told me to do so. Thanks man I fired the timer1 at 10ms and then checked for button debounce routines and then created a 1 second counter to do all the other slow stuff and you know it worked. Thanks Good Sir.
avrcandies wrote:
A big mess...
It Still ischeekyBut I am Glad it works now as I wanted it to be. But don't worry I will try to create more clean codes from now on.Thanks man.
Stay Safe and Stay at home. Best thing to do at home is to code and try to build something .If stuck somewhere come here for help .A great place guys .Thank you all.
Anshumaan.
anshumaan kumar
