Template for Arduino libraries using archives?
10 posts / 0 new
I recently figured out that by default Arduino only creates an archive (.a) for the core, and not for any libraries.  Despite almost all C developers being familiar with the convention of combining .o files in to a .a, for the Arduino IDE all .o's built from a library are included on the link line.
I made a UART library that has optional support for interrupt-driven receive.  By putting the rx_data_ready() function in the same .o as the ISR (where the vector is defined), and linking the library .a, the ISR only gets installed if the rx_data_ready() function is used.  When I tried using the library in the Arduino IDE, I ran into the problem.  With the Arduino library build process, the ISR code gets included even if it is never used.
I see from the arduino libary specs that it is possible to create archive files.
https://arduino.github.io/arduin...
My tolerance for learning Arduino internals is rather limited, as I have to suppress the impulse to bang my head against the wall every time I read another stupid way it does things. :-)
Is anyone aware of a reasonably simple and well written Arduino library I can use as a template?
Total votes: 3
Isn't that an oxymoron?
David (aka frog_jr)
Does arduino.cc have a "developers" area - as opposed to the "user" areas - for this kind of question ?
Even if it did, I'm not welcome there.  I got banned from the forums several years ago after questioning the honesty/ethics of Marchese Banzi.
was that in the "Arduino Wars" ... ?
No, I think that was in "Arduino strikes back!"...
I've found I've wasted more time in the Arduino forum than the benefits I reaped from it.
FIY, since it's C++ I write my arduino libraries as a single .hpp file, which helps me get the inlining and code optimization properties I want.
I would have expected unused methods would get stripped by the linker even if they're defined in a .cpp file and compiled in a separate .o.
TBH IDK if the linker would nuke unused methods from a .a... When you compile a static binary there's no reason to keep unused methods, nor keep them relocatable. hmmm...
My GitHub (FAB_LED bitbang for ws2812, DigitalIO, SerialMenu...).
I make portable, code optimized Arduino libraries as a hobby and use AtTiny85 the most for my builds.
I am a burner and an OS and systems programmer by trade.
could it be the ISR stays because you have a function pointer that doesn't optimize away when you compile a program using your library? Protect its use by a program constant?
No.  The vectors are all weakly defined in crt0, so any .o (not contained within a .a) that defines a vector will be preferred and get linked in.  When it is in a .a, the linker only pulls in .o's to resolve undefined references.  A good example of how it works would be to look at how __do_clear_bss and __do_copy_data only get linked in when needed.
I think this explains it better than I could.
https://eli.thegreenplace.net/20...
