GPIO in SAMD21
3 posts / 0 new
Hi
I have started configuring GPIO pins.
Please find code below.
#define Pincfg                  	0x06
#define PA13			        	(1 << 13)
#define PORTA			        	PORT->Group[0]
#define RX			            	PA13
#define Read_IO_PA13()              ((PORTA.IN.reg)>>13)
    int main()
        unsighed char readdata;
        PORTA.DIRCLR.reg = RX; //set direction as input
        PORTA.PINCFG[13].reg |= Pincfg; //enable input buffer and internal pull
        readdata = Read_IO_PA13();
        return 0;
I am unable to read pin PA13.
Please help me to resove this.
Compiler: Mplab X
Using simulator in above mentioned compiler
Microcontroller: samd21g17d
You must enable clocks first.
Its random occurrence, sometimes I am able to read value on pin, sometimes I can't read it.
Please elaborate on how to configure clock specifically for GPIO configurations as I couldn't find it in datasheet.
Is it like when we configure timer, we select Generic clock generator as input to TCx?
Thanks!
