Help for Assembly Newb
8 posts / 0 new
I am trying learn assembly.
Could someone please explain the loop below and when/where/how many times it loops?
ldi R16, 40
outer_loop:
ldi R24, low($4000)
ldi R25, high($4000)
inner_loop:
sbiw R24, 1
brne inner_loop
dec R16
brne outer_loop
Thanks in advance.
It loads  hex  4000 into the pair...decimal 16384
it counts it down one by one until zero
Then it repeats this process 40 times.
You have to figure out the details yourself
Thank you. The didn't realize the hex.
If you make a build-able program then you can run it in the simulator and you can see what is going on by running it in single step.
Of course you will have to use smaller numbers as the simulator is very slow other wise you will be a very old person by the same the loop end.
Interesting inconsistency (hobgoblin of little minds?):
The ldi R16 is in decimal.
ldi R24 and ldi R25 is in hex.
sbiw R24 is in decimal again.
[dec r16 doesn't care].
S.
Actually, you could manually adjust the counts in the simulator - so you don't have to change the source code ....
Not a big deal in this case, but a useful debugging/testing technique in general ...
Perhaps the original author worked for NASA...
or perhaps the ESA!
Thanks for the laugh!
