AVR Delay routing using parameter as delay needed
65 posts / 0 new
Pages
ralphd wrote:
sparrow2 wrote:
Point take that is only a problem on the newer once. (and we all assume that a read from undefined flash just is remapped).
I don't assume that.  Not only have I read about other people's tests, I've tested flash address wraparound on several tiny/mega AVRs.  It's also well documented (search for " --pmem-wrap-around ")
In the usual case with power of two flash, I believe that wraparound is implicitly guaranateed.
The datasheet spcifies what bits of Z are used: just enough to cover the entire range.
I also read somewhere here that:
--pmem-wrap-around
Don't always work. But I can't remember if it was a HW error or a compiler error.
Also on of the chips (I think a 16k flash version) always push a illegal return addr. for (r)call ! so that for will (has to do wrap all the time).
I have not seen anywhere that Atmel has guarantied wrap to work other than for 8k chips.
Add
But this is about a SW delay OP for some reason want to do.
I wanted OP to do it him self but now it's solved.
joeymorin wrote:
Here's how I did cycle-accurate delays in one project:
I've lost track here.  Your solution, joey, is a build-time solution, right?  Didn't OP want run-time?
robydream wrote:
 I want to write delay routine that is accepting delay time
I thought that the "newer" GCC facilities were cycle-accurate?
If there is a reasonable range of values, couldn't a Duff's device-type-thing be used?
In C, via __builtin_avr_delay_cycles, yes.  It's a GCC extension.
For my purposes, I needed assembly language, and I needed something that would use a minimum of code space via a (re)callable subroutine.  Looks like the OP wants assembly language, too.
Where did he say that, exactly?
Isn't that what "using parameter as delay needed" (in the title) means ?
I don't see how 'runtime' is implied.  Macros take parameters, too.
fair point - and it's the way the 'C' delay works, too.
I quoted, from #1.  At least that was the way I took it.
"  I want to write delay routine that is accepting delay time ..."
And the "not working" code immediately following sets a "parameter" and then jumps to the "routine".
So you can't use _builtin_xxx except in a C source?  [not a GCC person]
C'mon; you are stretching things now, aren't you?  Are you arguing that there is, then, no difference between e.g. delay routines that are expanded at build time such as your example code, and those that pass a parameter at run-time?
Of course not.  Why be specious?  This is irrelevant to the thread.  If the OP can achieve what they're looking for by extracting from my or your or anyone else's posts, what difference does it make?
If you say so.
Macros have parameters, as you well know, and as has already been established in this thread.  A suggestion was made in #41 to examine and emulate _delay_nn macros' code generation, but you don't have a problem with that.
Possibly, but none that I know of.  It is a C extension.
Have you >>looked<< at the code in #46?  It is a macro, yes, but it generates a call to a subroutine.
Perhaps I'm getting too old, or the virus is affecting me.
joeymorin wrote:
Use like this:
	delay_c	46
is, to me, at build time.  It cannot accept a parameter at run time...let's say 8-bit (for convenience) ADCH, can it?
Why am I having such a hard time grasping how
is relevent to the thread?  Are you saying that you code can take, e.g. the value in ADCH at run time after a conversion and produce a proportional delay?  I thought that is what OP was asking for in #1.  Which post can be extracted to produce this varying ADCH-proportional delay?
How should I know?
The first (and only) mention of 'runtime' was by you.
The first (and only) mention of ADCH was by you.
Look at the macro in #46 again.  It generates two instructions.  An 'ldi' and an 'rcall'.  If you wish, you can rcall delay_loop yourself, having arranged to load tmp with whatever value you wish, perhaps with the contents of ADCH.
The code in #46 was offered with:
No other claims were made.
I fail to understand the value of this diversion.  It is not helping the OP.  Who, as you can see, hasn't been here for a while.
Boy, I must have tickled your isolation bone.  OK, tell me the exact wording to distinguish between build-time and runtime?  Call them case A and case B.  I read that OP wanted case B.  Did you read that differently?
The answers to this might be important, as it may well be the niggle.
And that was a bad example to make it clear as an example of a runtime/dynamic/not-the-same-value-every-time ?
I'm very confused again -- no, you cant pass that and have your macro lines such as
.elseif \cycles > (((3 * 256) + 7) + 2)
  work.  How?  "cycles" is ADCH at build time when the macro is expanded.  How do you know is ADCH is less than 0 or greater than a million?  Won't ou be working with the I/O address at this time?
Who asked for run-time delay, and you gave build-time.  And no, substituting ADCH value as "cycles" ain't gonna carry out your statements.
I can't quite figure out why this is a bone you can't seem to let go of, but whatever gets you through the day...
You've failed to convince me.  But this is a fun game.
theusch wrote:
How?
Never said.
Did say:
Pages
